Headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by 2010 tundra!, Sep 3, 2024.
  1. Sep 3, 2024 at 7:51 PM
    2010 tundra!
    2010 tundra! [OP] New Member
    Mick
    2010 Toyota tundra
    Looking for good quality headlights and tail for my 2010 tundra base model. Don't want them to leak so I've been searching for a good price and a perfect fit.i know a lot of them don't line up like OEM ones.any advice for good quality and not 1000 dollars please I'm all ears? Thanks so much.
  2. Sep 4, 2024 at 4:11 AM
    @memario1214 is our lighting guy. Good quality and under $1000 for front and rear might be cutting it close but he will help you out with what will work for you. Just an FYI, he also has all kinds of goodies...wheels, suspension, etc.
  3. Sep 4, 2024 at 7:52 AM
    Dr_Al
    Dr_Al New Member
    Al
    I got a couple of sets of the cheap ones ($100ish for a pair) and it's not leaking that's an issue. One set the stock bulbs would hit the black housing when you tried to aim them. That caused the adjustment to stop working. All the lights have vent hole in the back. Neither of the cheap set leaked and I'm sure they will not last as long as the originals before they discolor. I just couldn't see spending a lot of money on headlights.
    The set that broke I pulled apart and combined parts from the OEM lights (the black rear housing and the adjusters) with the parts that needed replacing from the aftermarket ones (the lenses and the reflectors). Doing so I got to play with how the lights are built and sealed. The lenses have a butyl tape that seals them to the housing. It's very hard for that gap to leak.
    I ended up putting in universal projector lenes. You have to take the lights apart but they fit into the hole for the low beam bulb. They have a hood that electronically flips up when you turn on the high beams. The ones I got are LEDs but I've seen HID ones too. If you want bright they are like a sun. On low beam the hood cuts off the light (almost too much) so you don't blind oncoming cars. But when you turn on the high beams it's like having a giant light bar.
    If you swap out your headlights and you like to fiddle I would play around with your original headlights vs just throwing them out. After taking the OEM ones apart I removed almost all of the butyl so I could put them back together and take them apart easily so I could try out the projectors. They may not look as nice as some of the ones with DRLs but they do give the truck a more modern look. I also swapped on the 3rd brake light and I'm now looking for LED taillights that look a bit more modern.
  4. Sep 4, 2024 at 9:22 PM
    Luckster
    Luckster New Member
    '11 4.6L Dual Cab
    Vland has nice looking LED head+tail for $600 on ebay right now.
  5. Sep 5, 2024 at 9:05 PM
    Underdogg
    Underdogg New Member
    07 Crewmax 5.7L
    Are you looking to buy new aftermarket ones? If not I have a pair of used OEM fronts from my 07 I can sell. No worries if not though
  6. Sep 5, 2024 at 9:24 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  7. Sep 18, 2024 at 4:46 PM
    S0CKETMAN
    S0CKETMAN New Member
    07 Limited 4x4 CM Slate Metallic
    Save up for Morimoto xbs!
  8. Sep 18, 2024 at 5:37 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    The Alpharex Pros were under $500 and would recommend, put on my 07. They have a DRL which is nice.
    The DRL pic is weird, off-white in pic. The light is white-white..
  9. Sep 18, 2024 at 5:40 PM
    Slingsteel
    Slingsteel New Member
    2013 CM 4x4
    I just finally installed my Vlands , they have been sitting in my garage for 2 years.
    Was procrastinating because I just did not feel like painting the new grill. (Rattle can it)New lights and Grill.jpg
    2013 CM
  10. Sep 18, 2024 at 5:44 PM
    2010 tundra!
    Mick
    2010 Toyota tundra
    Thanks for the suggestions guys!
    Trooper2 likes this.
  11. Sep 18, 2024 at 6:36 PM
    S0CKETMAN
    @Slingsteel those lights look badass! Very similar to sequoia.
  12. Sep 18, 2024 at 8:47 PM
    Trooper2
    JR
    You may or may not be aware that the prongs on the filler pieces below the headlights like to break or fall apart when removing them. New ones are available but not painted.
    Two way tape is an option to secure if they break off but not a great long term solution.
    S0CKETMAN likes this.
  13. Sep 18, 2024 at 9:14 PM
    S0CKETMAN
    Yep. The prongs are easy to break! Advance with caution. Plastic pry tool helps.
