Let's see 1st gen with Toyota Rims
Discussion in '1st Gen Tundras (2000-2006)' started by Lupe, Feb 19, 2019.
  1. Aug 3, 2024 at 3:22 PM
    #991
    He hasn't signed on since April, so I'll help a lil' bit
    285/75r17 -> https://www.tundras.com/threads/lets-see-your-first-gen-photo-thread.21/page-15#post-826799
    Lift => https://www.tundras.com/threads/lets-see-your-first-gen-photo-thread.21/page-14#post-826090
    Before you do either, I highly recommend reading this thread, both the wheel/tires and suspension/lift section => https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    I assume he means Tuff Country, not Rough Country. Rough Country is really not-good stuff. For same or barely more than budget stuff like RC you can easily get that same lift.
    But running a 265/70r17 or 275/70r17 will look visually very similar on your truck. Here's why.
    abcinv and Spike77777[QUOTED] like this.
  2. Aug 3, 2024 at 6:26 PM
    #992
    Spike77777
    Spike77777 New Member
    2000 Limited Bilstein shocks, mild lift 1" front and 3/4" block rear. 17" Stock wheels from later model Tundra with 275/70/17
    Thanks, I haven't been on here for awhile myself. Appreciate all the links and also the interesting links to tire size. I currently have a modest lift from bilisten 5100's and running 265/70r17's. May go 275 next time around but not sure it's worth it in loss of gas mileage. Thanks for the help!
    shifty`[QUOTED] likes this.
  3. Aug 3, 2024 at 6:56 PM
    #993
    As someone running aggressive and oversized E-rated 275/70r17 that are closer to 285/70r17 than they are their actual size, having lost about 15% of my mpg, I'd recommend against it. I'd jump straight to a C-rated 285/70r17 from your current size, and I'd try to find something you think looks good, but weighs less than 50lb in the larger size, if you can. If you're going all-terrain it'll be harder for sure to find something under 50lb (I think). My Mickey Baja Legend EXP are 59lb in 275/70r17 I believe, and my stock tire was closer to 35lb. Almost doubled the rotational mass.
    But you'll still be rubbing, you'll need to remove your front mudflaps, and potentially hammer some stuff out. Don't forget, lift doesn't help you clear tires per se, just helps prevent contact during compression events. If you have 5100s already, alignment and hammering is what's going to help you avoid rubbing should you choose to commit adding another half inch or inch of tire.
  4. Aug 3, 2024 at 7:49 PM
    #994
    Spike77777
    I'll keep this in mind the next time the search to buy tires comes up. I only have around 7k miles on these 265s so it will be awhile. Not sure I look forward to losing 15% in gas mileage but hopefully gas prices will drop over the next year.
  5. Aug 3, 2024 at 7:54 PM
    #995
    This is not being said in the context of political banter, because politics is strictly banned on this forum, but ...
    I'd love to convince the oil companies to do just that. Given the millions they get of our tax dollars for incentives, on top of the gaggle of profit they make, it'd be nice for them to finally stop screwing all of us. But you gotta pay the stockholers what they want, I guess.
    I'd love tire prices to drop too. What BFG wants for the KO2s versus when they first launched, with no significant change in raw material pricing, and the KO3s now, it's nuts. It's in their hands to drop their pricing, but as long as people are paying it, there's no reason to.
    That's the really awesome part about capitalism, amirite?! The system is working as it's designed. However, for the other stuff...
    Even on my hunt for fun OEM wheels on FB Marketplace recently was a gouge-fest. At this point, everyone "knows what they got", I guess :rofl:
    G_unit3000 likes this.
  6. Aug 6, 2024 at 9:35 PM
    #996
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    thanks guys...bought them will mount up Saturday to test...thanks
    shifty` likes this.
  7. Aug 6, 2024 at 11:32 PM
    #997
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Mounted these up about 2 weeks ago, lots of pinch weld clearance needed. They still slightly rub so I’m going to go with Solo Motorsports LCA’s.
    Falkin 285/75r17 (34x11:50) bought on Black Friday from Simple Tire with about 4 discount codes, shipped just under $1,150.
    Wheels are New Toyota T4R 5th Gen Pro Wheels. Purchased from a Toyota dealer on Amazon. I bought them 2 years when they dropped to like $975 shipped. I was skeptical and was ready to fully inspect them to make sure they were real, and they are 100% new OEM.
  8. Aug 7, 2024 at 6:46 AM
    #998
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Great size, I'm running toyo's in the same on repro (I believe) TRD pro's with Solo Motorsports LCA's as well.
  9. Aug 7, 2024 at 7:52 AM
    #999
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Twinning!
    Those look like Toyota, the knockoffs are pretty obvious.
    My old 285 Toto’s still have tread even at 116k miles. I wanted to give the Falkins a try as everyone has been suggesting them.
  10. Aug 7, 2024 at 10:50 AM
    #1000
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Yeah I've always heard good things about the falkens.
    Idk I see fakes online all the time that look pretty good. They say made in China on them, and as far as I know the TRD pros are made in Thailand ‍♂️
  11. Aug 7, 2024 at 10:51 AM
    #1001
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    That's a crazy amount of miles btw, are they E rated?
  12. Aug 7, 2024 at 2:50 PM
    #1002
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I believe mine did say Thailand, and had the normal Toyota marking on the wheels. The packaging was very much a Toyota product.
    Tlar25[QUOTED] likes this.
  13. Aug 9, 2024 at 8:02 AM
    #1003
    taranovich92
    taranovich92 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Nitto TerraGrappler G3 285/70/17, Apple CarPlay, CB radio, Randy Ellis Design front bar, Hella 500 rally lights, Mini LED projector headlights, Trailrunner Customs fogs, SkidRow Offroad skid plate, 333 Fab steering rack clamp.
    I have since gone bigger but that was 275/70/17 with 2.5" front strut spacer & 2" block in the rear.
    Spike77777[QUOTED] likes this.
  14. Aug 9, 2024 at 8:44 AM
    #1004
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    I recently got these wheels with 265/70/17. Did you have to run any spacers or different lugs,, wheels came without lugs, havent had a chance to test fit yet,
    so was looking into spacers if i need them and noticed bora makes a thin spacer, like 1/4 inch and that would take me back to near stock offset any experience with those ?
  15. Aug 9, 2024 at 9:08 AM
    #1005
    1/4” spacers would be dangerous to me. Still using the original lugs which are short to start with. Have to run ET lug nuts as it is.
    3bears[QUOTED] likes this.
  16. Aug 9, 2024 at 10:01 AM
    #1006
    tsinajinii
    tsinajinii Black Streak Wood People | Free Folk have no King
    Jamin
    AZ
    Tundra - Crewmax TRD Sport; Tacoma - DCLB TRD Sport
    My coworker initially did not use spacers and did use his same lugs.
    Without spacers the wheels were very tucked in, to the point where his new 285 tires (wider thand 265's) were rubbing on the upper control arm.
    He ended up running a 1.25" spacer and it corrected the rubbing and gave him the perfect stance with those wheels.
    I've ran spacers on my Tacoma before and would reccommend these:
    https://www.spidertrax.com/products/2000-2006-Tundra
  17. Aug 12, 2024 at 6:46 PM
    #1007
    AlexiosTundra02
    AlexiosTundra02 New Member
    Ventura County
    2002 Tundra AC 4WD
    FJ Trail Edition wheels
  18. Aug 13, 2024 at 8:47 AM
    #1008
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    Those look good. I was looking for a used set for a while, but they aren't as common as anything that came on a 4runner.
    Tlar25 likes this.
  19. Aug 13, 2024 at 12:56 PM
    #1009
    AlexiosTundra02
    Ventura County
    2002 Tundra AC 4WD
    Yup, drove 4 hrs total to pick them up.
    Tlar25 and SharkDog[QUOTED] like this.
  20. Aug 15, 2024 at 8:02 PM
    #1010
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    They actually came on the early 5th Gen trail editions as well, although in a lighter color (same difference between the darker 1st Gen Sequoia wheels and the lighter color Tundra 5 split spoke wheels) still not super common though. Once I'm ready for new tires I plan on swapping the TRD style wheels from my tundra with my 4th Gen 4runner that has these older trail edition wheels on it currently.
    SharkDog[QUOTED] likes this.
  21. Aug 16, 2024 at 3:19 PM
    #1011
    SharkDog
    SharkDog New Member
    Denver
    Whelp, they should have put them on some more.
  22. Aug 23, 2024 at 5:57 PM
    #1012
    Spike77777
    I have the same wheels and same tire size but only 1.5" front and 1" rear. How much bigger 285's?
  23. Aug 24, 2024 at 6:32 PM
    #1013
    Spike77777
    Do you have any lift front or rear?
    Stance looks good.
  24. Aug 25, 2024 at 3:48 AM
    #1014
    taranovich92
  25. Aug 25, 2024 at 7:50 AM
    #1015
    Spike77777
    Even better. What size did you go up to?
  26. Aug 25, 2024 at 7:57 AM
    #1016
    taranovich92
    285/70/17 tire. 3" lift in the front. About 2" or 2.5" in the rear.
  27. Aug 25, 2024 at 8:16 AM
    #1017
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    Limited/sequoia wheels I refinished. New caps. 1.25" spacers. 265/70r17 toyo at3s. Leveled on bilstein 5100s.20210324_192355.jpg
    The Black Mamba, abcinv and Tlar25 like this.
  28. Aug 27, 2024 at 2:15 PM
    #1018
    WTHamIdoing
    WTHamIdoing New Member
    Eric
    2001 tundra v8(2uzfe) auto extended cab
    Killmat entire cab Method 703 wheels King 2.5 coilovers w/ 700lb springs JBA UCA Coastal Off Road high clearance front/rear bumpers and sliders Dirty Deeds 250cc 12 hole fuel injectors
    bilstein 5100 2in. BFG KO2 275/70/17 E -- AFAIK stock rims but I rub on frame and UCA. I am looking at labor day sales for wheels and want to get a better offset for same tire size. What offset do yall think would clear me with no rubbing? I read megathread and have been trying to look at other peoples setups but haven't found the answer yet.
    The Black Mamba likes this.
  29. Aug 29, 2024 at 3:43 PM
    #1019
    Spike77777
    What method did you use to black out your wheels? I've been thinking about doing the same.
  30. Sep 15, 2024 at 1:23 AM
    #1020
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Not my truck. 4th Gen 4runner sport edition wheels
