Best Brake Pads & Rotors...
Discussion in '2.5 Gen Tundras (2014-2021)' started by mambo143, May 26, 2019.
  1. Sep 6, 2024 at 11:08 AM
    #61
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    • Akebono Performance Ultra-Premium Brake Pads
    • ADVICS Rotors
    WILLINH likes this.
  2. Sep 6, 2024 at 11:29 AM
    #62
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    You probably didn’t do the proper bedding procedure if it vibrates a lot.
    reywcms likes this.
  3. Sep 6, 2024 at 11:38 AM
    #63
    ButtasTundra
    ButtasTundra New Member
    James
    2017 White Tundra Crewcab 4x4
    6" lift with BDS UCA, 35x12.5-20 Toyo Mud Terrain, Pioneer 10" wireless Apple Carplay unit, 2 channel and 4 channel amps, JL mids & highs, 2 JL 10' W3 shallow subs.
    thats what I was thinking too :(
    pvn.beluga[QUOTED] likes this.
  4. Sep 6, 2024 at 2:53 PM
    #64
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    My install went well. Running it a few miles to wear off any coatings and get a small layer deposit on the rotors. Will bed them this weekend.
    Question, do yall bed brakes on a new car?
  5. Sep 6, 2024 at 3:08 PM
    #65
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yep
  6. Sep 6, 2024 at 3:28 PM
    #66
    Haslefre
    Haslefre New Member
    TN
    Mine didn't vibrate myself until my dad drove my truck. Think he decided to be heavy on the brakes and then went through too high of puddle and likely warped a rotor...
    So 10k miles later, I get to change something again.
  7. Sep 20, 2024 at 2:03 AM
    #67
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Greens say you need slotted rotors to run. Anyone have info on this?
  8. Sep 20, 2024 at 2:54 AM
    #68
    1UP
    1UP Truck Gang
    My rotors were slotted and drilled. But I wasn't aware of that requirement
  9. Sep 21, 2024 at 5:27 PM
    #69
    NTX_Tundra
    NTX_Tundra New Member
    About to do the front rotors and pads tomorrow. Any advice on jack points/torque specs or other useful info from those who have completed this?
  10. Sep 22, 2024 at 2:10 PM
    #70
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Just jack up the truck at the front crossmember and then jack stands on both sides of the frame.
    There should be a thread somewhere on torque specs for caliper bolts…
  11. Sep 22, 2024 at 2:21 PM
    #71
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Toyota also states the caliper bolts are not reusuable.
    For 2016 and newer Tundra:
    Front - 180 N-m (133 lb-ft)
    Rear - 167 N-m (123 lb-ft)
  12. Sep 22, 2024 at 2:22 PM
    #72
    1UP
    1UP Truck Gang
    I didn't know that. Oh well.
  13. Sep 22, 2024 at 4:10 PM
    #73
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Oh well, torqued to spec and nothing has happened.
    1UP[QUOTED] likes this.
  14. Sep 23, 2024 at 5:09 AM
    #74
    1UP
    1UP Truck Gang
    I didn't even torque to spec. Really should get a torque wrench :anonymous:
    Totmacher likes this.
  15. Sep 23, 2024 at 6:48 AM
    #75
    centex
    centex New Member
    Impact and some blue lock tite. Had a caliper bolt fall out one day on a different vehicle and when I went to brake it rotated up into the wheel. That was fun at 70mph. All caliper bolts get lock tite now.
  16. Sep 23, 2024 at 7:12 AM
    #76
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I actually used orange lock tite when I installed those caliper bolts.
    centex[QUOTED] likes this.
  17. Sep 23, 2024 at 3:53 PM
    #77
    NTX_Tundra
    Did the front rotors and pads yesterday, bedded them in but I'm getting a chirping/clicking noise at 30+ mph on the right side. See video below. I'm going to take everything apart tonight to see if anything was loose etc. Any idea what this could be?
  18. Sep 23, 2024 at 4:36 PM
    #78
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    what pads did you use?
  19. Sep 23, 2024 at 4:46 PM
    #79
    NTX_Tundra
    BOSCH BC1303 QuietCast Premium Ceramic
    Rodtheviking likes this.
  20. Sep 23, 2024 at 5:00 PM
    #80
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Bosch pads typically fit well.
    Double check that nothing is touching backing plate or caught between the backing plate and rotor.
  21. Sep 23, 2024 at 6:31 PM
    #81
    centex
    centex New Member
    I had a small rock somehow get lodged between the pad and rotor on a different truck that made a similar sound. It got stuck in a groove in the pad material.
  22. Sep 24, 2024 at 5:44 AM
    #82
    NTX_Tundra
    Took everything apart and nothing seemed out of place. I did re-seat the rotor, so it's possible that could have been the issue. I took it for a drive after and no noise so I think I'm good to go.
    WILLINH and 1UP like this.
  23. Sep 29, 2024 at 5:58 PM
    #83
    therealjonwick
    JR
    2019 OR
    Do you guys usually bleed to install rotors and pads? Had the system flushed about 4 months ago. Don’t want to change fluid yet. Planning to just open the cap and push the pistons back in. Putting on yellow stuff pads and slotted cryos. Also confused on the different torque settings. Either 70ish or 133 for front caliper bolts. Have seen as low as 45 up to 120 something for rear. From 22-65 for rear slide pin bolts. Anyone nail down the answers? Have a 19’.
  24. Sep 29, 2024 at 6:32 PM
    #84
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No need to touch the fluid for rotors and pads. Open the cap and gently depress the pistons. Been doing it this way for over 25 years and never had an issue.
    centex likes this.
  25. Sep 29, 2024 at 6:58 PM
    #85
    centex
    centex New Member
    Ditto.
    therealjonwick likes this.
  26. Sep 29, 2024 at 7:12 PM
    #86
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    For 2016 and newer Tundra caliper bolts:
  27. Sep 30, 2024 at 1:35 AM
    #87
    therealjonwick
    JR
    2019 OR
    Perfect. Appreciate the info.
  28. Sep 30, 2024 at 1:39 AM
    #88
    therealjonwick
    JR
    2019 OR
    I did buy all new caliper bolts. Still can’t find info on the slider pins for the rear caliper. Only data I have is on the 2015. I’ve seen 20 ft lb or 65.
    On another note, the rear caliper bolts used to be 46 ft lbs. Now 123… that’s quite a jump.
  29. Sep 30, 2024 at 6:13 PM
    #89
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Toyota used larger front and rear caliper mounting bolts for the 2016 and newer models.
    From my information, 65 lb-ft is the rear caliper slider pin torque, and that number remained the same 2007-2021.
  30. Oct 3, 2024 at 5:44 PM
    #90
    therealjonwick
    JR
    2019 OR
    Slider pins are 65lbs. I need to buy the e-manual…geesh.
