Vland Taillights for 2nd Gen
Discussion in 'Lighting' started by texasrho83, Mar 19, 2023.
  1. Aug 29, 2023 at 7:41 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I guess I will just keep waiting for clear.
    B.Ross and BoysandHisToys like this.
  2. Aug 30, 2023 at 4:03 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Swapped back in the OEM lights this morning. Checking things out with the lights out, it looks like the 50W 6ohm resistor used to prevent hyperflash is bad. Measuring 5kohms or more as my meter was jumping all over the place.
    going to replace that and see if it fixes it.
  3. Aug 30, 2023 at 4:13 AM
    CMikeB
    CMikeB New Member
    I might B U Y a set, need to see more posts about 'em first though.
  4. Sep 2, 2023 at 11:47 AM
    BoysandHisToys
    Central Virginia
    Replaced that resistor on the tail light and it’s working again.
    Kinda odd that the resistor would fail like that. But cheap and easy fix!
    Shanet421 likes this.
  5. Sep 22, 2023 at 12:16 PM
    aelarson
    aelarson New Member
    AZ
    2021 1794 Tundra (Silver Sky Metallic)
    Any other folks get a set of these they'd like to share?
    I think once I get my truck back from the shop after my little fender bender, I'll upgrade.
  6. Oct 29, 2023 at 3:12 PM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Question, All the pics of these make the stop/brake lights look /yellow in color?
  7. Oct 29, 2023 at 3:14 PM
    BoysandHisToys
    Central Virginia
    The tail lights and brake lights are all red (all three rows). Only the outer row turns yellow and sequences from top to bottom for the turn signal.
  8. Apr 12, 2024 at 11:13 AM
    aelarson
    aelarson New Member
    AZ
    Reviving an older thread - any other folks have experience with these? Any issues with the people that have had them for a while?
  9. Apr 12, 2024 at 11:27 AM
    BoysandHisToys
    Central Virginia
    I was without my truck for a couple months. Just got it back. No issues with mine other than that resistor. And I’ll likely need to install OEM next month to pass inspection and then put these back in. They are not DOT approved if that’s a concern for you.
    aelarson likes this.
  10. Apr 12, 2024 at 1:36 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  11. Aug 31, 2024 at 3:35 PM
    Luckster
    Luckster New Member
    '11 4.6L Dual Cab
    I went for the Ebay combo deal. A 10% coupon for auto parts Ebay has right now made it $600 after taxes for headlight and tail light. Seriously cannot beat that.
    Tails came in today. Headlights coming in a few more days.
    The tails look way better than I thought it would on the (age dulled) radiant red.
    The daytime brake lights are definitely a concern of mine with both the smoked housing and red paint. I am planning on adding the morimoto 3rd with the flasher module and a tailgate lightstrip to help mitigate some of that. For now I will be sure to not turn on my lights at all until it is well after dark.
    Before and After:
    BoysandHisToys likes this.
  12. Aug 31, 2024 at 4:13 PM
    BoysandHisToys
    Central Virginia
    Yeah, I wish they had a clear version and not just the smoke. Mine may be a little easier to see bc of my white truck, but still hard in full daylight. At dusk and night they’re bright enough.
    Luckster likes this.
  13. Aug 31, 2024 at 4:19 PM
    Luckster
    Luckster New Member
    '11 4.6L Dual Cab
    I would have gone for clear if they had it too.
    That said I have had people say they cannot see my brake lights even with the stock hallogens in the past so maybe it wont be as big of a "downgrade" in that sense as one might think it is.
  14. Aug 31, 2024 at 4:42 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    I'm honestly surprised VLAND never put out a clear lens version for their 07-13 tail lights, especially considering these were out way before the 14-21 version.
    There are 2 other versions I've come across that offer a clear lens, one by spec-d and not sure where the second originates from. They did take a different approach to the design though but they're an option for whoever wants this style of light with a clear lens.
    spec-d
    unknown manufacturer
  15. Aug 31, 2024 at 4:44 PM
    BoysandHisToys
    Central Virginia
    I might have to check these two out and if one of them is DOT approved I might switch.
  16. Aug 31, 2024 at 8:23 PM
    Shanet421
    San Diego,CA
    These say DOT certified
    https://a.co/d/0Ml7d2p
  17. Sep 4, 2024 at 9:34 PM
    Luckster
    Luckster New Member
    '11 4.6L Dual Cab
    Got the headlights in. Learned that the combo deal does NOT include the uodated sequoia headlight trim piece. Might shift the value prospect one way or another for some.
    I managed to nab an OEM pair on Ebay for $130 after shipping. I see an aftermarket listing but its just as expensive.
    So a total of ~$750 for the heads and tails if you have to buy the trim. Honestly still way better than almost anything out there.
  18. Sep 7, 2024 at 5:00 AM
    BoysandHisToys
    Central Virginia
    I tried out the “Unknown” manufacturer tail lights from Amazon this morning. They look OK to me, especially for the price. It does have some DOT number on the bottom, but it looks like not enough numbers to me. But I could be wrong.
    They are definitely brighter in the daytime with the clear lenses. But a couple of things I didn’t like.
    1. I don’t like the chrome. I de-chromed my truck so it doesn’t really go with my build. This is a personal preference.
    2. On that chrome behind the lens, there is a smudge from a handprint or something. Done during manufacturing I guess.
    3. on startup there is a light sequence that last about 16 seconds. That seems long to me as if the lights cut on while driving I would think that would confuse those behind you.
    4. The turn signal light isn’t sequential like the smoke lense ones I have now.
    5. Not sure I like the side marker on these lights. I guess that’s probably needed for the DOT approval, but it could have been done better.
    6. I did not try the backup lights but I have the VLED license plate backup lights so I’m not so concerned with that.
    In the end I’m sending these back and will try the Spec-D ones.
  19. Sep 7, 2024 at 9:37 AM
    Shanet421
    San Diego,CA
    Yes that bottom part of the light just doesn’t look right…good call
  20. Sep 20, 2024 at 1:46 PM
    #50
    BoysandHisToys
    Central Virginia
    The Spec D tail lights came in today and so far I’m impressed with the fit and finish compared to both the no name brand before and the VLAND type. I got the clear lens's with jet black.
    1. on startup there is a light sequence that last about 10 seconds vs the 16 seconds in the last set I tried.
    2. The turn signal light is sequential like the smoke lense ones I have now but it’s a smaller line of LEDs and not the main lights. Not a deal breaker and looks ok. The picture looks more yellow but it is red.
    3. The lights look much crisper then my previous set. Some due to the smoke lens but I think also due to the LEDs.
    4. Don’t have anyone else here right now to see the brake lights.
    5. They do have DOT numbers on them.
    Time will tell how they hold up.
