  1. Aug 29, 2024 at 5:31 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Try 90171-18003
    Burgmane[QUOTED] likes this.
  2. Aug 29, 2024 at 5:50 AM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    Thank you
  3. Aug 29, 2024 at 9:05 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    flushed power steering fluid, p.o was using power steering fluid.
    shifty` likes this.
  4. Aug 29, 2024 at 9:22 AM
    I mean, they're both technically hydraulic fluid (ATF & power steering fluid). Different additive packages, and you should always use what OEM recommends for the part that's using the fluid, but PS vs. ATF, I don't think, will kill anyone.
    455h0le_dachshund likes this.
  5. Aug 29, 2024 at 9:44 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I've heard fabric softener can quiet a noisy pump:
  6. Aug 29, 2024 at 11:35 AM
    bfunke
    bfunke Tundra Curmudgeon
    SE Toyota dealers sell a power steering fluid that is clear. It looks just like what came from the factory. Container looks suspiciously similar to Idimetsu PSF.
  7. Aug 29, 2024 at 12:30 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Anybody want to suggest a rattle can for painting bases of my side mirrors?
  8. Aug 29, 2024 at 12:55 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Heat gun or
    whodatschrome and oscardog86 like this.
  9. Aug 29, 2024 at 1:18 PM
    I would use a vinyl dye myself.
  10. Aug 29, 2024 at 1:46 PM
    Mustanley
    Hendersonville, NC
    The base is metal though... I was thinking some satin black Rust-Oleum if it will stand up to the elements. I'm not trying to paint any of the plastic bits.
  11. Aug 29, 2024 at 1:58 PM
    Is it? I thought it was plastic. Huh. I guess I'd use Rustoleum satin black then. Mine don't feel rubberized, so I'd want to stick with something not-rubbery.
  12. Aug 29, 2024 at 1:59 PM
    oscardog86
    oscardog86 New Member
    Southern California
    I thought it was plastic too!
  13. Aug 29, 2024 at 2:04 PM
    Mustanley
    Hendersonville, NC
    If you look closely at the passenger mirror, you can see it's almost completely exposed metal as the original paint has chipped off. It doesn't rust so it's either aluminum or stainless. Looks like aluminum to me.
    oscardog86 likes this.
  14. Aug 29, 2024 at 2:29 PM
    Someone on here - I'm going to randomly take @JakeJake b/c pretty sure it's him - repainted his mirror caps and used a textured paint which looked perfect to me.
    Damn I hope it was him and my memory isn't failing. I remember a lot of really weird shit, and then everything else is a far in the wind. Getting old sucks!
  15. Aug 29, 2024 at 2:34 PM
    Mustanley
    Hendersonville, NC
    I've got an unopened can of this stuff. Maybe it's worth a try.
  16. Aug 29, 2024 at 2:40 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    It was in fact me! I used a rattle can of Rustoleum truck bed coating. Look(ed) great but don't skimp on the prep. Mine look pretty beat after only 2,000ish miles.
  17. Aug 29, 2024 at 2:49 PM
    WTHamIdoing
    WTHamIdoing New Member
    Eric
    2001 tundra v8(2uzfe) auto extended cab
    Killmat entire cab Method 703 wheels King 2.5 coilovers w/ 700lb springs JBA UCA Coastal Off Road high clearance front/rear bumpers and sliders Dirty Deeds 250cc 12 hole fuel injectors
    painted my bumper and slider with rustoleum bed coating spray, this is after about as amateur effort as it gets. No sanding, bare metal, 2 coats. I think it has good color especially for an area like side mirrors that doesnt see a lot of friction.
    oscardog86, BroHon, RealTruck and 2 others like this.
  18. Aug 29, 2024 at 2:51 PM
    Man, I'd have at least hit it with a self-etch primer so you've got something digging into the steel, which is also offering up tooth for the paint to grab into.
  19. Aug 29, 2024 at 2:54 PM
    WTHamIdoing
    Eric
    I am running a test to see how fast it fades with as little effort put in as possible lol. At the first sign of rust/ bad wear, ill do it right. Also considering doing the same to my hood with is looking like @Mustanley mirrors lol
  20. Aug 29, 2024 at 3:16 PM
  21. Aug 29, 2024 at 3:18 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Ok I thought the base was plastic because it looks like faded plastic in the pic.
  22. Aug 29, 2024 at 3:21 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I need a cap like that.
    WTHamIdoing[QUOTED] likes this.
  23. Aug 29, 2024 at 3:21 PM
    Fafo
  24. Aug 29, 2024 at 3:28 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
  25. Aug 29, 2024 at 3:44 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :eek::confused:
    BroHon and FrenchToasty like this.
  26. Aug 29, 2024 at 4:27 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
  27. Aug 29, 2024 at 4:34 PM
  28. Aug 29, 2024 at 4:48 PM
    :itllbuffout:
    Glad you made it out alright.
  29. Aug 29, 2024 at 4:53 PM
    I believe what you see was the offending text.
  30. Aug 29, 2024 at 5:02 PM
    @VR6T just banned as well.
