Toyomafia - The Clubhouse. 151.880
  1. Aug 19, 2024 at 7:03 AM
    Florida AF
    Logan
    North Florida
    Yeah, my bill is not high because I have two units. It is high because we hold 70 degrees 24 hours a day. My little condo bill was cheaper, but it was better insulated. The last house was about the same with one unit, but it ran all the darn time.
    what little i know... higher seer, short run time harder draw. so to me it makes sense, but I am still trying to find an HVAC guy to explain to me wtf is going on at this house and potentially making a few changes.
  2. Aug 19, 2024 at 7:09 AM
    Higher seer should net shorter run time and lower amp draw; usually 2 stages of cooling and heating, but it only ramps to the second stage if set point isn’t being met in a certain time frame. 2nd stage is 100% power, so starting it on 1st stage is also much gentler on the compressors
  3. Aug 19, 2024 at 7:10 AM
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    appreciated
  4. Aug 19, 2024 at 7:18 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I feel like a bougie power hog all of a sudden. I keep it at 72 or 3 during the day (I work from home), but we drop it down to 68 at night. When the A/C is running 90% of the night on 71, but 92% of the night on 68, I don't get why the extra $3 should matter.
  5. Aug 19, 2024 at 7:24 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    ...or spring for variable stage units.
    ToyoMafia[OP] likes this.
  6. Aug 19, 2024 at 7:29 AM
    I think that’s what @Azblue did, his looks like a big inverter unit
    Azblue likes this.
  7. Aug 19, 2024 at 7:54 AM
    Azblue
    The Dirty T ( ^_^)_且
    Yep, but for some reason it just runs on high. Need to look into it, but too lazy.
  8. Aug 19, 2024 at 8:04 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Probably cuz you live in the BF crack of the center of the earth....
    Sorry, I mean cuz you live where it gets really hot :D
  9. Aug 19, 2024 at 9:16 AM
    That looks like a mini split unit. With carflex. Ewwww.
  10. Aug 19, 2024 at 9:18 AM
    Car flex is 100% code out here, and it amazes me. My sparky buddy says that’s a lot of his calls, replacing rotted flex with….. more flex!
  11. Aug 19, 2024 at 9:28 AM
    I hate carflex. I'll use sealtight all day long. But yeah, it dies in the sun like everything else. Just hard pipe it with EMT. Fuuuuuck iiiiiiit.
    Azblue likes this.
  12. Aug 19, 2024 at 9:34 AM
    Is sealtight different from car flex? They both don’t last long out here
  13. Aug 19, 2024 at 11:04 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    One thing ain't puzzling - they're expensive AF
  14. Aug 19, 2024 at 11:18 AM
    Sealtight is flex with a weatherproof coating, carflex is just the hard ass can't push wire in it flexible PVC. Sealtight is usually light gray with steel connectors, carflex is dark gray with plastic connectors.
  15. Aug 19, 2024 at 11:37 AM
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    damn right!
    TaquitoBandito likes this.
  16. Aug 19, 2024 at 11:42 AM
    SAGE63
    San Diego County
    I don't understand why but some dude in a Raptor was staring down my passenger side front suspension. Window down, head out staring at it...
  17. Aug 19, 2024 at 11:49 AM
    coTony
    Tony
    Montrose, CO
    I don’t get it either...
  18. Aug 19, 2024 at 11:53 AM
    AZBoatHauler
    So.Arizona
    Just got my bill Saturday. $625 - new record.
  19. Aug 19, 2024 at 12:01 PM
    RobertD
    Robert
    DFW, Texas
    :eek:
  20. Aug 19, 2024 at 12:02 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I'm resisting the urge to go look at mine...
  21. Aug 19, 2024 at 12:06 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I believe jealousy is the answer. i understand his pain
  22. Aug 19, 2024 at 12:08 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Damn... We're on the SRP plan where they average your bill over 12 months based on last year's usage. Been running about $175mo (2 AC's - 2900sq' - pool - just us 2).
    For us it's the other utilities that have increased significantly. Gilbert almost doubled the rates for water/sewer/trash earlier this year.
  23. Aug 19, 2024 at 12:10 PM
    Dear lord!
    TaquitoBandito, Mater and Azblue like this.
  24. Aug 19, 2024 at 12:21 PM
    I think I see a spot on your frame you can put some more Icon stickers.
  25. Aug 19, 2024 at 12:29 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Maybe he was thinking..
    “All those suspension upgrades and still running stock LCAs.. betcha they’ll get mangled”
    Too soon, Sid :boink::D
    PS: You have very nice front suspension
  26. Aug 19, 2024 at 12:32 PM
    SAGE63
    San Diego County
    lol Nick.. and thanks
    AZBoatHauler and Mater[QUOTED] like this.
  27. Aug 19, 2024 at 12:33 PM
    AZBoatHauler
    So.Arizona
    Insult to injury, zapped myself yesterday with 220 cleaning up around the pool pump. I’m not sure what kind of yelp I let out but Josh was concerned.
  28. Aug 19, 2024 at 12:34 PM
  29. Aug 19, 2024 at 12:35 PM
    SAGE63
    San Diego County
    Saving that spot for Toyo mafia sticker!
  30. Aug 19, 2024 at 12:36 PM
    SAGE63
    San Diego County
    Used to love those commercials and videos
