  1. Sep 19, 2024 at 5:47 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Here it is stuck at the Good Evening Ranch.
    Looking forward to getting the new tires mounted. I'm currently have Pitbulls mounted but they are radials.
    The TSL's are Bias ply and should be a little more sticky. Plus the sidewalls should be tougher.
  2. Sep 19, 2024 at 6:06 AM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    As much as I like doing everything myself, too many other projects and nervous about messing something up and ruining something on fluid refills...at the dealer getting trans, coolant, diff, transfer case and brake fluid drain and fill and a 4w alignment. Costing a fortune, but at 4 1/2 years, 100k miles and still looks/feels close to new, ok to give her a spa day...
    kingpin3919, BR73, Fobroader and 2 others like this.
  3. Sep 19, 2024 at 6:16 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    What's it cost? I might do this at 30k coming up, minus the alignment.
  4. Sep 19, 2024 at 6:16 AM
    Florida AF
    Logan
    North Florida
    yall get above 15????
    LOL....
    side note, i need to look into these sabm and bypass mods
  5. Sep 19, 2024 at 6:21 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    ^^yes you do! Simple, functional and worth the time doing it!
    Florida AF likes this.
  6. Sep 19, 2024 at 6:22 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I can appreciate the time problem. I have experienced the same thing at times. You just pay because your time is more valuable in other areas.
    However, there is nothing to be nervous about on these trucks. The trans is one of the easier ones. Hit the right temp and all of the guess work is gone... No dipstick to read just right or anything. Pull the screw and if it is drizzling you are good.
    Coolant on these is easy. The system burps well and if you measure what came out vs. what went in you should be good.
    The rest (diff, brakes, etc.) are easier than most.
    You can do this!
  7. Sep 19, 2024 at 6:27 AM
    It's totalling at about $1650...$450ish for trans, then everything else is $150-$250 each, as I recall. I'll give you the breakdown when I get it back. Killing me, but like I say, not well set up for it, too much to do, and the 'temperature has to be right, bypass the right pins, level surface, and if you mess up, you kill the trans' just made me say 'let them do it'...
    Major and woods[QUOTED] like this.
  8. Sep 19, 2024 at 6:30 AM
    HulkSmurf14
    2014 Tundra Limited
    Still less money than owning a GM/Ford/Ram!
  9. Sep 19, 2024 at 6:31 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I agree, might be easy with a good set up, but I am on gravel that isn't level and have limited skills. I don't feel comfortable doing them all and not messing something up. But damn! :bananadead:
  10. Sep 19, 2024 at 6:57 AM
    You said it! I do my own oil in the driveway, because the slope doesn't matter, and I'm hoping I'll have my garage cleaned out enough to pull it in, so I'd have a level surface at 150k for trans, might be willing to try it, but the way my projects are stacked up...
    We need a 'crying handing over the credit card' emoji.
  11. Sep 19, 2024 at 7:26 AM
    If I'm lucky on a good day my display will show a 15.1 or 15.2. I don't recall ever seeing it any higher than that.
    Fobroader, St2946, BR73 and 1 other person like this.
  12. Sep 19, 2024 at 7:32 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I got a new job and drive 70 miles round trip. I've been seeing 17.5
    As soon as I do a lot of town driving and/or spirited driving, i'll see 15.X all day.
    Stock setup with 275/60/20 AT's.
  13. Sep 19, 2024 at 7:33 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I'm up to 14.7 mixed moving up from 12-13 mpg with addition of Borla exhaust. I think the 60lbs K02's is the only thing holding me back from 15 mpg.
    Tripleconpanna likes this.
  14. Sep 19, 2024 at 8:25 AM
    WardenTruck
    WardenTruck New Member
    2006 OEM Tundra
    Dangerously Stock
    You must drive downhill both directions on your commute. Wizardry is afoot!
  15. Sep 19, 2024 at 9:01 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    oh man their hardware situation strikes again
  16. Sep 19, 2024 at 9:33 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Pulled her out of the garage to stretch some legs and check on the trail cam since the reservoir has been drawn down and hasn’t rained in a month.
  17. Sep 19, 2024 at 10:52 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Yeah not ideal, but not the end of the world.
    Tripleconpanna and Fobroader like this.
  18. Sep 19, 2024 at 12:30 PM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    I had both rear doors on a 2000 Grand Cherokee fail with less than 40k miles on it while our youngest son was in a baby seat. No way to open the doors when they fail, thankfully they failed a few months apart.
    Had one fail in a Honda, but never in the Tundra I had for almost 10 years.
    harrydunn[QUOTED] likes this.
  19. Sep 19, 2024 at 1:07 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Love that color.
  20. Sep 19, 2024 at 1:41 PM
    Mullen
    Mullen Desert Dude
    Corona, CA
    2001 Prerunner, 2014 DC 4wd
    I installed my GM-style tow mirrors today. I previously had Toyota tow mirrors and hated them. I went back and forth between them and the stock mirrors 5 times before I finally sold them. I hated the look and couldn’t get used to the tiny convex mirror. These GM ones seem like they’ll work much better and I like the look of them. Similar to the Toyota tow mirrors, the running lights and turn signal indicators work even though my stock mirrors had neither. For $174 delivered versus the $415 I paid for Toyota ones 8 years ago, these can’t be beat.
  21. Sep 19, 2024 at 2:28 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I have searched a few different ways and not found a thread on it, so going to ask here.
    Are there any threads on after market heated steering wheels, or even using maybe an OEM one? I found one on the website that sells the auto up/down window buttons and it looks nice. I have seen the threads on the regular leather replacements. This looks like the resolvo with heat added.
    https://cartrimhome.com/Heated-Steering-Wheel-Perforated-Leather-Toyota-4runner
  22. Sep 19, 2024 at 2:47 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Mirrors look good and how do you like the Toyota Open Country tires? What size are you running?
  23. Sep 19, 2024 at 4:28 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Definitely. :thumbsup:
  24. Sep 19, 2024 at 5:57 PM
    seydou
    seydou Distinguished Member
    Do they have BSM or heat? I assume they are still remotely adjustable.
    Fobroader likes this.
  25. Sep 19, 2024 at 9:20 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  26. Sep 19, 2024 at 9:45 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    seems that way, my commute is 53 miles one way. Will see how it does on that trip because it will include the highway. This was just a little over 11 miles mostly all backroads without much stop and go. I’m also running all stock on the wheels/tires etc.
    WardenTruck[QUOTED] likes this.
  27. Sep 19, 2024 at 10:36 PM
    Pimpala1962
    Pimpala1962 New Member
    Kyle
    Massachusetts
    2015 double cab
    Wow city driving mostly i havent seen better then 12.7 and im the factory 20s with a trd exhaust and i baby it
  28. Sep 20, 2024 at 7:58 AM
    Mullen
    Mullen Desert Dude
    Corona, CA
    They are the RT in 35x12.50-17. They work well and the wear seems acceptable. They have gotten louder with age, but performance has been consistent. I’d definitely buy them again given how I use my truck, but if I were commuting I’d go with an AT style tire instead. I have Toyo MT on my first gen desert truck and they have held up to all the abuse I put that truck through.
    The heat function still works and the big mirror is remotely adjustable. My truck doesn’t have BSM, but they claim these mirrors do have the function if your truck has it stock. Here is the link to the mirrors: https://www.ebay.com/itm/386568738689
    BR73[QUOTED] and JMGmanAZ like this.
  29. Sep 20, 2024 at 8:10 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Very tempting for the $$... I'd lose pwr fold, but rarely use it anyway.
    Mullen[QUOTED] likes this.
  30. Sep 20, 2024 at 8:30 AM
    RobertD
    Robert
    DFW, Texas
    Just remember the tow mirrors stick out further. I never folded my stock mirrors and figured I'd only occasionally fold my tow mirrors. I fold them a lot of the times I'm out and about and parking somewhere not my house or work.
    I know not everyone folds their's when they park. But I do like being able to just fold them in if I feel like the cars parking on either side will be closer than I would like.
