DASH CAM. Where did you connect your hard wires?
Discussion in '3rd Gen Tundras (2022+)' started by magicfirefighter, Aug 25, 2024.
  1. Aug 25, 2024 at 9:35 AM
    magicfirefighter
    magicfirefighter [OP] New Member
    JIM
    2022 SR5
    after market PELSEE Dash Cam. installing the 24 hour wire connection. ITs asking for a ACC connection and a 12v connection. Which fuse did you jump to do this? so that the camera records 24/7 thank you
  2. Aug 25, 2024 at 10:13 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I used a OBD power take off with a voltage protection cutoff set to 12.1V. Camera will still record if there is an impact or movement in the cameras view.
  3. Aug 25, 2024 at 1:14 PM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    Fuse box behind glove box. Use fuse taps.
  4. Aug 25, 2024 at 1:40 PM
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    Couldn't the Dongar adapter for the OEM dashcam be reconfigured to be 12 volt on all the time and still have an acc on?
  5. Aug 25, 2024 at 2:13 PM
    BayAreaTruckin
    BayAreaTruckin New Member
    San Francisco, CA
    Yes, the Dongar adapter can be rewired. They are also coming out with a new version that will be always on.
  6. Aug 28, 2024 at 8:49 PM
    MaiToyTunCap
    MaiToyTunCap New Member
    Hoa
    Minnesota
    2023 Tundra Capstone
    Bak X4S; Hardwired Dashcam; Carlinkit
    I just scrolled through their website and don't see any mention of an "always on" connector. Where are you getting this information? Would you mind sharing?
  7. Aug 29, 2024 at 7:28 AM
    BayAreaTruckin
    San Francisco, CA
    Yeah, check out post #112 & #120 in this thread. I had an email conversation with one of the co-owners of Dongar, and there is a video linked of the functionality.
    MaiToyTunCap[QUOTED] likes this.
  8. Aug 29, 2024 at 7:38 AM
    bobsicle
    bobsicle New Member
    Bob
    Red trd or limited
    Pull the sunglasses holder down and there’s a socket with everything you need. Wire to that or make a connector. You can buy on Amazon
  9. Aug 29, 2024 at 8:05 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    A member on here was selling pigtails for that headliner plug...thats where the OEM dashcam connects. I use that, paired with a low voltage cutoff for my cam
  10. Aug 29, 2024 at 8:15 AM
    bobsicle
    bobsicle New Member
    Bob
    Red trd or limited
    I used the hardwire kit from Vantrue, removed the connector and wired directly to those wires. Works fine. I can always replace that connector if I need to.
  11. Aug 30, 2024 at 2:59 PM
    MaiToyTunCap
    Hoa
    Minnesota
    I've mentioned this before in the other thread, and I think about it all the time, but I wish there were some smart person out there who'd created a piece of hardware and program that can tap into all the camera feeds and capture it as dashcam recording--like Tesla. It seems like a huge wasted opportunity for the 6 cameras.
  12. Aug 30, 2024 at 3:02 PM
    TaquitoBandito
    Joel (AKA Bif)
    If y'all chip in and gift @RainMan_PNW a 2024, I bet he could figure it out.
