General Supercharger Thread
  1. Aug 17, 2024 at 1:24 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    I have a new USB, I have tried different ports. I will try your suggestion later today. Thank you.
    koditten and Mdl like this.
  2. Aug 17, 2024 at 3:25 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Yep, Looks the same as what I got
  3. Aug 17, 2024 at 4:58 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Are you trying to log a large number of parameters at frequent intervals?
  4. Aug 17, 2024 at 7:07 PM
    Fastlane47
    Maryland
    2018 Platinum
    No, I don't save all of the logs, maybe five at the most at a time.
  5. Aug 17, 2024 at 7:21 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Ok ordered the Lexus coils from rockauto denso units. Going to also throw in some fresh o2’s while it’s apart.
    Silver17, AZTundra, e30cabrio and 2 others like this.
  6. Aug 17, 2024 at 7:41 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    what is rockauto charging ?
  7. Aug 17, 2024 at 7:47 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  8. Aug 17, 2024 at 8:00 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    My first time installing an AFR gauge on a 2.5 Gen (2021). I'm not a fan of the options out there, so came up with this:
    Little more dialing in, but so far has turned out absolutely awesome! Only took six revisions to make it fit how I wanted. And it's a single piece of flat patterned sheet metal.
    jhrrld, sbxx312, ARES35 and 15 others like this.
  9. Aug 17, 2024 at 8:01 PM
    bflooks
    bflooks New Member
    Metrowest MA
    reywcms likes this.
  10. Aug 17, 2024 at 8:08 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Sign me up! Caveat: no squeaks or rattles and the dial can be turned to split the difference between the HVAC and shifter.
    Mdl and snivilous[QUOTED][OP] like this.
  11. Aug 17, 2024 at 8:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice workmanship!
    ARES35 and snivilous[QUOTED][OP] like this.
  12. Aug 17, 2024 at 8:13 PM
    snivilous
    SW UT
    So far it seems squeak and rattle free, there's rarely a noise that might be coming from the back right corner of the mount so going to do some trimming tomorrow to see if that stops it. Can move the gauge where ever you want, I biased it higher since it's at a 45 degree angle so thought the wires would package better not coming out right next to the floor of it.
    ARES35, Fastlane47, e30cabrio and 3 others like this.
  13. Aug 17, 2024 at 8:21 PM
    snivilous
    SW UT
    Thanks Mike! I have a whole stack of prototypes where I would move stuff 1/8" trying to dial it in. I wanted it as close to factory looking as I could. I need to go back in tomorrow and clean up the plastics and some of the mount since stuff got scratched a bit trying to get this in. Getting the fitment so tight is a blessing and a curse when it comes to assembly!
    ARES35, Fastlane47, e30cabrio and 6 others like this.
  14. Aug 18, 2024 at 7:42 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Looks awesome brother
  15. Aug 18, 2024 at 8:35 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    reywcms and Mdl like this.
  16. Aug 18, 2024 at 9:48 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    reywcms likes this.
  17. Aug 18, 2024 at 10:51 AM
    e30cabrio
    The part number I searched came from my eBay purchase
    90919-02269
    reywcms likes this.
  18. Aug 18, 2024 at 10:56 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Seeing as the oem is a denso also I think the rock autos should be good. If yall didn’t lie to me about rock auto that is lol
    Tripleconpanna and Mdl like this.
  19. Aug 18, 2024 at 10:59 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    According to Jowett it's Lexus 90919-02269 or denso 673-1206. The Denso cross-references to the 02269.
  20. Aug 18, 2024 at 11:01 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was just referring to the part number you posted for the link to that AZ dealership. You showed the 90919-02260 instead of the 90919-02269
  21. Aug 18, 2024 at 11:02 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Rockauto.com had this part number
    e30cabrio, reywcms[QUOTED] and Mdl like this.
  22. Aug 18, 2024 at 11:07 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's a decent price.
    armyoffoo[QUOTED] likes this.
  23. Aug 18, 2024 at 11:08 AM
    e30cabrio
    Some more research shows this is the coil for the Turbo T24A-FTS in the Grand Highlander. FWIW
    armyoffoo likes this.
  24. Aug 18, 2024 at 11:14 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yea that’s what I ordered should be here Thursday
  25. Aug 18, 2024 at 11:15 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Running through the hit list
    nags, WinterWarlock21, ARES35 and 6 others like this.
  26. Aug 18, 2024 at 11:37 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    If anyone needs some brand new tundra packs lemme know lol
  27. Aug 18, 2024 at 3:54 PM
    snivilous
    SW UT
    Weird tuning experience with a 2021 today, and about shit myself. Uploading a tune revision at a gas station 1.5 hours from the house, and only halfway to the customer drop off. HP Tuners says it flashed it and go to start it and it just cranks, acting like there's no fuel whatsoever. I have no idea what's going on, and try to flash it again and get a controller error. I've essentially concluded it just bricked, but I go back to my basic checklist of things and restart and replug everything, and I flash the previous tune just fine!
    I get near the customers house, and decided to do all the tuning there in case it shits itself again at least I'm close. No issues. Drop off at customers house, and as we're leaving decide to do one final tune to really dial in the fuel trims from the last log. Truck does the same thing it did at the gas station, but this time I'm less freaked out so flash the same tune over again and it takes it.
    What the common denominator seems to be from these two fucky flashes and the ones that were fine? I opened/closed the door during the fucky flashes. Open/closes going into the gas station, and then closed the door during the flash at dudes house. Really weird, never heard of or seen that happen. More imperative than I thought to touch absolutely nothing during the flash!
  28. Aug 18, 2024 at 4:00 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    At this point I pretty much just stand there frozen, holding my breath and thinking happy thoughts until it says the flash was successful
    j_supra, VWTim, bflooks and 8 others like this.
  29. Aug 18, 2024 at 4:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I haven't heard of this with the newer trucks but know earlier models required door open during certain testing/programming.
    If door is open it stays open and vice versa, windows too.
  30. Aug 18, 2024 at 4:06 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I wonder, was that a push-to-start truck? Maybe that's something related to security? But ya, pucker factor there, huh. About all the braver I get is that I'll leave the radio playing at a low volume. I've never opened/closed the door though, I'm afraid that I'd knock the cord out of the OBD port, or yank the cord out of the laptop.
    ARES35, snivilous[OP] and Mdl like this.
