  1. Aug 30, 2024 at 7:00 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    If that's what was in the first gen TRD Tacomas, they seem good. I rarely, rarely used mine. Years would go by without using it. Not sure if that's better or worse for it, but I assumed worse. Kind of like putting our trucks in 4wd now and then to keep things lubed and working. Anyway, locker always worked when I needed. Worked the day I sold it when I tested it out during the test drive. That was a 98, so 26 years later, still working great.
    oscardog86 likes this.
  2. Aug 30, 2024 at 7:08 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Eaton doesn't make the stock Toyota e-lockers. The Eaton are a little different than the factory Toyota e-lockers, their engagement operation method is a little bit different.
  3. Aug 30, 2024 at 7:46 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    https://www.carthrottle.com/news/what-scrub-radius-and-why-it-important
    Here’s a quick read on scrub radius. I did take a stick to my front end to see what mine was earlier this week. My setup puts my scrub within the first 2” of the contact patch on the inside of the tire, but I really don’t care cause it looks good lol. 17x9.5 -32 (4” backspacing). It’s so aggressive i could damn near replace the LBJ without pulling off the wheel.
    oscardog86, FishNinja and KNABORES like this.
  4. Aug 30, 2024 at 10:13 AM
    :( Damn...
  5. Aug 30, 2024 at 12:59 PM
    Put away tools for the day. At first I was not impressed with the Diablo blades I had, burned thru 4 of them without even making it thru one cam bolt(front driver was seized)
    Went to the hardware store and got 50$ worth of other ones along with some temp nuts for my cam bolts. Maybe the carbide ones are better?
    Got the arms out and started flattening the cam tabs with a grinder. The instructions say to remove entire cam tab plate……… but on the rears it’s part of the frame, so I opted to just grind down the tabs; we will see if that bites me in the ass later. Everything is pretty much ready for welding except the back rears because the rack is blocking my grinder getting in there to take the tabs down.
    IMG_7016.jpgGetting help pulling the skid
    front of the rear cam tab plate, see how it blends in with the rest of the frame further down in one pieceIMG_7019.jpg blue tooth LCAIMG_7020.jpg IMG_7021.jpgone for the hand manIMG_7023.jpgback of rear, same sandwich design with the cam tabs that integrate further into the frame with no breaks.
    i should have arms mounted by tomorrow but no where near done
  6. Aug 30, 2024 at 1:22 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    A bajillion times.
    I've seen the cam tabs both removed and ground flat. I like the idea of having the extra thiccness to clamp against.
    nice work!:thumbsup:
  7. Aug 30, 2024 at 1:26 PM
    Hahah I never used them before or bought them, so I guess I didn’t get the good Ones the first time, the one that did cut thru is still probably good for 6 more cam bolts!!!
    yeah I didn’t want to cut into the inter grated cross member trying to remove two stupid tabs, and I agree with the more material sentiment. And for the most part it just makes things easier on my end with labor.
    Hahah you do this shit everyday, I’m pooped!!!
    JakeJake[QUOTED] likes this.
  8. Aug 30, 2024 at 1:52 PM
    Went out for informal job interview. Discount Tire was in the same parking lot, so I took it as kismet, finally got this done. And I tossed the TRD logo on the sports grille.
  9. Aug 30, 2024 at 1:57 PM
    JakeJake
    2000 Tundra AC 4X4
    Looks killer!
  10. Aug 30, 2024 at 5:08 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    You doing solos too?
  11. Aug 30, 2024 at 6:56 PM
    des2mtn
    SW
    Tonto cover
    Looks like my Magnaflow cat is done, two new O2 sensors did not change a thing. Ordered a Walker plug-and-play from RA to hopefully get through emissions.
  12. Aug 30, 2024 at 7:21 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I got some Hercules blades from HF wayyyyy better. I smoked 2 blades cutting the driver side bedside when I did all that trimming.
    des2mtn and FrenchToasty[QUOTED] like this.
  13. Aug 31, 2024 at 5:44 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    These are the blades you want:
    https://www.diablotools.com/products/DS0608CF
    ToyotaDude likes this.
  14. Aug 31, 2024 at 8:15 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    These are 17x9 -10mm bs for anyone interested in poke
  15. Aug 31, 2024 at 8:16 AM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    Also I drove from Houston to New Orleans last night and saw 10 fgts! That seemed like alot
  16. Aug 31, 2024 at 8:17 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Man you're all over the place lately.
    KTM_AJ421[QUOTED] likes this.
  17. Aug 31, 2024 at 8:43 AM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    did toy lex get you sorted out? Wife’s bday this weekend so we took a quick trip
  18. Aug 31, 2024 at 8:55 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    I wonder how well it really holds up, was thinking of doing my rocker panels with it, not rusty but pretty beat up from off road
  19. Aug 31, 2024 at 8:57 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    hope you and if any passengers are ok
  20. Aug 31, 2024 at 9:00 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Used traditional "undercoating" (looks similar) on underside of fj40 fenders after properly prepping (sandblasting IIRC) and first covering in epoxy. Think it's been about 20 years and holding up fine.
  21. Aug 31, 2024 at 9:42 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I don't expect to hear back from Juan for like a week maybe more. He said he had 8 vehicles ahead of me.
  22. Aug 31, 2024 at 10:14 AM
    I swore we had a wheel fitment thread on here, but hell if I can find it. I was going to tell you to post this over there.
  23. Aug 31, 2024 at 11:16 AM
    Waiting till Monday when the neighboring Karens leave so I can do some truck work and not get reported to the HOA.
  24. Aug 31, 2024 at 11:19 AM
    It’s Labor Day, they will all be home watching you
  25. Aug 31, 2024 at 11:33 AM
    Duh. :facepalm:I meant Tuesday.
  26. Aug 31, 2024 at 6:07 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Did the normal 5000 mile oil and filter change, rotated the tires, greased the driveline. Also installed LED bulbs in the instrument cluster. What a difference! The one thing I wasn't happy about seeing was some grease starting to pooch out of the intact cups on the LBJs. They were replaced (and documented) by Toyota in the recall campaign in 2006, and 63,000 miles ago. I guess this is the beginning of the end for these LBJs? No play in them. I was thinking about ordering them (OEM) and having them on hand to replace in 5000 miles at 100,000. What do you all think?
  27. Sep 1, 2024 at 12:22 AM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    IMG_3608.jpg Swapping the bumpers and plastics over because the bumper on the white truck has a slight bulge on top that the plastic won’t sit flat on. I’m really going to miss this gold one when I finally sell it. No rust anywhere. Bolts are still chrome 20 years later
    oscardog86, bmf4069, des2mtn and 3 others like this.
  28. Sep 1, 2024 at 10:43 AM
    MT-Tundra
    Montana
    Bank 1 O2 sensors.
    Front was surprisingly not so bad. Except somehow my O2 sensor socket shrunk and the 3/8" ratchet wouldn't fit in the hole..? Very strange. So that held things up overnight, but I bought a new one and it worked great.
    And the back...well, one nut was no problem. Other was a lot of problems. But with a lot of hammering & cold chisel it finally budged without even damaging the stud threads or needing to cut everything off.
    Will connect the battery in a couple minutes here and see if the check engine light comes back on.
  29. Sep 1, 2024 at 10:44 AM
    MT-Tundra
    Montana
    My plastic cover is raised up, too. It annoyed me more at first, but I've gotten used to it, more or less. Or other things are more concerning for now.
    Bed Tundy[QUOTED] likes this.
  30. Sep 1, 2024 at 12:12 PM
    IMG_7032.jpg IMG_7033.jpgKachow!!! Solo Arms are 90% done, got toe as close as I could with my peepers. Tomorrow I just gotta tighten up the cam bolts and I’m done!
