DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Aug 26, 2024 at 1:54 PM
    #3391
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  2. Aug 26, 2024 at 4:21 PM
    #3392
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    You’re local to a shitload of us. We can/should get together and you can eyeball the goods before marrying the milk maid or screwing the cow or whatever the fuck the saying is.
    And also yes - you can flex off road and still turn.
    And like @reywcms said, if you’re looking in this thread, the money is already spent. :rofl:
  3. Aug 26, 2024 at 4:33 PM
    #3393
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    lol she gone
  4. Aug 26, 2024 at 5:04 PM
    #3394
    PhoenixSR5
    PhoenixSR5 New Member
    Brandon
    Gilbert, Az
    2016 Tundra SR5 work in progress
    Front: Dirt King Long Travel Kit, DK spec King Coilovers, BMC and Pinch weld mod. Rear King 2.5 RR shocks, Deaver K37s, SDHQ Shackles. Fuel Hype 18x8.5 w/ Dirty Seven Maxxis RAZR MT
    It's gone lol. They'll be here in a couple days lol.
  5. Aug 26, 2024 at 5:05 PM
    #3395
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Hahaha nailed it
    Corndog123 and KevinK like this.
  6. Aug 26, 2024 at 5:48 PM
    #3396
    SAGE63
    San Diego County
    I lose money not talking to him...lol
  7. Aug 26, 2024 at 8:46 PM
    #3397
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    When I drive north, I go the long way around so I don’t spot him in Beaverton. It’s bad enough online, but I can afford that level. Not sure I can handle a live-action meeting…
    I had to run through Tigard yesterday to pick up a couple new jig rods. Had the wife with me, so I ran like hell after the rods were loaded.
    Side note, she was less than impressed with how much room the passenger seat loses when you quickly cram two 9’ jig rods in the cab!
  8. Aug 28, 2024 at 8:30 PM
    #3398
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    LOL, what kind of jig rods did you pick up?
  9. Aug 28, 2024 at 10:37 PM
    #3399
    Chad D.
    Chad D. New Member
    Western Oregon
    One is my UC Reaper. Had a minor repair done. Other is a 10’ Rainshadow MH Tuna Popper 2-piece rod. Interesting, as the split leaves about 7’-6” in one piece with a 30” butt section. With my guide layout and reel placement, it worked fine with 6” cut off the butt. Both are spiral wrapped.
    pvn.beluga[QUOTED] likes this.
  10. Aug 30, 2024 at 8:01 AM
    #3400
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
  11. Aug 30, 2024 at 12:23 PM
    #3401
    -PUG LIFE-
    -PUG LIFE- New Member
    Dillon
    Huntsville, AL
    2021 Cement CM SR5 Trail Edition
    @bmw345 care to share your lift and what all was needed to make these work? This is exactly what I’m looking to do to mine.
    thanks in advance
  12. Aug 30, 2024 at 3:59 PM
    #3402
    bmw345
    bmw345 New Member
    CT
    TRD Pro Fox shocks at all four corners, added a .5 coach builder spacer to the fronts for a total of 2.5" of lift. Rear is plus 1" Coach builder shackle only. BMC done and Coach builder bumper spacers also added. Plastic at front of fender well also massaged for another inch or so of clearance. That's it.
  13. Sep 4, 2024 at 7:44 AM
    #3403
    PhoenixSR5
    Brandon
    Gilbert, Az
    Officially joined the club! Have some pretty good rubbing but still need to get the alignment done.
  14. Sep 10, 2024 at 5:16 PM
    #3404
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    I'm hopeful but.....I've lurked on this thread long enough to realize there arent many big lift, negative offset guys that go 37s.
    I bought this truck with a 6" Pro comp spacer lift on Fuel 20 x 10 and -19 offset (from what i can find searching these wheel specs) running 35" ridge grapplers. I had some rubbing when the tires were newer and installed CB bumper shims. The front fender liners have some minor nip/tuck from the previous owner.
    I'm wanting to replace the front spacers with coilovers, looking at the Vertex 2.5s. If I went that route I'd likely look at SPC UCA as well.
    Knowing I'd at least need an aggressive BMC and PW mod, is there any hope for fitting 37s with those wheel specs? I probably won't convince the boss that new wheels are needed when these tires wear out. Just trying to see gauge how realistic 37s would be on this setup.
    No wheeling, no towing. Very limited offroad except to get to fishing spots. Thanks in advance for the input!
  15. Sep 10, 2024 at 5:30 PM
    #3405
    Chuck45
    Chuck45 New Member
    Chuck
    2014 DC
  16. Sep 10, 2024 at 5:34 PM
    #3406
    rcsbguy
    rcsbguy New Member
    Are most of you guys spacing your bumps down to limit uptravel? I’m doing the math on running 37s and looking like you lose 1” of uptravel, which is a lot given these trucks don’t have much to begin with.
    That being said, I still want 37s. Lol.
  17. Sep 11, 2024 at 5:19 AM
    #3407
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    You running wheel spacers with those RW wheels?
    pvn.beluga likes this.
  18. Sep 11, 2024 at 5:23 AM
    #3408
    Chuck45
    Chuck45 New Member
    Chuck
    2014 DC
    Yep. 1.25”
    Shanet421[QUOTED] likes this.
  19. Sep 11, 2024 at 10:09 AM
    #3409
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    20x10 on -19 is a bit extreme for my taste. But, I mean whatever floats your boat. If it’s already running 35s and you’re not seeing anything that affects your daily drivability, then I don’t see why 37s would affect if it much more considering you’ll most likely be on the pavement.
    Go for it. It seems everything is already in place so you might just need an alignment after putting on new tires.
  20. Sep 11, 2024 at 10:11 AM
    #3410
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I left my OE bump stops in place. I know quite a few have added the extension to the front bump stops to limit up travel.
    rcsbguy[QUOTED] likes this.
  21. Sep 11, 2024 at 10:37 AM
    #3411
    rcsbguy
    rcsbguy New Member
    I talked to quite a few shops now and all advised not to do 37s on mid travel, but OK on long travel. Static ride height is too low on these trucks to allow for full functionality of the tire on MT.
    So with that info I found some nice new 37” KO2s for $1000 lol.
    COTundra23 and SAGE63 like this.
  22. Sep 11, 2024 at 10:40 AM
    #3412
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    I don't understand what the shop means.
    37s will fit a truck on stock suspension if you want to. It's a tire. It's functionality is rolling...
    What is "full functionality"?
    Guess they mean squish it adds to the ride.
    Or maybe they said that hoping you'd buy a long travel from them?
    rcsbguy likes this.
  23. Sep 11, 2024 at 10:53 AM
    #3413
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Lol wouldn’t be surprised actually that they advise against it.
    I had a couple people say that if you want full functionality of your articulation, then 35s are the sweet spot or even 285/75. But ultimately, I wanted to be a cool kid and so I went with 37s instead.
    Yes, without proper modifications, you’re limiting a lot of up travel running 37s. Which is why there’s many that suggest to actually go find a loading dock or something that allows your truck to go full lock and seek areas of rubbing. I personally have not done that, but for what I use my truck for right now, as long as I’m not rubbing when I’m turning or doing u-turns, then I’m good. I would like to eventually put my truck into full lock and trim a bit more or even consider purchasing glass and a high clearance front bumper to mitigate all those issues.
  24. Sep 11, 2024 at 10:55 AM
    #3414
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Function over Form is what the shops are saying.
    If you can only go in a straight line, you may as well trailer your rig and bring it to the drag strip.
  25. Sep 11, 2024 at 11:15 AM
    #3415
    Totmacher
    Daniel
    West TN
    Some
    So shop is just saying not full functionality if you don't cut for clearance to articulate it?
    You can trim stock to articulate 37s, doesn't need long travel. That's why the statement doesn't make sense to me .
    coTony likes this.
  26. Sep 11, 2024 at 3:32 PM
    #3416
    Chuck45
    Chuck45 New Member
    Chuck
    2014 DC
    I’d find a new shop. I brought my tires to discount tire and told them they’d fit.
    I had already chopped body mount and pinch weld though.
    rcsbguy likes this.
  27. Sep 11, 2024 at 6:52 PM
    #3417
    rcsbguy
    rcsbguy New Member
    Getting the most uptravel possible smashing through whoops. That advice to stay away from 37s came from bigger shops down here, one being Total Chaos.
  28. Sep 11, 2024 at 6:56 PM
    #3418
    rcsbguy
    rcsbguy New Member
    I feel that man. I’m between abusing my truck offroad and daily driving. Little to no crawling, but a lot of whoops. I’ll likely drive the 35s I have out then move to 37s, but set them up the best I can to not take away too much bump travel. For crawling the 37s I’m sure help a lot.
    And @Totmacher , we’re talking more than just cutting to fit while turning. I’m talking fully stuff, smashing whoops at 50mph, etc. I’d like to see any pictures of people who really “cleared” for 37s with mid travel and a lower static ride height if there are any. I haven’t seen any people on here post cycling suspension, etc.
  29. Sep 11, 2024 at 9:04 PM
    #3419
    SAGE63
    San Diego County
    I scuff the top of my wheel wells on some whoops. Usually at slower speeds, lol
    btw no well liner either self cleared both sides at Cinders during Go Fast Friday
    reywcms and rcsbguy like this.
  30. Sep 12, 2024 at 9:33 AM
    #3420
    rcsbguy
    rcsbguy New Member
    Sounds about right, haha.
    SAGE63[QUOTED] likes this.
