Valve cover bolts - Yes, I searched stickys first.
Discussion in '1st Gen Tundras (2000-2006)' started by fishordie, Sep 18, 2024.
  1. Sep 18, 2024 at 7:49 AM
    fishordie
    fishordie [OP] New Member
    Earl
    East Texas Piney Woods
    2002 SR5 AC 2WD 210K Grocery Getter
    Middle of Timing Belt - Possibly Cam seals
    replacing VC gasket, going to really scrub the cover, etc so the only thing that wont be new are the 22 year old bolts...does anyone know the exact size (other than just 10mm) and have you been able to find them at the hardware store? Gets kinda pricey x 18 so looking to find them on the cheap.
    Also, would it be a good idea to use a small amount of threadlock on the first couple of threads? All of mine were really loose.
  2. Sep 18, 2024 at 7:53 AM
    Don’t cheap out. This logic doesn’t compute. Don’t use hardware store bolts. Get the appropriate fasteners from Toyota. Follow the FSM as far as thread lock or no. If it requires it, the bolts will likely come with it on. I bet the answer is no due to the very low torque these require.
  3. Sep 18, 2024 at 7:55 AM
    Fobroader and jerryallday like this.
  4. Sep 18, 2024 at 7:59 AM
    fishordie
    Earl
    i hear ya.
    I always go with OEM, but I was just wondering if going with the OEM bolts was worth it here? hurts to cough it up for some small bolts that are loose =)
  5. Sep 18, 2024 at 8:00 AM
    Are your bolts ruined? As long as the grommet is in good shape, clean it all up and reuse them. Can’t recall if I reused mine or not when I did my valve cover gaskets.
  6. Sep 18, 2024 at 8:02 AM
    fishordie
    Earl
    KNABORES[QUOTED] likes this.
  7. Sep 18, 2024 at 8:03 AM
    Willing to bet by the time tax and shipping is figured in it’s a wash.
  8. Sep 18, 2024 at 8:10 AM
    fishordie
    Earl
    No, they aren't ruined but I've seen a couple of comments from people replying to a VC gasket job video or post and said "why in in the world didn't you change out the bolts when you had the chance" ??? I was hoping/wondering if some new ones would be be more secure to keep it clean. I've only been a Tundra owner for a cpl months so I really lean on others here.
  9. Sep 18, 2024 at 8:17 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Post some pics of the insides of the vc's & heads. For science.
    Jack McCarthy likes this.
  10. Sep 18, 2024 at 9:13 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    9008010330 18 $ 1.27 BOLT(FOR CYLINDER HEAD COVER)
    these are the ones I bought
    fishordie[OP] likes this.
  11. Sep 18, 2024 at 9:23 AM
    Mr Badwrench
    Mr Badwrench New Member
    They should be sort of loose. Valve covers distort easily if you tighten them too much. Don't use threadlocker.
  12. Sep 18, 2024 at 9:24 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I think its 13ft.lbs. Barely finger tight.
  13. Sep 18, 2024 at 9:46 AM
    bfunke
    bfunke Tundra Curmudgeon
    I’ve been there and bought new bolts from Toyota. The rubber gets hard, brittle and flat. You can get the rubber parts from Felpro but for the gaskets I prefer OEM.
    Fobroader, fishordie[OP] and KNABORES like this.
  14. Sep 18, 2024 at 10:02 AM
    fishordie
    Earl
    thanks
  15. Sep 18, 2024 at 10:02 AM
    fishordie
    Earl
    found them..thanks
  16. Sep 18, 2024 at 10:39 AM
    From the Megathread, all the info you need on part numbers and process, click link in red. Rather than rely on forum search, that sticky thread has a ton of keywords in it, always search that thread before you suffer the pain of the search feature.
    • Oil leaks: Two most common causes: Valve cover gaskets and cam seals - this is especially true on low-mile trucks, valve cover gaskets will shrink, harden, crack over time. If you see oil leaks reaching the oil pan, running down the dipstick support, on the heat shield flanges above the manifold, it's probably the valve covers - check the torque on the bolts first to ensure they're in spec, but be prepared to replace the valve cover gaskets and spark plug tube gaskets (see parts and process listed here). If it's leaking down the front of the block, with oil showing either side of the harmonic balancer (big center pulley) or behind the A/C compressor, it's probably your cam seals. Cam seal replacement is $$ and best done w/timing belt, however, ATP's AT-205 will rejuvenate the seals safely without over-swelling or causing collateral damage you'll need to fix later. Of course, the oil pain *does* sometimes leak, but it's pretty unusual, unless someone had it off for some reason.
  17. Sep 18, 2024 at 11:26 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Inch Pounds!!!
  18. Sep 18, 2024 at 11:49 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    *53 inch lbs
  19. Sep 18, 2024 at 12:29 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Thats WAYYY too tight.
    53 INCH LB is the spec (approx 4.2 ft lbs).
  20. Sep 18, 2024 at 4:12 PM
    bfunke
    My valve cover ratchet
    Jack McCarthy and chunk like this.
  21. Sep 18, 2024 at 4:23 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Just snug, two fingers and a thumb. No ape hands. I seldom use a torque wrench on these kinds of fasteners, it is so hard to feel the bolt snuggling up, even with a quality inch pound wrench. With new gaskets it doesn't take much to get a leak free seal.
  22. Sep 18, 2024 at 7:20 PM
    ericryder
    ericryder Nailbender
    Eric
    HILLSBOROUGH
    '04 SR5 3.4 5 speed access cab
    Head unit and door speakers aluminum ladder rack
    Three snugga-duggas
    Jack McCarthy and fishordie[OP] like this.
  23. Sep 20, 2024 at 12:38 PM
    fishordie
    Earl
    thanks for this info. As i cleaned all the old oil gunk of the dipstick i was thinking how could there be funk from the top of the stick all the way to the grommet at the bottom. Even the bracket secures the dipstick was pitch black with gunk. They are all shiny now
    thanks..i didnt think about new seals possibly getting it back to good snugness..
  24. Sep 20, 2024 at 12:39 PM
    fishordie
    Earl
    how long is that?
  25. Sep 20, 2024 at 12:41 PM
    fishordie
    Earl
    cam seals replaced..crank next. I wonder whats waiting on me behind the crank seal??? ha I hope its not sludge.
  26. Sep 20, 2024 at 12:45 PM
    Gist of it is this.
    Red dot on that blolt is, IIRC, the front/lower valve cover bolt. That's right next to the spot where you MUST clean off any FIPG and re-blot a wipe of fresh FIPG before laying the cover down. It's the only way to properly seal the right-angle corner there, and there's an identical one on the other side of the valve cover where it meets the throttle body area. Any oil seeping past that spot, if you don't re-FIPG when you reinstall your valve covers, will seep out at that corner, the dipstick support is in that spot, it travels down the support bracked, then runs down the dipstick tube, following the arrow.
  27. Sep 20, 2024 at 12:46 PM
    Make note of the big washer thingy between the crank and seal (IIRC). There's been a lot of topic on that, where it's been misinstalled. I think @Mr Badwrench is the first person I saw fess up to it.
  28. Sep 20, 2024 at 12:53 PM
    fishordie
    Earl
    this is gold info!! unanswered questions bug me to death..and I had no idea how that dang dipstick support could be covered in gunk. Got the OEM FIPG in the mail yesterday.. so just right there in the corner...get it good????
  29. Sep 20, 2024 at 12:54 PM
    fishordie
    Earl
    dude, your engine is clean.
  30. Sep 20, 2024 at 1:02 PM
    Another thing people fuck up doing valve covers is failing to pull, clear, and re-seal with FIPG for the two half-moon plugs at the back of each head, which will lead to oil leaking down the back of the block. It gets mistaken at shops as a rear main seal (RMS) leak. Oh, and here's a pic below that of the spots on the front of each head where you need to FIPG. Instructions for all this is in the FSM, which I hope you've already downloaded.
