DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Aug 8, 2024 at 7:53 PM
    #3361
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Haaaaaave ya met @reywcms?
  2. Aug 8, 2024 at 8:36 PM
    #3362
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Lmao.
    Disclaimer not responsible for significant others being upset at you lol
  3. Aug 8, 2024 at 8:56 PM
    #3363
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    Tried finding in the thread, but a hundred plus pages, anyone running 37x13.50R18 with +25 offset?
    I have Icon Billet uppers and Icon 2.5 remote resi shocks
    CaptRussia253 and coTony like this.
  4. Aug 9, 2024 at 6:08 AM
    #3364
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    KevinK and NoMoreGreen[QUOTED] like this.
  5. Aug 9, 2024 at 6:27 AM
    #3365
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    The 13.5 may need a bit of a modification. The +25 fits with the 12.5 more so. That 1” will make a difference.
    coTony and NoMoreGreen[QUOTED] like this.
  6. Aug 9, 2024 at 8:13 AM
    #3366
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    That’s what she said
    bmw345, KevinK, CaptRussia253 and 5 others like this.
  7. Aug 9, 2024 at 9:38 AM
    #3367
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    :rofl::rofl::rofl::rofl::rofl:
  8. Aug 9, 2024 at 10:21 AM
    #3368
    NoMoreGreen
    Robert
    2020 Tundra
    Thanks for the pointers, I’ll have to go read KevinKs build again.
    maybe better to stick with 12.50.
    are you guys getting proper articulation up and down with your set ups?
    KevinK likes this.
  9. Aug 9, 2024 at 10:23 AM
    #3369
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yes
  10. Aug 9, 2024 at 11:31 AM
    #3370
    SAGE63
    San Diego County
    So true I am on 37 12.5
  11. Aug 9, 2024 at 11:34 AM
    #3371
    SAGE63
    San Diego County
    Still hitting the fender well on big hits yeah no liner tbinking of bigger bump stops on my MT 2 set up. same as @KevinK currently.
    3.0 coilovers and 2.5 omega S2
    KevinK and NoMoreGreen like this.
  12. Aug 9, 2024 at 4:18 PM
    #3372
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I live vicariously through @reywcms so technically, yes. :D
  13. Aug 9, 2024 at 6:01 PM
    #3373
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Lol
    SAGE63 likes this.
  14. Aug 10, 2024 at 8:25 AM
    #3374
    coTony
    Tony
    Montrose, CO
    That is my current setup
    NoMoreGreen[QUOTED] likes this.
  15. Aug 10, 2024 at 8:33 AM
    #3375
    coTony
    Tony
    Montrose, CO
    That 1 inch makes a difference with the Icon billet UCA. With the alignment shoving the tire as far forward as possible when in reverse full lock the side walls decsribed as 12.5 actually measure 13.5” and rub the UCA slightly. Never caused a problem yet
    NoMoreGreen likes this.
  16. Aug 10, 2024 at 8:33 AM
    #3376
    coTony
    Tony
    Montrose, CO
    Ya think? With LT you are golden Mister
    reywcms[QUOTED] and NoMoreGreen like this.
  17. Aug 12, 2024 at 6:32 AM
    #3377
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    I need to check my lift sometime.
  18. Aug 20, 2024 at 1:48 PM
    #3378
    rcsbguy
    rcsbguy New Member
    Anyone running +35mm Method 703s?
  19. Aug 20, 2024 at 1:52 PM
    #3379
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I think @bmw345 is running +35.
  20. Aug 20, 2024 at 1:59 PM
    #3380
    rcsbguy
    rcsbguy New Member
    Looks like an easy offset to clear 37s. But doesn’t look like it’ll work if you add in secondary bypasses on midtravel.
  21. Aug 21, 2024 at 6:04 PM
    #3381
    SAGE63
    San Diego County
    +25 701 r18s fit Mid Travel 2.5 secondaries
    coTony and rcsbguy[QUOTED] like this.
  22. Aug 21, 2024 at 8:27 PM
    #3382
    rcsbguy
    rcsbguy New Member
    Yeah but 18s…I’m a 17 guy haha! I do have a few +25mm options in a 17”.
  23. Aug 21, 2024 at 8:58 PM
    #3383
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
  24. Aug 21, 2024 at 9:04 PM
    #3384
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Adding secondary’s would require you to add an additional shock hoop anyway. At that point, I’d assume you’re doing everything you can to gain max up travel/down travel to clear your tires.
    Why limit yourself to an “easy” to fit offset?
  25. Aug 22, 2024 at 6:06 AM
    #3385
    Chad D.
    Chad D. New Member
    Western Oregon
    Keep in mind that most 17” wheels are 8.5” wide, while the 18s are more likely 9” wide.
    The only reason that matters is because it changes the relationship between offset and backspacing. Look at an online wheel offset comparison tool to see what this means, but the backspacing difference (which is what affects clearance to UCA) between a +25 18” wheel and a +35 17” wheel is NOT 10mm.
    KevinK and rcsbguy[QUOTED] like this.
  26. Aug 22, 2024 at 7:23 AM
    #3386
    rcsbguy
    rcsbguy New Member
    Good advice!
  27. Aug 22, 2024 at 8:50 AM
    #3387
    Chad D.
    Chad D. New Member
    Western Oregon
    I just looked it up. An 8.5” wide wheel with +35mm offset will sit only 4mm CLOSER to the UCA than a 9” wide +25mm offset wheel. Less than 1/4” difference on the backspacing.
    It’s the outer edge where you’re gonna see the difference. The 8.5” wide +35mm wheel will have 16mm LESS poke than the 9” wide +25mm wheel. This means more clearance for the fender well, body mount, and back side of the bumper. Quite a bit more…
  28. Aug 25, 2024 at 10:35 PM
    #3388
    rcsbguy
    rcsbguy New Member
    I like my tire tucked in under the fender, and easy to fit = less BS to deal with.
  29. Aug 26, 2024 at 5:37 AM
    #3389
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Do you thinks I’ll be able to stuff some Patagonias 38x13.5?
    What issues could I run into if I’ve already done pinch weld, BMC, pushed bumper forward, casters at 6*, trimmed front caps? What issues can I run into in the rear aside from rubbing the liners?
    What potential mechanical issues can I be facing moving up an extra inch in diameter?
    Grabber X3 currently sits at 80lbs per.
    Patagonias will sit at 84lbs.
    Going to be running the VTX rogue with these tires if I do use them. So downgrading to 17s and probably keeping the 18s aside for spare purposes until I can find another cheap set of 17s.
    danb, Deaner, Mountun Goat and 2 others like this.
  30. Aug 26, 2024 at 8:47 AM
    #3390
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    Correct, our first 37s setup was 37x13.5 on 18
    I preferred the 13.5 width, but when we switched to beadlocked 0 offset 17s, the tires we wanted to run didn’t come in 13.5 width.
    The beadlocks also made the 0 offset into a -5 offset (verified by measuring the new backspacing after OMF converted the Methods)
    This guy fucks.
    You’re gonna have to take your current setup out someplace where you can articulate the suspension completely and cycle the steering from lock to lock. Measure everywhere the tire gets close to metal and plan on rubbing or trimming.
    Also bear in mind the different shoulder profiles of the old and new tires (where the tread meets the sidewall). Some tires have a very wide shoulder, and some slope off toward the sidewall sooner.
