Factory TRD lift/sway bar drop…
Discussion in '3rd Gen Tundras (2022+)' started by mcahoon, Sep 21, 2023.
  1. Mar 31, 2024 at 12:30 PM
    #61
    LunarRckplati
    LunarRckplati New Member
    Tundra hybrid Platinum
    TRD 3 inch on 35's looking for TRD pro wheels!!
    Exactly my idea, I need to sell my TRD skid plate
    Worst part is I bought it a week ago and found out of won't work and Toyota won't let me return it. They installed it too...
  2. Mar 31, 2024 at 12:31 PM
    #62
    NoHater
    NoHater New Member
    I removed the front mid flaps and pinned the fender into the hole next to the crash bracket with body panel clips
  3. Apr 1, 2024 at 7:11 PM
    #63
    LunarRckplati
    Put the relocation bracket back in and it drives so much better. Still has the slight rub on sway bar. My next step is going 0 offset if I want to change the rub. Messing with the sway bar location doesn't make sense to lose drive quality.
    Better to just switch to a lower offset. I'll just put the nytop fender flares on if I go 0 offset.
  4. Apr 1, 2024 at 7:12 PM
    #64
    lapoolboy
    lapoolboy New Member
    Why not the 1" spacers for $149?
  5. Apr 1, 2024 at 7:21 PM
    #65
    LunarRckplati
    I have the spidertrax 1 inch spacer I received them today and that was what I was gonna do. It would make my wheels -7 offset. I figured that could be too negative.
    I don't want to have to trim or body chop.
    Wish I could find a half inch spacer! That was hub centric
    Also, I hear running spacers isn't a good idea.
  6. Apr 2, 2024 at 10:47 AM
    #66
    lapoolboy
    I just got the tires mounted....no rub on mudflap, felt liner, or swaybar. No spacers needed. 285/65R20 Ridge Grapplers on the TRD wheels. Looks WAY better now!
    tallg53 likes this.
  7. Apr 2, 2024 at 10:55 AM
    #67
    LunarRckplati
    Yes the best way to go for sure. Are you on the TRD 3-in?
  8. Apr 2, 2024 at 10:56 AM
    #68
    lapoolboy
    Yes. Factory-installed on a 2024.
  9. Apr 2, 2024 at 11:05 AM
    #69
    LunarRckplati
    very nice! post some pictures if you haven't already
  10. Apr 2, 2024 at 5:33 PM
    #70
    lapoolboy
  11. Apr 2, 2024 at 6:16 PM
    #71
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    I got a 4 Spidertrax spacers I need to get ride of if interested. Used em for about 2 weeks before I bought some wheels.
  12. Apr 2, 2024 at 8:21 PM
    #72
    LunarRckplati
    Any recommendations and brand or look?
  13. Apr 2, 2024 at 8:29 PM
    #73
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
  14. Apr 2, 2024 at 8:34 PM
    #74
    LunarRckplati
  15. Apr 3, 2024 at 4:41 AM
    #75
    mr_fusion
    mr_fusion New Member
    I dont know. But for me, I went with the toyo 35s wrapped on method 318's 17" with the 25 offset and that seems to be the sweet spot. The mudflaps do rub when i articulate , so I might remove them. But other than that I dont have any issue with the sway bar at full lock.
  16. Apr 3, 2024 at 6:42 AM
    #76
    lapoolboy
    Well, I spoke too soon. Turning into my garage hard to the left when I got home last night and the tire gets into the swaybar. I guess I'm ordering wheel spacers now.
    Has anyone tried just the Icon swaybar drop brackets to see if that works without having to do wheel spacers? I really don't want to remove the mudflaps and space the tires out any further if I can help it so I don't make a mess of the side of the truck/paint.
  17. Apr 3, 2024 at 12:14 PM
    #77
    LunarRckplati
    I have them, I ordered them and never even opened the package. I decided not to do it and just got new wheels and added fender flares.
    Im a -12 offset not and clear my sway bar. I pinned my liners back and in all clear.
    In going to return the icon spacers I didn't think an inch would do much.
  18. Apr 3, 2024 at 3:34 PM
    #78
    nyc2mtk
    nyc2mtk New Member
    24’ MGM Tundra Platinum
    Any thoughts about going with something like a +18 or +20 offset wheel?
  19. Apr 3, 2024 at 4:56 PM
    #79
    lapoolboy
    I'm keeping the OEM wheels. Just got to find a way to make them work. Seems like the 1" spacer others have used solves the problem.
    JGlock30 and nyc2mtk[QUOTED] like this.
  20. Apr 3, 2024 at 5:02 PM
    #80
    nyc2mtk
    nyc2mtk New Member
    Plenty of people have had good luck with them. I had a couple of unfortunate experiences on previous trucks where quality products were used they were torqued to spec and I had to check them a lot more then I cared for. If possible I would like to avoid them but again plenty have used them and had good experiences.
  21. Apr 3, 2024 at 10:16 PM
    #81
    LunarRckplati
    You'll rub on sway bar. Go 0 offset I went -12 with rough country fender flares
  22. Apr 19, 2024 at 12:13 PM
    #82
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Are you guys getting the sway bar rub with stock wheels because you went wide on tire size? I have 275/65/20 tires on stock wheels with trd lift and no rub whatsoever.
  23. Apr 19, 2024 at 3:04 PM
    #83
    NoHater
    NoHater New Member
    Yes, it's the larger and wider tire
  24. Apr 19, 2024 at 3:08 PM
    #84
    TundraLaw
    Northern Nevada
    Did you guys get a pretty rough ride in the first week or so with the trd kit? Went over a speed bump and it topped out, felt a little stiff.
    will the coilovers loosen up? was considering putting on 3in dobinsons IMS with this kit
  25. Apr 19, 2024 at 3:15 PM
    #85
    NoHater
    NoHater New Member
    The springs may settle a little bit, but I doubt you'll be able to feel a difference
  26. Apr 19, 2024 at 3:30 PM
    #86
    lapoolboy
    I have 285/65R20 and I rub the swaybar at full lock in forward only.
  27. Apr 19, 2024 at 3:31 PM
    #87
    lapoolboy
    My TRD 3" is the softest, plushest ride I've ever had with a lifted truck, even with the 10-ply tires.
    daverxa likes this.
  28. Apr 19, 2024 at 3:53 PM
    #88
    TundraLaw
    Northern Nevada
    I’m sure it’ll soften up. I might change things up and go icon sway bar drop instead of the trd sway bar drop, Dobinson’s IMS front and rear and coil spring.
    keep every other trd part including UCA.
  29. May 18, 2024 at 5:02 PM
    #89
    Unique
    Unique New Member
    2024 Limited Hybrid TRD Off RD
    Honestly spend the money on some wheels with a more negative offset. Do it right vs spacers.
    funtruck92 likes this.
  30. Aug 18, 2024 at 3:32 PM
    #90
    The Dutch Man
    The Dutch Man New Member
    I have a 23 Platinum with dealer-installed TRD 3" lift kit on 285/ 65 BFG KO2 stock rims and at full lock my swaybar rubs.
    I really don't want spidertrax spacers.
    Will the ICON 1" sway bar bracket blocks work? Will trying to get the truck aligned to the factory spec for the lift kit work? Here it is:
