Going Long Travel Front and Rear
Discussion in 'Long Travel Suspension' started by heckler66, Jul 4, 2023.
  1. Aug 3, 2024 at 12:29 PM
    #121
    heckler66
    heckler66 [OP] New Member
    2012 Tundra CM 4x4
    Icon Billet Upper CA King 2.5 Fr / Rr Deaver U748 Victory 4x4 bumper RCI Skid plates Baja Designs lights
    Limit straps are in
  2. Aug 3, 2024 at 12:50 PM
    #122
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Looking great man!
    reywcms and heckler66[OP] like this.
  3. Aug 3, 2024 at 1:31 PM
    #123
    heckler66
    2012 Tundra CM 4x4
    Thank you! Really appreciate it
    BiggHertz[QUOTED] likes this.
  4. Aug 3, 2024 at 2:08 PM
    #124
    Mullen
    Mullen Desert Dude
    Corona, CA
    2001 Prerunner, 2014 DC 4wd
    Where do the bumps hit on the rear end relative to the lower limit strap mounts? Looks like they would end up close at bump.
    heckler66[OP] likes this.
  5. Aug 3, 2024 at 2:10 PM
    #125
    heckler66
    2012 Tundra CM 4x4
    Bumps hit the pad with the American flag. Camburg bump kits hit the stock leaf perch area.
    Mullen[QUOTED] likes this.
  6. Aug 3, 2024 at 3:48 PM
    #126
    Mullen
    Mullen Desert Dude
    Corona, CA
    Right on. The pads and other machined parts look awesome.
    heckler66[QUOTED][OP] likes this.
  7. Aug 3, 2024 at 4:14 PM
    #127
    heckler66
    2012 Tundra CM 4x4
    Going to have to redesign the bump pads because where the bump stop hits (on the edge) and where I place the M8 holes. Might try to thread-rivet the existing 1/2” holes and use those.
    Peeeheeuuu and reywcms like this.
  8. Aug 3, 2024 at 4:25 PM
    #128
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Flex the suspension out too so you know the bump stop hits where you want when the axle is pivoted around too
  9. Aug 3, 2024 at 4:30 PM
    #129
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    This
  10. Aug 7, 2024 at 5:24 PM
    #130
    Mullen
    Mullen Desert Dude
    Corona, CA
    While I love the American flag on the bump pads, keep them smooth for bump scrub. Also, remove the nylon cap on the bump when cycling to simulate worst-case scenario where the bump cap is destroyed.
  11. Aug 11, 2024 at 9:31 AM
    #131
    heckler66
    2012 Tundra CM 4x4
    Updated the bump pad. The bump doesn’t rub on the flag engraving but I haven’t had a chance to articulate one side fully up. Also the cap screws are being replaced with shallow head cap screw so they will sit sub flush of the pad.
    Peeeheeuuu and Mullen like this.
  12. Aug 11, 2024 at 9:34 AM
    #132
    heckler66
    2012 Tundra CM 4x4
    Also started in the fiberglass bedsides. This was my initial cut. I had to cut more on the rear top portion which was giving me the most trouble. The fiberglass was built up so thick back there which made for a lot of interference. I’ll get more pics of what I had to cut later. Ordered some 1” tubing to make some bedside supports from the frame to the fenders near bottom of well.
  13. Aug 22, 2024 at 6:20 PM
    #133
    heckler66
    2012 Tundra CM 4x4
    Some bed supports mocked up, not installed yet. I may have mimicked an existing design.
  14. Aug 29, 2024 at 10:08 AM
    #134
    bryman55
    bryman55 New Member
    @heckler66 in the front wheel area back side fender, did you cut the body/frame on the back side to make clearance for the wheels? Camburg provides a small plate for this area. Did you make the cut? Do you think it is needed? If so, can you take a picture of your cut and wheel clearance, please?
  15. Aug 29, 2024 at 10:17 AM
    #135
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    This is called the body mount chop mount mod. Very common. Bottom triangle portion
    Peeeheeuuu likes this.
  16. Aug 29, 2024 at 10:17 AM
    #136
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I know that design! Looks awesome I've been towing on switching mine out. Let me know if you want to make another set lol
  17. Aug 29, 2024 at 2:46 PM
    #137
    bryman55
    bryman55 New Member
    @reywcms Thanks for the pics, that plate weld for the body mount chop is really clean. Also, is that FEND-X from a Tacoma you shaped in that spot?
  18. Aug 29, 2024 at 2:53 PM
    #138
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    This liner was custom made but showed up and I cut it all up and made it work for me much better. I'd disregard the brand but you can duplicate this with abs again
  19. Sep 16, 2024 at 7:01 AM
    #139
    heckler66
    2012 Tundra CM 4x4
    Bedsides mounted but still need to get the taillights in which are not lining up to the 2 factory bolt holes. I had to remove a lot of the factory bedside at the back top so the fiberglass would sit properly. Need to fabricate a couple brackets from the frame to the lower wheel well sections of the bedside.
    Mullen, Peeeheeuuu, AZTundra and 5 others like this.
  20. Sep 16, 2024 at 3:17 PM
    #140
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    I'm so envious! Your motivation to get mines done
  21. Sep 16, 2024 at 3:35 PM
    #141
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    More motivation to get It done
  22. Sep 26, 2024 at 7:43 AM
    #142
    heckler66
    2012 Tundra CM 4x4
    just a couple pictures. Got taillights in, but had to customize how they mount. I basically cut the 2 threaded tabs off and installed 1 M6 threaded rivet-nut into the housing which worked out really good. Currently working on fabricating bedside supports that bolt to the frame and lower bedside by wheel well.
  23. Sep 26, 2024 at 7:51 AM
    #143
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Looks good!
  24. Sep 26, 2024 at 8:05 AM
    #144
    heckler66
    2012 Tundra CM 4x4
    Im having a problem getting the gas filler anywhere close to where the new fuel door is. I can get a pump into it with no fuel door on it but if I added the door I just don't think it would have room. The bracket and 3 metal tubes make it difficult to bend much.
  25. Sep 26, 2024 at 8:09 AM
    #145
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I left mine short and bent the bracket. You can also remove the filler neck and extend the hoses by adding more hose there.
  26. Sep 26, 2024 at 8:13 AM
    #146
    heckler66
    2012 Tundra CM 4x4
    I will probably go the bendy route. Now I gotta bite my wallet and get the SS Built rear bumper.
  27. Sep 26, 2024 at 8:23 AM
    #147
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    significant lead times on that just as a heads up
  28. Sep 26, 2024 at 9:20 AM
    #148
    Peeeheeuuu
    Peter
    Elk Grove, CA
    Good luck with that. I had a horrible transaction with SS built and I would never do business with them ever again or refer tgem to anyone. Long story short, I ordered front and rear bumper, paid in full, waited over a year and got the run around for 5 months that my bumpers shipped but I never received them. Asked for my money back and got ghosted. I had to do a charge back to get my money back. I still have all my messages from them if you want them but be warned move at your own risk.
  29. Sep 26, 2024 at 9:52 AM
    #149
    heckler66
    2012 Tundra CM 4x4
    damn, I might have to reconsider because I can't stand businesses that don't respond. I was considering fabing my own but the hitch part has me concerned.
  30. Sep 26, 2024 at 9:06 PM
    #150
    CaptainRT
    CaptainRT New Member
    2011 CM
    Camburg LT front and rear, Supercharged
    just catching up on this thread and want to know why are you guys still running those air pumps still in the front passenger wheel wells, is it an inspection thing where your at?
