Pinned Trans Thermostat observations
Discussion in '2.5 Gen Tundras (2014-2021)' started by nobodyintexas, Feb 19, 2024.
  1. Jun 16, 2024 at 5:58 PM
    #61
    centex
    centex New Member
    Towed the rzr in 97* heat. 70mph in s5 through the hill country. Saw 206* in the pan. Unpinned.
    bucketlintels02 likes this.
  2. Jun 16, 2024 at 6:11 PM
    #62
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    My 2021 is usually 220 degrees plus or minus 10 driving on the flat freeway. Supercharged with 35s no trans cooler. With my rebuilt transmission I am going pinned, trans cooler and 20 degree lower engine thermostat too. Will be curious what the results are.
    nobodyintexas[OP] and Mdl like this.
  3. Jun 16, 2024 at 6:18 PM
    #63
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I asked if 150-170 was OK as that was where my temps were at over the winter. He mentioned not to be fixated on pan temp and pay attention to torque converter temps.
  4. Jun 16, 2024 at 6:34 PM
    #64
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    It stands to reason at least that if the fluid in the pan is cooler before entering the TC that it will also be cooler at/leaving the TC though, no?
  5. Jun 16, 2024 at 6:40 PM
    #65
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yes. I don't know if he gets a lot of questions concerning pan temperatures but kinda laughed when I asked what's a good temp to shoot for. Too many variables I guess just don't cook the oil.
    Silver17 likes this.
  6. Jun 17, 2024 at 3:33 AM
    #66
    nobodyintexas
    nobodyintexas [OP] What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    yes, this.
    I would rather have cooler fluid entering the TC, than hot fluid.
    Hot = >195degrees.
    pinned, I send ~170 degree fluid into the TC....all you unpinned fellas are sending ~200 degree fluid to your TC.
    and, as mentioned before, I would prefer to have AVG 175degree fluid, than AVG 200degree fluid.
    why? cooler is better. hotter is worser.
    Now, does it matter? yes. Heat, as for back as the antiquity days of Transmissions, has ALWAYS been the enemy.
    We still use multiple flimsy friction plates. keeping all those plates as cool as possible is the key.
    is it OK to run unpinned & see 210degrees on flat unladen roads?
    probably, but why do that when all you have to do is bend a damn paperclip and pin your trans open and see 170degrees.
    and for all the contrarians that are going to comment on the fluid being too cold....impossible.
    the puck heats the damn fluid.
    mine gets to 120 in about 5 minutes. 160 in 15 minutes.
    and when is the last time you watched your trans fluid heat up & then compared it to an pinned application? who would do that?
    for the record...it was 98 ambient in Montgomery TX this weekend. hwy cruise was at 173 degrees. S&G traffic was 185 degrees.
    way back - I predicted I would top out at 185 on hwy. reality = 173
  7. Jun 17, 2024 at 3:50 AM
    #67
    Silver17
    Eastern PA
    The whole TC aspect of the conversation also blows another gaping hole in the cold fluid causes condensation argument. Sure in the pan it may be 180, but the fluid still reaches well in excess of 200 in the TC rather frequently.
    Mdl and nobodyintexas[OP] like this.
  8. Jun 17, 2024 at 8:02 AM
    #68
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's another question I asked and ipt responded, what condensation from where? I'm just repeating his reply.
  9. Jun 17, 2024 at 9:15 AM
    #69
    JaxJacket
    JaxJacket New Member
    21 DC
    Was this changed for 21? I don't see anything like this near my puck. Coolant enters and exits nipples attached to the puck.
  10. Jun 17, 2024 at 9:49 AM
    #70
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I know some may have only the warming/cooling puck. I haven't seen if it's a tow pkg deal or certain areas.
    @Ponderosa_Pine any insight?
  11. Jun 17, 2024 at 10:45 AM
    #71
    AZBoatHauler
    So.Arizona
    Only trucks through 2018 can be pinned open. 2019-2021 don’t have a cooler or thermostat to pin.
    Some of the early trucks won’t have a cooler if they didn’t come with the tow package. Most do.
    Mdl likes this.
  12. Jun 17, 2024 at 11:25 AM
    #72
    JaxJacket
    21 DC
    Thanks. I was a little confused. Some one up thread with a 2020 in their profile was talking about pinning their thermostat.
    AZBoatHauler[QUOTED] likes this.
  13. Jun 17, 2024 at 11:37 AM
    #73
    AZBoatHauler
    So.Arizona
    They probably added a cooler. You can piece together a system using the older thermostat and adding a cooler and lines.
    Mdl likes this.
  14. Jun 17, 2024 at 12:02 PM
    #74
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Or you can just straight line from trans to a air/oil cooler from the transmission. Saves some money...Mostly for warm/hot climates without cold winters. I did ok down to 30. Took 20-30 minutes to reach 150deg then stayed 170deg.
  15. Jun 17, 2024 at 12:15 PM
    #75
    AZBoatHauler
    So.Arizona
    Personally I wouldn’t want my trans taking that long to warm up for short trips in the winter. I’ve got no issues pinning March-November here but winter months I’ll take the quick warmup since it isn’t unusual for me to have 4-5 short trips and no drives over 15 minutes.
    ID-Matt, Mdl[QUOTED] and FrenchToasty like this.
  16. Jun 17, 2024 at 3:40 PM
    #76
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    True. And even the warming puck acts as a cooler if your TC is over engine coolant temp.
    hagrid likes this.
  17. Jun 17, 2024 at 5:21 PM
    #77
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Yes my 2021 in stock form was not pinnable but added a trans cooler that is (after needing a transmission rebuild).
    AZBoatHauler likes this.
  18. Jun 17, 2024 at 6:14 PM
    #78
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    What happened that made you need a rebuild?
  19. Jun 17, 2024 at 6:16 PM
    #79
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    No no no no no...
    Mdl[QUOTED] likes this.
  20. Jun 17, 2024 at 6:24 PM
    #80
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Not entirely sure but some combination of 650ish crank hp + 35s + magnuson tune + stock transmission + no trans cooler equals losing 2-3 shift and reverse (same clutch as 2-3 shift). I would guess a stock NA engine and even an off the shelf 550hp magnuson install would never need a rebuild.
  21. Jul 2, 2024 at 2:31 PM
    #81
    nobodyintexas
    South of Houston
    Ok a tad more data
    I have a pinned trans cooler
    in the winter I would cruise at 170
    now in the 100 degree houston heat, I still cruise at 170
    you would think the ambient rise would show up in my cruise temp
    but noooooo.
    Ponderosa_Pine likes this.
  22. Jul 24, 2024 at 1:40 PM
    #82
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Had some random thoughts reading through this:
    If you pin the transmission thermostat, does the fluid in the heat exchanger drain back into the pan when the truck is off?
    If fluid does drain back into the pan when the engine is off, what if your thermostat is un-pinned and you turn the engine off while the transmission is hot enough for the thermostat to be open. Fluid drains back into the pan and it is "overfilled" by the volume of fluid in the HX. Fluid cools and thermostat closes, then the transmission is running over capacity until you get the fluid hot enough to open the thermostat again next time you drive.
  23. Jul 24, 2024 at 1:44 PM
    #83
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
    The thermostat can't close if it's pinned open
  24. Jul 24, 2024 at 2:00 PM
    #84
    Tbrandt
    Tristan
    Kansas City
    Right, my thought was if the thermostat is NOT pinned and you turn the engine off while the fluid is hot enough to open the thermostat - Does it drain back into the pan and overfill the transmission if everything cools off enough to close the thermostat?
  25. Jul 24, 2024 at 2:36 PM
    #85
    centex
    centex New Member
    You mean like every single day when you drive it and shut it off at night and let it sit all night with the thermostat functioning as Toyota designed it to do? You mean like that?
  26. Jul 24, 2024 at 2:42 PM
    #86
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Its not running over filled, when you do the temp check for fluid level per the manual you need to pin the thermostat in order to get the correct level. Plus pinned or unpinned the fluid always drains into the pan it just wont pump to the cooler while it is unpinned and below temp.
    _none_ likes this.
  27. Aug 11, 2024 at 1:18 PM
    #87
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    Installed a trans cooler and saw temps hovering around 198-207 while towing. 200 was where it hovered.
    TC spikes were up to 220 on hills. Tow/haul and D.
    After leaving the thermostat pinned (thanks to this post) cruising without towing temps are staying at 170-175. Towing camper I’m not seeing anything over 200.
    Will be leaving it pinned open going forward…
  28. Aug 29, 2024 at 4:20 PM
    #88
    bucketlintels02
    NW Georgia
    Blackstone report on my drain/fill right after the cooler install. This is with several trips towing our 7k lbs. travel trailer.
    not bad.
    Ponderosa_Pine and ID-Matt like this.
