  1. Sep 17, 2024 at 11:32 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    Same.
    CaptRussia253[QUOTED] likes this.
  2. Sep 17, 2024 at 12:52 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    We’ve got a 2017 4Runner on its 3rd battery and am on my 2nd battery in the Tundra. It’s about 3 yrs old so it has reached old age. Pure dumb luck that all of these crapped out in my driveway. So got a little insurance.
  3. Sep 17, 2024 at 1:05 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red Tundra
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    I like it but there are some things to look for on the install and use.
    1.There are 2 different wire harnesses but only one has the correct plugs depending on the year model of your truck.Mine is a 2020 SR5 . Several YouTube videos out there to help
    2.Connect the Dasaita harness to the OEM harness first then to the head unit
    3.Make sure the canbus is connected to the harness you are using
    4.If you plan on using any of the apps go ahead and plug in the sim card cable with holder for a SIM card
    5.Plug in the external mic and find a location to your liking to place it
    6.After installation and you start setting up the unit make sure to raise the volumes in the factory settings for the mic and radio
    7.Make sure to use US2 for the geographic location.My radio wouldn't work on US1in factory settings
    8.I located the GPS antenna and 4G antenna under the dash and it works fine
    The unit looks OEM and it takes a little time to get things figured out but it's worth it so far PXL_20240901_013547856.jpg
  4. Sep 17, 2024 at 1:27 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Man, you guys need to put your battery on battery tenders…
  5. Sep 17, 2024 at 1:46 PM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    My wife has a work truck so her GX460 doesn't get a lot of use, it lives on a battery tender. 3 years, no problem.
  6. Sep 17, 2024 at 2:12 PM
    jeffw6236
    Jeff
    San Antonio
    I think it’s just the heat - also a couple of those were the original Toyota batteries
    BR73 and koditten like this.
  7. Sep 17, 2024 at 2:23 PM
    koditten
    Kirk
    Midland of the Mitten
    I agree. We are told to watch our oil and coolant levels, but no one checks their electrolyte in the battery.
    I think manufacturers want to reduce risk of getting battery acid in your eyes, so not much emphasis is spent on that check.
    Interesting fact:
    Many bottled waters are as pure as distilled water. That bottled water can be used to top off the battery.
    French Avocado, WFD473 and bulldog93 like this.
  8. Sep 17, 2024 at 2:59 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Put in the air intake accelerator yesterday. Could tell during my commute it felt a little more snappier, which could just be me, but I’m happy. IMG_4563.jpg
  9. Sep 17, 2024 at 3:23 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    And you’re right lol
    French Avocado likes this.
  10. Sep 17, 2024 at 4:28 PM
    Rgross2112
    Rush
    I’ve never seen 20.5 mpg usually it’s 18.3 will see how it is on a longer trip.
  11. Sep 17, 2024 at 4:48 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
  12. Sep 17, 2024 at 5:11 PM
    Hell...I've never even seen 17, much less 20.
  13. Sep 17, 2024 at 5:29 PM
    koditten
    Kirk
    I seent 17 once.
    bulldog93 likes this.
  14. Sep 17, 2024 at 8:23 PM
    centex
    centex New Member
    Psssh. Best I’ve seen is 14 and usually 12.2. If I didn’t have deer I’d ditch these bumpers.
    Rgross2112 and bulldog93 like this.
  15. Sep 17, 2024 at 8:31 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I haven’t paid much attention to my MPG, but I know I’ve been sitting around 11-12. 10 if I get too happy with the exhaust, Stillen, and accelerator :rofl:
  16. Sep 17, 2024 at 8:38 PM
    DrRansom
    DrRansom New Member
    Utah
    Silver Sky 2021 SR5 Tundra 4WD
    Tonneau covers are one of my least favorite modifications to a truck. I went through multiple on my Tacoma. Unfortunately, that experience taught me that the quality of many covers is declining due to industry consolidation (Realtruck basically owns everything now). I've therefore decided that at the high prices these things command, it's best to either:
    (1) Go all in on a cap or something like a Diamondback
    (2) Buy a cheap roll up from Amazon
    (3) Find something used
    In this case, I went with option (3). I found an Ultraflex tonneau for ~$300 on Facebook marketplace. It's a bit worn, but I appreciate the slightly better security a hard trifold offers.
    I was surprised that the cover doesn't lean against the cab like the Bakflip models. I think I like this solution better.
    This cover leaves the OEM rails in place and so the moveable tie downs are incompatible with it. I'll probably pick up something like the billet tie down system at some point.
    In all, I can't complain too much for what I paid for the cover. I do believe the solid trifolds are too expensive for what they offer these days - if you're in the market, buy used! Long term I'll probably pick up a Diamondback or a Retrax, but this will work for now.
    Tonneau cover: installed
  17. Sep 17, 2024 at 8:51 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    That only works on limited trim and above though.
    Bergy24 likes this.
  18. Sep 17, 2024 at 8:54 PM
    RobertD
    Robert
    DFW, Texas
  19. Sep 17, 2024 at 10:40 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Put um in 2016 SR5, drivers and passengers side, work great
    bulldog93 and BR73 like this.
  20. Sep 18, 2024 at 3:26 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    :thumbsup:
    Have the same exact one. Does the job well in my opinion
    BR73 and DrRansom[QUOTED] like this.
  21. Sep 18, 2024 at 7:58 AM
    Cthulhu
    I am SO GLAD you posted an awesome picture of which hose to use for the bypass. As soon as I saw the wire loom on your bypass hose I knew you used the shorter hose; I used the longer hose with no wire loom and I had to tuck the extra hose up underneath the throttle body so it wouldn't hit the fan. I just now swapped the long hose out for the shorter, wire-loomed hose (took about 5 minutes, I didn't have to remove the throttle body since I have some long needle-nose pliers, and luckily the hose clamps were facing upwards :thumbsup:), and it's a perfect fit. Thanks again!
    :hattip:
  22. Sep 18, 2024 at 8:01 AM
    IsaiahCanada
    Isaiah
    Calgary, Alberta
    Awesome, thank you
    RobertD[QUOTED] likes this.
  23. Sep 18, 2024 at 8:29 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Yeah that hose seemed to have the right length and shape.I removed my TB and cleaned it and cut out the screen :yes:
  24. Sep 18, 2024 at 11:17 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Got a new set of tires today..... for the Jeep.
    The Tundra would look great with them. But it would require a ton of $$$$ to fit 38.5 x 14.5 tires on it. Plus the Jeep only has 15" wheels so there will be no swapping them around.
  25. Sep 18, 2024 at 12:19 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Love those tires. Had a set of 38's that I grooved on my rock crawler, until I went with a set of bfg reds.
    Tripleconpanna likes this.
  26. Sep 18, 2024 at 5:51 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Got and installed my RCI High Lift mounts. Of course then sent me the wrong hardware, so after a quick Home Depot trip we’re back in business
  27. Sep 18, 2024 at 5:54 PM
    harrydunn
    harrydunn New Member
    Columbia, MO
    Because I was inverted.
    Call it, Friendo.
    Replaced the rear drivers side door lock actuator motor. I've got a warranty but I despise dealers so I bought the motor for $11 and did it myself. I've done several before on some of my Land Cruisers so had a bit of a head start.
  28. Sep 18, 2024 at 7:35 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Took her to Pismo beach with the pup to test out the new rear King shocks. I was able to be at full speed most of the time and everything was smooth as butter (I may have been airborne once or twice). Got her home and after a Turtle Wax spray wax, she got a Beadmaker treatment.
  29. Sep 18, 2024 at 9:15 PM
    DrRansom
    DrRansom New Member
    Utah
    Nice. Would love to see your Jeep sometime
  30. Sep 19, 2024 at 3:42 AM
    LuvMy21DC
    LuvMy21DC New Member
    Central Florida
    2021 White Double Cab SR5 SX 5.7 4x4
    TonnoPro Hard Fold Raptor SSR running boards
    Nice! Like the low profile. Do you have a link to that camera on Amazon?
