Headlight cleaner/polisher
Discussion in 'Detailing' started by tmac58star, Aug 25, 2024.
  1. Aug 25, 2024 at 3:58 PM
    tmac58star
    tmac58star [OP] New Member
    Black 1st generation Tundra SR5 Access Cab
    Got after the lightly oxidized headlight buckets on my 07 SR5. Turned out pretty well, even though the Meguiar's cleaner & polish is kind of old...looks much better.
    mtucker likes this.
  2. Aug 25, 2024 at 4:49 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    might want to give some cerakote a try. Should last a while.
    KNABORES likes this.
  3. Aug 26, 2024 at 10:41 PM
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    My colleague at work also used the cerakote headlight restoration kit with great success
    kamaaina1 and TRD ROB like this.
  4. Aug 27, 2024 at 2:29 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Ditto on the Cerakote. Stuff is a wet and it lasts
  5. Aug 27, 2024 at 5:05 PM
    tmac58star
    Looks like a terminal, once-off product purchase. Dampness and 2 grit pads for wet sanding, plus a plastic pad applicator. I'll stick with Meguiars and seal with a wax coat.
  6. Aug 27, 2024 at 5:07 PM
    I’ll 3rd or 4th the cerakote kit. Did mine almost a year ago and still look great
  7. Aug 27, 2024 at 5:12 PM
    Before:
    After:
    One year later:
  8. Aug 27, 2024 at 5:14 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    When last December i purchased my 3 gen tundra in preparation to pass my 2008 4runner to my daughter i polished i for the first time in its life, i used el cheapo HF polisher/buffer about $7 and Meguiar's Ultimate Compound $13.
    Ran over the head lights as well. They still like new. Better then my previous attempts with specials restoration kits.
    tmac58star[OP] and KNABORES like this.
  9. Aug 30, 2024 at 8:04 AM
    hackettTRD
    hackettTRD New Member
    2007 DC TRD 5.7
    I used Cerakote on my wife's "13 Camry headlight and it scratched the hell out of it. Threw it away and bought a new headlight. She had hit a deer and the other one was brand new. I use Rain-X on my "07 Tundra headlight. Rub it in like a polishing compund. It also coats it. Try it, it works good.
  10. Aug 30, 2024 at 2:26 PM
    Danny3737
    Wow, I’ve done about 7 vehicles ( 4 were my own ) and they all came out looking like new. The first one I did has been over 3 years and still looks like the day I did it.
  11. Aug 31, 2024 at 3:20 PM
    coastaldesert
    coastaldesert New Member
    Oregon Coast
    Improved! I just gave up on mine and replaced them with some Eagle Eyes OEM style total replacements, also threw in some silverstars while I was at it. Looks much better for around $200 all in!
  12. Aug 31, 2024 at 10:34 PM
    Dr_Al
    Dr_Al New Member
    Al
    I tried to do mine (can't remember which brand headlight restorer) and found out the reflective part of the light was so bad that I gave up on my '07. I got a real cheap set of Chinese replacements that look just fine but I'm sure they will not last that long. Since then I replaced the low beam bulb with a projector upgrade kit. Had I done that first I probably would have not worried about the dullness of the original light's reflectors.
  13. Sep 29, 2024 at 1:53 PM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    I just cleaned up my headlights with the Turtle Wax headlight kit. Not too bad for $13 from Home Depot.
  14. Oct 1, 2024 at 12:53 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Just used this. Super easy to apply with great results.
  15. Oct 1, 2024 at 1:06 PM
    For those that are compounding/polishing...my advice would be to then treat it with IPA and ceramic it.
  16. Oct 2, 2024 at 4:07 AM
    TundraClayDigger
    TundraClayDigger New Member
    2018 Crewmax Limited 4X4
    I have used Klasse AIO to clean my wife's old 2006 Camry's headlights. It works well and they look like new. It is a sealant but it also has cleaners in it. I tried it on my niece's husband's 2014 Tundra that were hazed very badly. It cleaned them up some but Klasse would not bring them back to clear. I told him we would buy a headlight kit because we needed a more powerful cleaner to polish them out.
  17. Oct 9, 2024 at 5:38 AM
    vmkeith
    vmkeith New Member
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining bedliner Rydonair 7" antenna 275/70/18 Pirelli Scorpion A/T tires Lund 5" Cab Length Oval Curved Tube Steps RealTruck Elevate FS Bed Rack Rhino-Rack Carriers RealTruck TruXedo Pro X15 Tonneau Cover Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs
    I just finished up doing a headlight restoration this weekend. I just had some simple clouding, nothing seriously bad like yellowing or deep scratches. Watched a ton of videos on YouTube to compare different techniques. I went with the following:
    1. 3" border of painter's tape around each headlight
    2. Cleaned both headlights with simple Windex 3x
    3. Wet sanded with 1000 grit and 3000 grit sandpaper (soaked 5" x 5" pieces of sandpaper in water for 10 minutes before use)
    4. Cleaned with Windex 3x again and let dry (can speed up drying process with a heat gun set on medium heat)
    5. Applied Chemical Guys Headlight Restore and Protect with a fine polish pad until transparent
    6. Hand buffed with a clean dry microfiber towel
    7. Applied 2 coats of Meguiar's Keep Clear Headlight Coating
    All total, maybe 1.5 hours for both headlights. It's not perfect, but a damn sight better than what it was and don't have to fork out the cash to have someone else do it.
  18. Oct 9, 2024 at 6:14 AM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Nice work!
  19. Dec 8, 2024 at 9:33 AM
    agathon
    agathon New Member
    PA
    2000 Tundra 4.7L V8 2WD
    SnugTop camper shell
    Dummy question: what is "IPA" ??
    T-Rex266[QUOTED] likes this.
  20. Dec 8, 2024 at 9:48 AM
    IPA – Isopropyl Alcohol is a highly effective, general use cleaning solvent that is used to clean a variety of substrates and remove a variety of soils.
    agathon[QUOTED] likes this.
  21. Jan 15, 2025 at 4:31 AM
    SC SR5
    SC SR5 New Member
    2014 SR5 CM, 2025 Lifted Platinum
    RC coilovers/level shocks , 2014 Factory lift on the 2025 Platinum
    Menzerna 400 and a wool pad on buffer , maybe 2-3 minutes per light
