4.9L 2uz Turbo build, I have questions
Discussion in '1st Gen Tundras (2000-2006)' started by VR6T, Aug 3, 2024.
  1. Aug 9, 2024 at 2:09 PM
    #91
    VR6T
    VR6T [OP] In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Maybe I clicked the wrong one but they have a 2uz to transmissions were talking about
  2. Aug 9, 2024 at 5:56 PM
    #92
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  3. Aug 9, 2024 at 6:26 PM
    #93
    VR6T
    5 or 6 speed. 6 speed would be stellar but I'd settle and be very happy with a 5 speed
  4. Aug 10, 2024 at 9:05 PM
    #94
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    a760f is bascially a a750 with an extra gear. its fairly strong. but a shift kit is a must for power to survive. same gear stack 1-5. just an extra overdrive
    FishNinja and 455h0le_dachshund like this.
  5. Aug 11, 2024 at 3:37 AM
    #95
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Sounds like your saying cd009
    Mr.bee likes this.
  6. Aug 11, 2024 at 6:05 AM
    #96
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    lenco or bust.
  7. Aug 12, 2024 at 11:34 AM
    #97
    My work truck is a 4.6 and it is 2wd.
  8. Aug 12, 2024 at 11:42 AM
    #98
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    To be clear I was being facetious, of course there are 2wd 4.6 Tundras. But the suffix "F" always means 4wd on an Aisin trans code and suffix "E" is 2wd.
  9. Aug 12, 2024 at 9:48 PM
    #99
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    2 under driven m90's might be better than an overdriven m90.
    Run 4 literbike throttlebodies through each blower, ethenol or methenol spray in the plenum to help cool the hot side. And slightly tweaked rocker arms to open one of the intake valves right before the other to induce swirl.
    widening the lobe separation angle usually flattens the torque curve (or maybe opposite) but a wide flat torque curve would do good with an auto trans and towing. Yea, a turbo would be better, but if you use 2 different blowers (or the blowers with different pulleys) it would have a warble. And that would be cool to flutter through a cars & coffee.
    bmf4069 and 455h0le_dachshund like this.
  10. Aug 13, 2024 at 5:45 AM
    #100
    You have entirely too much time on your hands.
    BroHon and 455h0le_dachshund like this.
  11. Aug 15, 2024 at 3:00 PM
    #101
    VR6T
  12. Aug 15, 2024 at 8:23 PM
    #102
  13. Aug 15, 2024 at 8:35 PM
    #103
    VR6T
    They're my go to, I was just looking at other options. Lol.
    bmf4069[QUOTED] likes this.
  14. Aug 15, 2024 at 8:42 PM
    #104
    I'll be following what you do. I'm having visions of a 2uz with a tremec behind it after seeing the Vic.
  15. Aug 16, 2024 at 5:55 AM
    #105
    FishNinja
    Lee
    06DC2wd
    I wonder what an high compression 2uz would sound like with ITB's..................... And a cd009
    or something with straight cut gears
  16. Aug 16, 2024 at 6:14 AM
    #106
    loud. My buddies 2003 Camaro SS had straight cut gears in the rear. Wow, loud. My father in laws side by side had weak gears in it and they blew, the fix is an aftermarket straight cut set. Loud. But I like mechanical noises, so I don’t mind.
    bmf4069 and FishNinja[QUOTED] like this.
  17. Aug 16, 2024 at 6:45 AM
    #107
    FishNinja
    Lee
    06DC2wd
    I mean yea....I just wanna hear a high compression 2uz screaming at 6-7k with straight cut gears and ITb'sgoing down a long straight. Lol
    bmf4069 and KNABORES[QUOTED] like this.
  18. Aug 16, 2024 at 8:07 AM
    #108
  19. Aug 16, 2024 at 10:18 AM
    #109
    FishNinja
    Lee
    06DC2wd
    Mr.bee, bmf4069[QUOTED] and VR6T[OP] like this.
  20. Aug 16, 2024 at 10:24 AM
    #110
    VR6T
    I would be lying had I said I never thought of it and then tried to source the parts........
    bmf4069 likes this.
  21. Aug 16, 2024 at 6:03 PM
    #111
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Gsxr 1000 throttlebodies would be enough.
    busa carbs for the win, tho.
    Riverdale21 likes this.
  22. Aug 16, 2024 at 6:16 PM
    #112
    VR6T
    Like how would one let's say use those in a turbo application. The ITBs that is. Not sure it's possible
  23. Aug 16, 2024 at 6:20 PM
    #113
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Its possible, just difficult. And itb's are more of a short-runner high-rpm thing. Not really fit for your task. The stock intake runners are pretty long, good for torque. Each pulse of air is heavier, takes longer to get moving, but has more weight behind it.
  24. Aug 25, 2024 at 3:59 AM
    #114
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  25. Aug 26, 2024 at 3:48 PM
    #115
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  26. Aug 27, 2024 at 10:37 PM
    #116
    VR6T
    I can't view it don't have FB.
  27. Aug 27, 2024 at 10:49 PM
    #117
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    $600 in stephenville
