4hi won’t lock in
Discussion in '1st Gen Tundras (2000-2006)' started by Broken4\4, Sep 3, 2024.
  1. Sep 3, 2024 at 5:39 PM
    Broken4\4
    Broken4\4 [OP] New Member
    Isaac
    2006 tundra 4.7 double cab
    When ever I go to put my tundra in 4 high it just blinks and doesn’t go in but if I turn the truck off while 4hi is blinking and than turn truck back on it’ll lock into 4 lo ?
    I can only here the tcase actuator wen trying to put it in 4 high
  2. Sep 3, 2024 at 5:54 PM
    From the community megathread...
    • If you're reading this because your 4WD isn't working and you need help, check THIS REPLY for some helpful troubleshooting steps to take.
