Hello all. I just inherited a 2003 Toyota Tundra and have started the repairs.
Discussion in '1st Gen Tundras (2000-2006)' started by 2003 inherited Tundra, Aug 13, 2024.
  1. Aug 13, 2024 at 6:41 PM
    2003 inherited Tundra [OP] New Member
    Martin
    2003 Toyota Tundra
    I need help figuring out what this part is. Any help is welcome.
    Jack McCarthy and Black@Blue19 like this.
  2. Aug 13, 2024 at 6:47 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    E brake I think,,, but that rear end looks shot!:(
    I would not drive it like that?
  3. Aug 13, 2024 at 6:48 PM
    Martin
    2003 Toyota Tundra
    Im putting in a new rear but I did not have that part
  4. Aug 13, 2024 at 6:48 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I'd start with the frame rust. Looks to be pretty encompassing and you may not even need to repair anything. I also believe it's an ebrake.
    edit. Use a hammer to see if the frame is still salvageable.
  5. Aug 13, 2024 at 6:51 PM
    Martin
    2003 Toyota Tundra
    Replacement rear going in soon
  6. Aug 13, 2024 at 6:52 PM
    Black@Blue19
    Ken
    SE Texas
    I am pretty sure some things might be upgraded by now. I would see about doing away with some of the older things and see about getting a touch of newer on it? Such as an emergency brake assembly. But on the other hand if you can find a whole unit it might save time and money.
  7. Aug 13, 2024 at 6:53 PM
    Martin
    2003 Toyota Tundra
  8. Aug 13, 2024 at 6:55 PM
    Black@Blue19
    Ken
    SE Texas
    Very nice!!!:)
    dang did you find that new at a yard??
  9. Aug 13, 2024 at 6:56 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Was going to ask the same question. Is this a reman unit? Looks clean.
  10. Aug 13, 2024 at 6:58 PM
    Martin
    2003 Toyota Tundra
    I bought the casings on eBay from AZ and ordered the other parts
    Black@Blue19 likes this.
  11. Aug 13, 2024 at 7:00 PM
    Black@Blue19
    Ken
    SE Texas
    WOW!!! That is so cool!!!!:). Very nice! You have it all under control. Please keep us up to date it’ll be nice to see it finished!
  12. Aug 13, 2024 at 7:01 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Pictured part is the LSPV bracket and adjuster. shown in red.
    White is the e brake cable.
    @OldGuy03 @Black@Blue19 you guys ever been under your truck?
  13. Aug 13, 2024 at 7:04 PM
    Martin
    2003 Toyota Tundra
    Thank you for your help it was the LSPV bracket that I was stumped on
  14. Aug 13, 2024 at 7:06 PM
    Black@Blue19
    Ken
    SE Texas
    Not an 03 I thought that attached to the brake behind tire, that thing is 23 years old
    close though it still has sumtin to do with the brakes?????:)
    OldGuy03 likes this.
  15. Aug 13, 2024 at 7:06 PM
    JakeJake
    2000 Tundra AC 4X4
    BroHon and shifty` like this.
  16. Aug 13, 2024 at 7:13 PM
    Start at the beginning of the thread @JakeJake posted. It has everything you must know and more.
    BroHon and Black@Blue19 like this.
  17. Aug 13, 2024 at 7:40 PM
    Black@Blue19
    Ken
    SE Texas
    Since you seem to be mechanically inclined I thought you might like to see this. I do not know why I thought of this but here you go.
    One of the upgrades :)
    I do not know anything about an 03 absolutely nothing!:)
    Just an FYI
    https://m.youtube.com/watch?v=C-sAsgDWJKw
  18. Aug 13, 2024 at 7:59 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Won't be the last time I'm wrong. My first gen was an 06.
  19. Aug 14, 2024 at 9:07 AM
    Martin
    2003 Toyota Tundra
    Well i found all of the replacement parts now. Thank you all for your help and advice
  20. Aug 14, 2024 at 9:25 AM
    I see after looking back over this thread, you've made a few classic mistakes covered (for a reason) in the new owner megathread.
    • Rancho shocks: Avoid for these trucks. The lower shock bushing blows out, often within a few thousand miles of driving. We have one member on here who was going on his 3rd pair up front, and finally gave up. We've had several others come here for suspension advice or help whose lower Rancho bushings were obliterated. It's garbage, and sadly, Bilstein 5100s are only fractionally more expensive.
    • fleaBay and scAmazon are rife with subpar parts, and littered with counterfeits. We've seen droves of people on here over the years who've had issues with both cheap/generic aftermarket, and even knockoff OEM parts, from both platforms. Shit part about it with eBay, specifically ... say those ABS sensors cause an issue with braking, one of the most important safety systems in your truck other than the airbags. Do you think fleaBay seller "Parts-Proper" will be stepping up and covering your loss, or replacing the part in the event there's issues? fleaBay won't take any responsibility for damages, nor step in and intervene if the part is faulty. Several members on this forum have received counterfeit spark plugs (not just in the 1st gen subforum, but site-wide!)
    • Stick with OEM for electronics: For example, coil packs, OEM coilpacks have been tested on this very forum to throw significantly hotter and more consistent spark than even moderate quality parts store brands. People have had issues with aftermarket temp/pressure senders. We've seen startup failures (and lots of money wasted) due to store bought aftermarket start/fuel pump relays that were supposed to work. Continued codes after using aftermarket O2 or air/fuel ratio sensors. ABS/wheel speed sensors are one of those I wouldn't trust aftermarket.
    • Honorable mention: Any part that takes more than 1hr to replace or requires collateral replacement (fuel pump, starter, SAI pump, etc.) always go with OEM to avoid having to do the job again in a couple of months or years.
    I'll be interested to see how you pan out with that stuff. If your OEM ABS sensors aren't clearly defective, I'd leave them in and return the generic no-name brand you bought. It's pretty clear based on the body they're inferior construction to OEM. But that's why OEM has lasted 20 years already...
  21. Aug 14, 2024 at 9:34 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Cool project - much more than I would be able to do myself!
  22. Aug 14, 2024 at 10:05 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Shocks listed by OP are also for 0 inches of lift, they won't be long enough.
    Also OP the front spacer lifts are known to make the truck ride a bit wonky. Good cheap option but ride quality may suffer a bit.
    Don't throw out your OEM front axles either. They are far superior in quality and you can replace the boots on them.
    Also new OEM lower ball joints and timing belt change should be on your to-do-list somewhere.
  23. Aug 14, 2024 at 12:31 PM
    Shit, I didn’t even see the CV Axles in his list. He’s in for a world of disappointment with the replacements :rofl:
  24. Aug 14, 2024 at 1:35 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    My 06 rear end looks damn wel near identical as that 03
  25. Aug 14, 2024 at 7:22 PM
    TundraBrew
    TundraBrew New Member
    NIce project. Post up a build thread so we can follow along.
  26. Aug 14, 2024 at 7:32 PM
    I’d be concerned about the spare tire and cable holding it up. Has it been replaced under the recall?
  27. Aug 15, 2024 at 7:41 AM
    Martin
    2003 Toyota Tundra
    I truly don't know that answer since it was my step father car. And i know he wouldn’t know at all
    Jack McCarthy likes this.
  28. Aug 15, 2024 at 8:04 AM
    You can look up the service history on the Toyota website for your truck and whether the truck was seen for the recall or not.
  29. Aug 15, 2024 at 8:09 AM
    Yup, more info on how to do that is in the thread @JakeJake and I both linked.
    JakeJake likes this.
  30. Aug 16, 2024 at 6:34 PM
    socomoby
    socomoby New Member
    2006 DC V8/2WD SR5 LSD
    Those aftermarket CVs are going to bring a bad time.
    I believe with your fortitude to go head first you’ll bring a lot of good to your ride. But please listen to the advice in here. If it’s electronic or the job will be time consuming, go OEM all day
