Do you ever meet LBJ non-believers?
Discussion in '1st Gen Tundras (2000-2006)' started by Bought2Pull, Sep 12, 2024.
  1. Sep 16, 2024 at 4:18 PM
    Mullen
    Mullen Desert Dude
    Corona, CA
    2001 Prerunner, 2014 DC 4wd
    I’m a non-believer fellas. Over 6 years on Moog LBJ on my desert truck with zero issues. LBJ are still tight today. I do a nut, bolt, and torque check before and after desert trip (LBJ checks are part of that list) and a full prep before every desert season. While my truck may not collect a ton of miles, those that it does are hard as hell.
    My truck is full long travel, full cage, well prepped, and my shocks are well valved. Maybe that has something to do with it or maybe I’m destined for failure. I live like Austin Powers.
    zingvs and whodatschrome like this.
  2. Sep 16, 2024 at 4:36 PM
    Pretty sure @KNABORES was in same boat, same brand. And his showed no signs of imminent fail until they had no load (like, taken off), then he found major play, like, “fuck I’m shocked those didn’t fail” level of play.
    Seems (based on the massive federal recall Moog had to do on LBJ for our truck) Moog contracts with different factories to make their parts, they don’t manufacture anything for our trucks themselves anymore. So you’re at the mercy of batch quality and which mainland china factory knocked them out. The one constant seems to be, whoever they’re using lately, ever since the massive recall, they’re using nylon internals where Toyota/OEM uses brass/metal. Brass bushings, metal springs. Maybe you got lucky and got a pre-recall batch made at a factory that was also using metal internals vs. nylon?
    Weagle likes this.
  3. Sep 16, 2024 at 8:19 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I see non believers on the Facebook groups everyday.
    LBJ will total these precious 1st Gens.
    My OEM LBJ’s have 105k on them in 4 years. They are very loose and easy to move around. They don’t show any signs of clunking, but are very loose. When my Solo Motorsports LCA’s come in I’m swapping some new OEM’s in.
    BroHon and shifty` like this.
  4. Sep 17, 2024 at 6:19 AM
    SHUUUUN CHARLEY SHUUUUUUUUUUUUUUNNNNNNNNNN
    Diablo169[QUOTED] likes this.
  5. Sep 17, 2024 at 6:33 AM
    Been there. Ignorance is bliss, till your truck crashes down onto its own fender and front door sheet metal and tears your front end bits apart with it. $100 part causing $3-4000 in damage. My moogs felt fine on the truck. When removed to replace the passenger side barely stayed in the socket it had so much play and knocked around. That video where the guy cuts the joint apart says it all. Aftermarket LBJs are designed like traditional ones are, and usually use nylon cups. Toyota OEM are a different animal. All metal construction with a spring tension cup.
    Weagle, G_unit3000 and BroHon like this.
  6. Sep 17, 2024 at 6:41 AM
    Weagle, G_unit3000, BroHon and 2 others like this.
  7. Sep 17, 2024 at 9:05 AM
    Mullen
    Mullen Desert Dude
    Corona, CA
    As I mentioned, I prep my truck often. I don’t go years driving it without a care and am far from ignorant. I bet I spend as much time prepping my truck as I do driving it. My full prep includes removal of all suspension, new nuts and bolts throughout, and much more done every year.
    Six years driving the truck harder than most, on 35” tires and being significantly heavier than stock, tells me maybe I got a lucky pair of Moog or maybe my prep pays off or maybe the LBJ problem lies with the stock suspension geometry. FWIW, when I build a new front end it will have upper and lower uniballs, but that’s common for long travel anyways.
    In summary - everyone should long travel their truck.:yes:
    zingvs, FishNinja, Dustbox and 2 others like this.
  8. Sep 17, 2024 at 9:13 AM
    What happens when Toyota discontinues their LBJs? Are we all screwed? Time to roll it off the cliff?
    BroHon likes this.
  9. Sep 17, 2024 at 9:15 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    We make a big F'n deal about it. Tell the news.
  10. Sep 17, 2024 at 8:10 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Cost benefit analysis.
  11. Sep 17, 2024 at 8:20 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    solid axle swap
  12. Sep 17, 2024 at 8:45 PM
    Not a cheap solution. Might as well change to long travel while I’m at it.
    G_unit3000 likes this.
  13. Sep 17, 2024 at 8:46 PM
    From what? A T100?
  14. Sep 17, 2024 at 9:26 PM
    Bought2Pull
    Bought2Pull [OP] New Member
    Greg
    WV
    2006 Tundra 4 door
    I'm a landscaper....I speak English.
    Good question...probably not a bad idea to buy a couple extra sets for "later."
  15. Sep 17, 2024 at 9:31 PM
    whodatschrome
    lots of dents
    I dunno. There’s so little documentation about 1st gen SAS. Sure, there are a few SAS builds online that have tall lifts and huge tires. But i’m more interested in a very mild lift (2~3”) and maybe a 32” tire. It’s MUCH easier to package custom suspension and steering in a tall lift. I would think it could all be done for $4k in one’s own shop?
    I assume a low pinion D44 front axle (i dunno if a D44 HP would fit with just a mild lift). Some sort of steering box (Toyota IFS?). Crossover steering. Leaf springs for simplicity and durability, or expensive go fast long travel coilovers for slowver landing.
  16. Sep 18, 2024 at 8:01 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    i trust oem, and thats what Ive been running on my 4runner. no paperwork on this tundra but all feels tight. Will replace hopefully soon for peace of mind. But aside from that , if you find the right on line dealer you can often get OEM for near same price as quality aftermarket. like 555 brand,
    but then again rock auto sells moogs for like 39 bucks
    I also find it interesting that the lower ball joint is the same as for my 2000 4runner, which weighs a lot less, interesting to me that toyota used them on both rigs....over built for one or underbuilt for other ?
  17. Sep 18, 2024 at 8:28 AM
    Around here you need to be bilingual to speak to the crew.
  18. Sep 18, 2024 at 8:32 AM
    Is the 555 brand a viable alternative? Has anyone destructively taken them apart to see if the joint is all metal and not plastic like Moog?
  19. Sep 18, 2024 at 10:33 AM
    I always thought Sankei 555 was OEM equivalent, but someone on here recently made a claim they saw one opened up and it used nylon retainers or seats (where Toyota uses a steel spring to cup the ball-end of the spindle).
    Don't get me wrong, if I have a choice between a steel bushing and a nylon seat over a nylon bushing with a nylon seat, I'll go with the partial-metal part over the full-nylon part any day. but I prefer metal internals.
    I did pass over a post on one of the FB groups today where someone had their non-OEM LBJ pointed out and the OP on the post was something to the effect of, like, "Yeah well I saw a video on YouTube that showed a Toyota LBJ being pulled apart and it had plastic too". No proof given, though.
  20. Sep 18, 2024 at 3:25 PM
    #50
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I wouldn't hire such crew.
    Dook55 and Jack McCarthy[QUOTED] like this.
  21. Sep 18, 2024 at 4:01 PM
    #51
    I often do. They always ask for less money, and almost always do better work.
    Roblit, Leo's first, Weagle and 3 others like this.
  22. Oct 17, 2024 at 12:31 PM
    #52
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    This linked video by 208Tyler shows cut away cross sections of Sankei 555 and OEM LBJs. Starts at about 8:20 of the video:
    https://youtu.be/TCzcKfUyfcM?si=GUXcfxfq7rIuwX7G
    Jack McCarthy, BroHon and Riverdale21 like this.
  23. Oct 17, 2024 at 12:50 PM
    #53
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Anybody have review for lower uniball set-up?
  24. Oct 17, 2024 at 12:56 PM
    #54
    I haven’t heard of anyone on here complain but that’s typically the long travel suspension crowd or group due to the cost.
  25. Oct 17, 2024 at 4:39 PM
    #55
    BluegrapeVr6
    J
    Regardless, thats one sweet truck you have there.
    Link to build?
  26. Oct 18, 2024 at 12:58 AM
    #56
  27. Oct 18, 2024 at 7:26 AM
    #57
    Mullen
    Mullen Desert Dude
    Corona, CA
    Thanks. The build thread is in progress, hopefully I’ll get it posted here next week.
    BluegrapeVr6[QUOTED] likes this.
  28. Nov 7, 2024 at 5:34 AM
    #58
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Indeed. I should have taken a side by side shot when I had the old ones out, but I don't regret changing them. OEM or DIE.
  29. Nov 8, 2024 at 1:37 AM
    #59
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I have mine out now, might take you guys some pics before I toss them into the steel pile. (I end up with a fair amount of steel with what I do....all that goes to the junk yard for what little cents on the pound it's worth).
  30. Nov 12, 2024 at 3:34 AM
    #60
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I had no idea about the LBJ's until I joined this forum a little over a year ago with just over 300,000 miles on the odometer. I guess I was lucky. Mine did not have any obvious play
    but now that I know I've warned 2 1st Gen owners and friends that are somewhere around 250,000 miles. They just seemed to shrug it off with indifference
    I'm still working on them. I need to text them pictures of failures. Maybe that will get their attention
    they are both like me, however, and not off roaders. so in general I'm guessing ours are not treated as harshly and last longer Whatever the case, I will be replacing mine around 100,000 miles next time or if and when I have to replace control arms/bushings
