General Supercharger Thread
  1. Sep 23, 2024 at 6:58 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Been a process figuring out how to put it together. Some post machining, some sanding, breaking parts, plasma cutting new throttle blades, but it seems to work! The idle is surging bad, I'm on my second throttle blade and evidently it's still not sealing well enough so will have to try making another, but it did respond to throttle inputs which is a win!
    pvn.beluga, Ctaylor76, nags and 18 others like this.
  2. Sep 23, 2024 at 7:27 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yes!!
  3. Sep 23, 2024 at 9:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    What's the gap? On that 103mm TB I had I was able to move one of the plastic gears and closed it up. Awesome that you got it going!
    ARES35 likes this.
  4. Sep 23, 2024 at 9:14 PM
    snivilous
    SW UT
    Right now is maybe .020" in a couple spots. It's not a matter of closing the blade more, just getting a consistently round blade that fits correctly.
  5. Sep 24, 2024 at 3:02 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Second rotor, pads & second caliper bolts arrived.
    nags, ARES35, AZTundra and 2 others like this.
  6. Sep 26, 2024 at 10:30 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I got my replacement boost gauge from AEM...and it's DOA...been dealing with trying to get a boost log since I started tuning with @snivilous back in April...now I get to deal with another RMA.
    ARES35, Wynnded and snivilous[OP] like this.
  7. Sep 26, 2024 at 10:31 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Weird- that's annoying. Did you replace harness etc?
  8. Sep 26, 2024 at 10:31 AM
    snivilous
    SW UT
    You have enough telemetry issues for a 1000 people
    ARES35, Wynnded, Saltyhero13 and 2 others like this.
  9. Sep 26, 2024 at 10:33 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    this.
    my harness was mangled when they ran it up the dash
    HulkSmurf14 likes this.
  10. Sep 26, 2024 at 10:41 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I did, I rewired with the harness with the new wiring they sent with the replacement gauge. I had to take the glovebox out to remove the gauge, so I took the time to shorten the wiring and make the gauge cluster removable. I also tested with another harness I have, only power and ground, not much to mess up.
    Lol, true, but most have been self-inflicted.
  11. Sep 26, 2024 at 12:08 PM
    pursuit2550
    pursuit2550 New Member
    I have been throwing around the idea of ditching my AEM AFR gauge and going to the AeroForce gauge. 1 gauge does it all basically. Only thing I was looking at is that the AF gauge only does 10.1-20.1 on their AFR sensor which is a LSU 4.9. I have been meaning to contact them to see if this is accurate since AEM can read down to 8.1. I ran their gauge with my SC 06 Silverado SS and I liked all the options it had and never had an issue.
    Just sent them an email to see what they say.
  12. Sep 26, 2024 at 9:25 PM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    Or buy a used one and send him that. Keep your original.
  13. Sep 26, 2024 at 9:31 PM
    Ctaylor76
    Chaz
    Houston
    I raced a TRX on the freeway and out ran him but it pulled on me after 80mph trucks fast.
  14. Sep 26, 2024 at 9:34 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    They don’t like when tundras pull on them lol
    HulkSmurf14, Saltyhero13, Mdl and 2 others like this.
  15. Sep 26, 2024 at 9:38 PM
    Ctaylor76
    Chaz
    Houston
    Yeah, not gonna lie that TRX is very very quick.
    Than I realized it's a hellcat engine AWD so instantly started feeling better about losing before his governor kicked on haha
  16. Sep 26, 2024 at 10:17 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    thats why you put yours in 4wheel, problem solved lol
  17. Sep 26, 2024 at 10:23 PM
    Ctaylor76
    Chaz
    Houston
    Yeah i was thinking about that, not sure how good that would be on the transfer case past 40mph?
    Mdl likes this.
  18. Sep 26, 2024 at 11:07 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Don't ask but...they do well into 100+. Even with my original 2007 transfer with 120k on the clock with a mix of on/offroad.
  19. Sep 26, 2024 at 11:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Did you have any excess air from these 2 spots for the TB bolts that maybe arent sealing with the coupler? Try fill/smooth with some rtv to ensure no excess air gets in. You know I'm the king of airleaks...
  20. Sep 27, 2024 at 5:43 AM
    Ctaylor76
    Chaz
    Houston
    Well glad i asked haha
    Mdl[QUOTED] likes this.
  21. Sep 27, 2024 at 6:10 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’ve heard of driveshafts blowing apart, specifically on RCSBs going 120+. Never heard of a blown transfer case though.
    ARES35 and Mdl like this.
  22. Sep 27, 2024 at 6:39 AM
    snivilous
    SW UT
    I was worried about that too, but the coupler I'm using is thick and compliant enough it seems to fully seal those pockets. This was proven yesterday when the throttle blade I coated with RTV just to experiment with worked well enough that the truck couldn't start since there was no airflow. That super tweaked throttle blade I got to work well enough to drive around, but the truck didn't like it and kept throwing stuck open or stuck closed errors so now waiting on the new laser cut blades.
  23. Sep 27, 2024 at 6:47 AM
    e30cabrio
    Sorry about your gauge Army, that is insane.
    Meanwhile UPS has no info on my missing calipers & the shipper did not insure them.
  24. Sep 27, 2024 at 6:51 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Did you try the harness before cutting it up?
  25. Sep 27, 2024 at 7:00 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    No, but I used my fuel pressure gauge to verify the boost wiring worked, and vise versa I plugged the boost gauge into the fuel pressure wiring connector and got the same result. I also did continuity testing on the wires from the deutsch connectors to the gauge connectors.
    ARES35, Mdl, e30cabrio and 1 other person like this.
  26. Sep 27, 2024 at 12:31 PM
    pursuit2550
    You are on 35's also. Probably a different story if it were like my truck probably. I have 33's but SL rated not E rated. My set up is actually a tab bit lighter or the same as OEM wheels and tires.
    Ctaylor76[QUOTED] likes this.
  27. Sep 27, 2024 at 12:32 PM
    pursuit2550
    Ctaylor76 likes this.
  28. Sep 27, 2024 at 1:36 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Was there mention of if it was the front, or the rear? The fronts are all the same as far as I know. The rears on the other hand . . .
    Edit: The quote didn't make it, this is in reference to the driveshafts blowing.
  29. Sep 27, 2024 at 2:09 PM
    pursuit2550
    Finally after 4 months of waiting.
    ARES35, Mdl and e30cabrio like this.
  30. Sep 27, 2024 at 3:16 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice! Are those just upgraded accumulators and not over sized? No drilling out the ports? Cool to see if you notice firmer lockups over the stock ones.
    ARES35 and pursuit2550[QUOTED] like this.
