Ahmed hates metal oil filter cannisters
Discussion in '2.5 Gen Tundras (2014-2021)' started by DaveInTexas, Oct 1, 2023.
  1. Oct 2, 2023 at 10:29 AM
    AZBoatHauler
    So.Arizona
    The procedure usually calls for a warm engine that has sit 5 or more minutes to check the oil. If you’re checking a cold engine, you’re not getting the intended reading.
  2. Oct 2, 2023 at 10:39 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Yes it was a cold engine........I will check again when I get home. Thanks
  3. Oct 2, 2023 at 11:37 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
  4. Oct 2, 2023 at 11:47 AM
    shawn474
    MoCo, Maryland
  5. Oct 2, 2023 at 3:27 PM
    shawn474
    MoCo, Maryland
    got home and started the truck; let it sit for 15 minutes and rechecked. Still reading above the second dimple; removed a half a quart from the fumoto valve. Repeated process and it’s right at the second dimple now ;hard to see from the picture). Next time this will not be such an adventure
    AZBoatHauler[QUOTED] likes this.
  6. Oct 2, 2023 at 6:12 PM
    pursuit2550
    pursuit2550 New Member
    You check your oil after putting it in, lol. I just add the oil, as long as there is no puddle in the driveway, I know where it's at. And 1/2qt +/- isn't hurting anything. :cheers:
    shawn474[QUOTED] and Gene_in_FL like this.
  7. Oct 3, 2023 at 4:51 PM
    seydou
    seydou Distinguished Member
    I kind of like these types of threads.
    So is there a part number for a Lexus(or?) with the same engine that is a metal housing and not plastic?
  8. Oct 3, 2023 at 5:28 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    If you just never change your oil everything is a lot simpler
    Mike59 and hagrid like this.
  9. Oct 3, 2023 at 6:38 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    THIS!!
    What have I been telling you people?! There is not a damned thing wrong with the oil Toyata put in there in the first place!
    Just use it and be happy.
    GODZILLA, WFD473 and gosolo[QUOTED] like this.
  10. Oct 3, 2023 at 7:38 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    What’s the biggest tire I can run with the aluminum filter housing?
  11. Oct 3, 2023 at 8:28 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    I swapped mine on my Tundra before the video came out. I guess I'm a simpleton thinking metal was better than plastic, but I've had so many plastic parts break on engines due to heat that it is hard to trust it, so I swapped it for the OEM metal one. I haven't had any problems with the swap in the 3+ years since I've done it. Just bought a 4runner and I'm leaving the plastic one in place without a worry in the world. I like Ahmed's videos and information and I imagine there are some that would mess up the process of the swap and it could cause problems, but I think his stance on this particular issue is a little over the top.
  12. Oct 3, 2023 at 9:26 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m pretty sure you’re good running 37’s, as long as you have the rear differential breather routed up to the rear tail light.
    Terndrerrr[QUOTED] and Mike59 like this.
  13. Oct 3, 2023 at 9:36 PM
    Joe333x
    Joe333x Member
    Boston
    Doesn't exist from what I could find. Seems its just an old wives tail passed through the forum, unless someone can chime in to back up that statement.
  14. Oct 3, 2023 at 9:49 PM
    Retroboy1989
    Northern Utah
    Bigfoot, loche ness, chupacabra, 5.7 with a factory aluminum oil filter housing.
    hagrid, AZBoatHauler and shawn474 like this.
  15. Oct 3, 2023 at 10:11 PM
    Joe333x
    Joe333x Member
    Boston
    One thing i was able to find was a Lexus 4.6 which is is a 1UR that used this part number 1562031040 for the filter cap which appears to maybe have the longer tube in it. Not the same as the 3UR but similar, I'm curious if this one at least uses the correct tube length.
    Edit: After looking at photos of the Tundra cap I dont think the Lexus one would be long enough. Photos attached
  16. Oct 3, 2023 at 10:25 PM
    Joe333x
    Joe333x Member
    Boston
    MrJimmyPenguin likes this.
  17. Aug 25, 2024 at 2:45 PM
    jcic22
    jcic22 New Member
    Old thread, but I purchased the 15650 part number and it has a little lock/retaining clip on it that prevents the housing from screwing on, 2021 Tundra w/ tow package in this case so maybe it has an oil cooler? Toyota parts website says the 15650 part is for non tow package. 15620 is for tow package with oil cooler. 15650 fits on a tow package equipped tundra if you slide off the clip, but I’m not sure what else might be different about that housing specific to a non-tow package (no oil cooler) tundra.
  18. Aug 25, 2024 at 3:35 PM
    Joe333x
    Joe333x Member
    Boston
    Interesting, looking at the photo you can actually make out a clip on the side now that I look closer.
  19. Aug 25, 2024 at 3:37 PM
    jcic22
    jcic22 New Member
    right, and I don’t know if the filter itself will actually function the same as the 15620 part? Oil bypass function, etc? Clip was removed to install it so it would fit on. The clip just slides off.
  20. Aug 25, 2024 at 3:41 PM
    #50
    18" TRD Off Road Wheels
    But what if he wants to "do you" too? Maybe he thinks you'd be a gentle and compassionate lover?
  21. Aug 25, 2024 at 3:44 PM
    #51
    So you just want an echo chamber? No discussion or evidence to counter one guy's personal view on the topic?
