  1. Sep 14, 2024 at 2:26 PM
    The forward portion of both inner fender liners was hanging loose. Used a zip tie to pull them back against the brackets behind them. Rubbing resolved.
    FrenchToasty and shifty`[QUOTED] like this.
  2. Sep 14, 2024 at 3:21 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Ready to traverse a raging river. Bring on more rust!
    FluidFilm rebuild
  3. Sep 14, 2024 at 6:00 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I wish there was an easy way to save posts for later
    oscardog86 likes this.
  4. Sep 14, 2024 at 7:39 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
  5. Sep 14, 2024 at 8:04 PM
    WTHamIdoing
    WTHamIdoing New Member
    Eric
    2001 tundra v8(2uzfe) auto extended cab
    Killmat entire cab Method 703 wheels King 2.5 coilovers w/ 700lb springs JBA UCA Coastal Off Road high clearance front/rear bumpers and sliders Dirty Deeds 250cc 12 hole fuel injectors
    https://imgur.com/a/H1IsDo5
    Got dirty deeds 12 hole injectors and tried to install them. was easy enough to get to the fuel rails and I cleaned the seats but once I went to turn on the truck they were spraying all over. Any idea what I did wrong? I'm going to tear everything down and redo it again tomorrow during daylight.
  6. Sep 14, 2024 at 8:11 PM
    Did you soak them in gas before you installed? Supposedly the seals on the tips need some lube, the gas helps them slide in nice and easy
  7. Sep 14, 2024 at 8:13 PM
    WTHamIdoing
    Eric
    I did not soak them in gas because they seemed to slide around pretty good as they came. I just got them yesterday and DD states that they are pre prepared but soaking them is on the list for the reinstall tomorrow. Some of them aren't spitting like this but about 4/8 are.
  8. Sep 14, 2024 at 11:44 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Any chance the old ones left an o-ring behind ?
    make sure all the old o-rings are accounted for
    bmf4069, FirstGenVol, BroHon and 2 others like this.
  9. Sep 15, 2024 at 12:07 AM
    WTHamIdoing
    Eric
    Oh thats a good idea! im glad i kept the old ones lol. so i am going to soak them in gas or coat in oil according to some youtubes and seat the grommets before installing the fuel rail back and check those o-rings.
  10. Sep 15, 2024 at 12:09 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So did I miss you show us what it looks like on your truck? Grill I mean. However tires and wheels too, why not?
  11. Sep 15, 2024 at 12:14 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    These o-rings like to stay behind
  12. Sep 15, 2024 at 12:29 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Bookmark them in the browser in folders under various topics.
  13. Sep 15, 2024 at 4:24 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Install CutePDF Writer on your computer. When you have a page you want to save click on File, Print, and select CutePDF as the printer. It will print the entire page to your harddrive as a PDF file that you can open and view anytime.
  14. Sep 15, 2024 at 6:33 AM
    I miss my white letters already
    bmf4069, BroHon and Sirfive like this.
  15. Sep 15, 2024 at 7:15 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    you can get paint & stencils to make your tires say whatever you want.
  16. Sep 15, 2024 at 7:53 AM
    That's what I do ^^
    I have a favorites folder in Chrome with truck stuff and save the hotlink to the reply there and title it something worthwhile.
    Still sitting on my floor in the garage. I'll get to it. Life's been a little overloaded lately. Doing a ton of stuff to the house at the moment.
  17. Sep 15, 2024 at 8:15 AM
    Thought about getting the paint pen for the letters, but the letters on these are quite large. Not sure I would like it
  18. Sep 15, 2024 at 8:35 AM
    Methodical
    Methodical New Member
    Maryland
    2006 Tundra SR5 DC TRD 4x4
    Thanks for the info and video. I was going to remove and inspect under there since I just bought the truck. I will definitely polish and wax under there.
    Forgot. The bedliner is a Toyota liner.
  19. Sep 15, 2024 at 8:43 AM
    Methodical
    Maryland
    I've used tune up grease on the seals when I've replaced a fuel injector. Always use some sort of lube on rubber seals before installation...always. Oh, and antiseize on bolts, especially bolts underneath the vehicle.
  20. Sep 15, 2024 at 8:47 AM
    Interesting…
    1. Install 12 hole injectors
    2. Let engine catch on fire burning truck to ground :bananadead:
    3. Collect insurance money
    4. Buy new truck :bananadance:
    Seems like a solid plan to me. :thumbsup:
  21. Sep 15, 2024 at 9:59 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Buy a new old truck. New trucks are garbage.
  22. Sep 15, 2024 at 11:36 AM
    WTHamIdoing
    Eric
    There are those fat o-rings and the smaller ones that go into the fuel rail. I confirmed with old injectors all of their parts are still with them!
    Took out the whole fuel rail, cleaned the shit out of the o-ring seats, lubed and reseated making sure to do it as well as possible, reinstalled everything very carefully and the same problem is still happening. I also inspected the o-rings to see if I damaged anything on the first go round and everything looks good, no cracks / damage to the integrity of the rubber.
    On a brighter note.... kings and jba UCA's are in!
  23. Sep 15, 2024 at 11:49 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    in my experience the paint pens suck! The rubber stickers are way better, but pricey if I remember correctly. Also they discolor extremely easily.
  24. Sep 15, 2024 at 2:48 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Replaced rear diff and t-case fluid, engine oil change. Made sure rear diff breather was clear. Got stymied by the front diff drain plug, but in a rare show of restraint, I stopped what I was doing before completely destroying the hex plug. Before I get out cold chisels and hammers, I should make sure I have a replacement on hand...I ordered the Lexus part to avoid this the next time. The fill plug cracked open no problem, but not the drain.
    Sometimes hard to trust Carfax. It reports what the auto shop reports, and a couple times now I've found they haven't reported everything, or used terms that were unclear. Carfax says the last time my front diff and t-case fluids were replaced was around 92,000 miles, but the fluid that came out of the t-case looked brand new. Still want to get to the front before long, just so I know for sure when everything was last replaced.
    Now I just need to do a few cycles of drain/fill on the transmission, and I'll be all caught up on most maintenance items. Need to inspect the brakes before long, but otherwise I think I'm up to date on more or less everything.
    bmf4069 and BroHon like this.
  25. Sep 15, 2024 at 3:21 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Hopefully you can get your injector issues figured out soon, because I need to know how those kings ride. I've been highly considering them for a while but been scared to bite the bullet. That's a big chunk of change to spend for "it'll probably ride better".
    Hopefully Shifty gets the time to install his Bilstein 6112s soon. Been thinking about either King 2.5s or 6112s for a while now.
  26. Sep 15, 2024 at 3:26 PM
    WTHamIdoing
    Eric
    I had kings on my tacoma and I rode that thing HARD. I went total chaos uca and king 2.5. the total chaos got squeaky but the kings were good for taking me anywhere I wanted to go however fast I wanted to get there. I think for the majority of people bilsteins would probably suffice. Think about it, king is a racing brand....
  27. Sep 15, 2024 at 3:32 PM
    FiatRunner
    Jack
    Yeah, I've talked to some people who say that their Kings have rode really rough, and others who say that they're super smooth. What springs do you have, the 650s or 700s? My thought is that with the 650lb springs and a low height setting, it would ride better than my Bilstein 4600s do.
    My interest in the Kings is mostly due to the fact that they're progressively tuned. I really want a progressive shock, and the Kings seem to be the cheapest ones. Pretty much everything for our trucks is DIgressively tuned until you get to Kings/Foxes/ADS/etc.
  28. Sep 15, 2024 at 4:37 PM
    Every time I’ve ever replaced my transfer case and front diff fluids, they’ve always looked brand new. Even at over 100k miles.
    oscardog86 and FirstGenVol like this.
  29. Sep 15, 2024 at 5:26 PM
    FiatRunner
    Jack
    Same here. I changed my Tcase and front diff fluid for the truck's first time at 200k. I almost didn't change them after seeing how clean they were.
  30. Sep 15, 2024 at 6:05 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Iv seen guys running kings with a bypass on their 1gen in the front end. But I haven’t been able to find a model number for them.
