  1. Aug 12, 2024 at 4:05 AM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20x9 Vision brawls, 285/60 Toyo at3s, Bilstein 5100s, Tint, rock warrior grille, all chrome removed. fully paint matched, HID headlights, LED tail lights, LED fog lights, Doug thorley LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub,
    This is the ticket! An often overlooked step. Also make sure the clear coat is UV resistant, otherwise it will yellow with time.
  2. Aug 12, 2024 at 11:26 AM
    Yinzer73
    Yinzer73 New Member
    Menifee, Ca
    2011 Tundra 5.7
    None yet but the list is growing
    Check out my post on this thread #15558 and you can see the difference the Cerakote made for mine. Still as clear to this day.
  3. Aug 12, 2024 at 11:55 AM
    Greddy
    Greddy It was called the 80s!
    Cam
    Bonney Lake, WA
    2013 SR5 CrewMax
    Fox 2.5 Factory Race Series Resi Coilovers, SPC UCAs, Fox 2.0 Performance Resi Shocks, Roadmaster RAS, Coachbuilder +2” Shackles, Method 18” NV305s & 34” Falken Wildpeak ATW3
    Installed new Dobinsons Leaf Springs 330-770lb Load (P/N L59-121-R), U-Bolts, Greaseable bolts, Timbren Bumpstop spacers, and swapped out my CB +2" Shackles for CB +1" shackles.
    Still need to change out my Fox Shocks for longer travel ones. Overall I'm pretty happy the bottom picture is my trailer hooked up without the WDH bars hooked up, sitting pretty level!
    455107045_10107623528155533_691390520696_b67f34ea1bc06cd757c8cf5012a4a15fc765d03c.jpg
    454771977_10107623531169493_820819210949_2125ab1dd9b81dcf998277fcc103507bda910fa5.jpg
    454493248_10107623533514793_620006166923_5326dc5c5698c8c9faa18da671555c2ff878e500.jpg
  4. Aug 12, 2024 at 4:29 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    First coat of roll on bed liner. Went with a light gray color to tone the heat down a bit. Honestly I wish I went with a dark gray but at this point, that's not happening.
    D4x4TRD, Peeeheeuuu, dondino and 6 others like this.
  5. Aug 12, 2024 at 7:42 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    2 coats. Followed durabek's instructions. Sanded, cleaned with solvide, taped off the tailgate and went for it. Left the topper on with all my doors open for the whole process. Pretty easy overall and I'm happy with the results of the finished product. Took longer to wait between coats than it did to prep and paint everything. Just under 4 hours total. IMG_8608.jpg
    carn_dogg, Warreng, tyr0981 and 14 others like this.
  6. Aug 17, 2024 at 7:28 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    Not so much of did to it as did in it.
    The fam and I spent the afternoon floating in the Colorado River. Had fun rides getting there.
    My son-in-law's 2008 (left) and my 2011 (right).
  7. Aug 17, 2024 at 7:45 PM
    koditten
    Kirk
    Midland of the Mitten
    Question:?
    Does the '08 seem peppier than the the '11?
    I have an '08 and a '21. The '08 is much more peppier and fun to drive. I'm just curious how the same engine and drive train changed over the years.
  8. Aug 17, 2024 at 9:49 PM
    blenton
    blenton New Member
    Throttle mapping is the biggest change for ‘14+ trucks. Looking at the stock tune file between my ‘13 Tundra and my ‘15 sequoia, the accelerator pedal is dumbed down a little bit and they limit the some throttle angle opening in 1st gear. MAF is also mapped a little differently (more tame on the ‘15). There was also a pedal replacement for some years - maybe ‘10-‘12 - for a jumpy pedal; it included a new tune file to dumb it down as well.
    From what I’ve gathered, the ‘14+ tundras mimic my sequoia with gently throttle mapping and such, whereas ‘13 and earlier were ‘peppy-er’ mostly due to the tune. For fun, I matched my throttle settings from my sequoia to my tundra. Even with the SC it felt kind of like a dog until you really got on it.
  9. Aug 17, 2024 at 11:05 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    What put in and take it did you use?
  10. Aug 18, 2024 at 4:22 AM
    sctomfar
    sctomfar Chasing 700RWHP
    Tom
    Bluffton, SC
    Supercharged Reg cab
    Harrop 2650 supercharger TRD suspension TRD intake Custom exhaust Dirtydeeds cross pipe Fully built bottom end motor Manly Rods Crowder Pistons ARB Stud Kit National Speed Tuned Redesigned fuel system XAT Fuel Rails Twin Demon Fuel Pumps 83cc Injectors Morimoto Headlights
    Finally… it’s back. It’s been at Bodyshop for 6 months getting painted.
  11. Aug 18, 2024 at 5:24 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Looks good, need to lower it
  12. Aug 18, 2024 at 6:46 AM
    Thumper_6119
    I have noticed no difference between the two. Both have very responsive gas pedals, and both have quite a bit of scat on tap. They are both fun to drive.
    koditten[QUOTED] likes this.
  13. Aug 18, 2024 at 4:42 PM
    sctomfar
    Tom
    Bluffton, SC
    I totally agree… the bank is on empty for the time being. I thought about bags but I don’t think I want the potential hassle or the cost. Fortunately I don’t have to daily it so a harder ride won’t be a problem.
    OldGuy03 likes this.
  14. Aug 18, 2024 at 10:51 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    Is it sitting totally stock right now? Almost looks lowered already lol. Maybe look into the SOS performance rear only kit if you haven't already. (Can also do front and rear depending on your goals)
  15. Aug 19, 2024 at 8:22 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    The Sequoia grille and bumper look awesome with the Morimotos.
    Very nice truck sir.
    Edit: And it definitely looks lowered already to me
    OldGuy03 and Mountun Goat like this.
  16. Aug 19, 2024 at 5:26 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I'm terrible at documenting a process but I went over to a good friends who has a shop with a lift that I used to replace my brakes. Went with power stop z36 drilled and slotted rotors. On the drive home I got to test them out on vail pass and I will say they are well worth the upgrade price. Found them on rockauto for 25% off last week.
  17. Aug 19, 2024 at 5:55 PM
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    2007 Tundra and 2011 Sequoia
  18. Aug 19, 2024 at 6:06 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    :muscleflexing:
    Tripleconpanna likes this.
  19. Aug 19, 2024 at 6:48 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Did you do the recommended bedding in procedure? Lol. It seems excessive but I put a set of Z36s on my Dad's Sierra and did the whole thing. Not sure if it made a difference but they work great and he's happy.
  20. Aug 19, 2024 at 7:09 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I did. I thought it also seemed excessive but I could tell a difference before and after the break in process. Backing out of his shop I could hear squealing coming to a stop. After the break in they function as should and definitely better than oem.
    Mdl likes this.
  21. Aug 19, 2024 at 9:02 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I ran those on my '08 when I was towing... I went through the procedure and had a good service life from them, but when the pads started to get low, one of them almost completely disintegrated :notsure: Not sure it was really anything more than just 'one of those things' that happens....
    The set up served me well though; rotors held up much better than OE (warping), no chattering, excessive noise or brake dust, etc....
  22. Aug 20, 2024 at 9:18 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I don't tow often but do have some fairly heavy loads when we do river trips across the country. 4 people, 2 rafts, all the gear, food and ice add up quickly. Then adding beer and whiskey weight.
    When not towing I'm still driving up and down passes all spring and summer just to do day runs. Having lived here most of my life and putting over 300 k on my first gen I can definitely tell the difference in how this bigger truck is hard on brakes. I don't ride my brakes at all either, s mode going downhill. My hope is what you said about your experience with them compared to oem. I'll keep an eye on pad thickness as I rotate tires so I don't have one disintegrate on me.
  23. Aug 20, 2024 at 2:00 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    When we do brakes at our shop we always burn the pads in, def does help
  24. Aug 20, 2024 at 3:37 PM
    SAGE63
    San Diego County
    Used it for truck stuff.... moving son into college Apartment.
  25. Aug 21, 2024 at 5:46 PM
    Retroboy1989
    Northern Utah
    100% it helps. It's a must.
  26. Aug 21, 2024 at 6:37 PM
    koditten
    Kirk
    Cor me skeptical.
    Been doing my own brakes for 30 years. I've never " bedded and burned" the pads.
    Let's just say for a daily driver, I can't see the advantage.
    I'm willing to be convinced that it helps.
  27. Aug 21, 2024 at 10:14 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I can't explain it as far as mechanics go but I will say that after bedding them in they seem to work better, and don't have any squeak to them. They have some good bite to them and are working great.
  28. Aug 22, 2024 at 1:55 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Bedding the brakes in transfers brake material on to the rotor creating more friction. It can happen over time, but you can also risk glazing the rotors by not doing it. Different manufacturers have different procedures, but independent tests prove it’s worth doing.
  29. Aug 23, 2024 at 11:06 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    That looks really good, amazing transformation. You went from what year to what year?
    I agree. I have both SOS lowering kit and airbags on my ‘07 SR5. Handles better, rides smoother.
    Not that expensive and I did it myself.
    j_supra[QUOTED] and OldGuy03 like this.
  30. Aug 23, 2024 at 11:19 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    You did rotors and pads? Not calipers? Does Rock Auto sell ‘loaded calipers’? I do know that
    don’t scrimp on pads, there is definitely quality differences. My ‘10 had brakes put on and I can
    only guess they said ‘cheapest ya got’, cause rotors are chipping and surface is cracked at vent
    post locations. So I’m needing new brakes after less than 2000 kms.
