Tundra color matched grill ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by FabioXc, Aug 8, 2024.
  1. Aug 8, 2024 at 5:23 PM
    FabioXc
    FabioXc [OP] New Member
    None
    Just looking for a super white color matched grill any websites ?
  2. Aug 8, 2024 at 5:39 PM
    RobertD
    Robert
    DFW, Texas
    Like, the grille insert is white or the surround piece is white?
    If the former, sounds like a custom paint job. Not sure that was ever offered in white.
    If the later, just ender your paint code (found on the sticker in your driver door jam) and tundra grille surround on Google. Might have to give it a year but you should start seeing options.
    FabioXc[QUOTED][OP] likes this.
  3. Aug 8, 2024 at 7:35 PM
    FabioXc
    None
    Ah I see thanks cuz what I really want is a 2018 grille surround that is white
  4. Aug 8, 2024 at 7:52 PM
    RobertD
    Robert
    DFW, Texas
    From Toyota it looks like 350ish but eBay and other sources have it for sub 200.
    This does not include the emblem! But with your truck not having the sensor in the grille, you can get one of the custom designs that fits the space and not pay for the Toyota T emblem that allows the sensor to function.
    https://www.ebay.com/itm/2356654943...gs8dhss4rU_0HEVyFzMvXV1_MmzVYDgtInRFmyVG8EHcA
  5. Aug 8, 2024 at 7:56 PM
    FabioXc
    None
    Thanks man where could I get that emblem ?
  6. Aug 8, 2024 at 8:04 PM
    RobertD
    Robert
    DFW, Texas
    The Toyota one can be from a Toyota parts distributor or ebay. I was just saying that since you don't have a sensor you can find one of the fun custom ones
    Example of the emblem, its more then the grille and surround...
    https://www.ebay.com/itm/1162378306...MI5ZH1-vXmhwMVSlR_AB3u-xIzEAQYAiABEgJcK_D_BwE
    Be aware that emblems changed how they mount. Not huge for you since you don't have a sensor you could make it fit without issue. Just being up front that the grille and emblem might not fit since its hard to tell online which option you are getting.
  7. Aug 8, 2024 at 8:09 PM
    FabioXc
    None
    Thanks bud yeah I know it’s hard really to tell. The thing that Iam hoping that is easy is the 2018 grille is easy to put on a 2016 . do the 2018 grilles have the same mounts or u gotta modify ?
  8. Aug 8, 2024 at 8:18 PM
    RobertD
    Robert
    DFW, Texas
    So the surround will fit from a 2013 to 2021, and the grille insert is interchangeable from the surround. In 2018 they added the TSS sensor behind the grille emblem and since the sensor has to work thru it, its cost went up. I'm not sure the emblem from your grille is removable, it might just be part of the insert (I'm not as familiar with the earlier inserts). I have the TSS so I've paid attention to the joys the emblem change created
  9. Aug 8, 2024 at 9:20 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Are you looking for this style grille?
  10. Aug 8, 2024 at 9:22 PM
    FabioXc
    None
    Yes sir just like that but with the grille surround that is super white
    TacomaTRD4x402 likes this.
  11. Aug 8, 2024 at 9:30 PM
    TacomaTRD4x402
    Southern California
    You can try searching OfferUp or Marketplace. As @RobertD said, the surround will fit any grille '14 - '21. The white surround should be easy to find. Search junk yards or Tundra part outs. Alternatively, most people may recommend bumpershellz if your looking to dechrome your truck.
    By chance, where are you located? Anywhere near So Cal?
  12. Aug 8, 2024 at 9:32 PM
    FabioXc
    None
    Iam in Arizona but yeah I’ll check offer up or I’ll look in junk yards that’s a good idea
  13. Aug 8, 2024 at 9:33 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  14. Aug 8, 2024 at 9:38 PM
    TacomaTRD4x402
    Southern California
    The grille I posted a picture of is one I got from a '18 part out. I got it mainly to experiment on for when I upgrade to a Pro grille for my '18. I ended up taking it apart to learn how to safely do so without breaking any tabs. I ended up painting the chrome surround to match my MGM and it didn't come out half bad. I actually just today installed my pro grille and I used the painted surround. I'll see tomorrow how it looks in the daylight. It's most likely not a perfect match but it looks pretty close. Anyways, there's lots of options for you. This is the best place to find out all about them :thumbsup: I know I did
    sotasty8 and FabioXc[OP] like this.
  15. Aug 8, 2024 at 9:40 PM
    FabioXc
    None
    Thanks bud !
  16. Aug 9, 2024 at 7:34 AM
    Snert
    Snert New Member
    2021 SR5
    I don't see that it's posted yet, but here's a link to the 2.5 gen parts megathread: Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21) | Toyota Tundra Forum (tundras.com)
    If you scroll down to the 2018 TRD Sport Grille Section, it outlines what you need to purchase a la OEM parts.
    Someone can correct me if I'm wrong, but it looks like this is everything you'd need:
    Super White grille surround with TRD honeycomb insert $343: 53101-0C031-A0 - Grille Assembly - 2020-2021 Toyota Tundra | OEM Genuine Toyota Parts (oemgenuineparts.com)
    Emblem $204 (As RobertD said, you might be able to reuse your current emblem, or find an aftermarket one for cheaper that fits): 90975-A2014 - Grille Emblem (Front) - 2020-2023 Toyota | OEM Genuine Toyota Parts (oemgenuineparts.com)
    Super White hood bulge $248: 76180-0C030-A0 - Hood Molding - 2014-2021 Toyota Tundra | OEM Genuine Toyota Parts (oemgenuineparts.com)
    Small panel for top of grille $20: 53113-0C010 - Grille, Radiator Side, Left - 2018-2021 Toyota Tundra | OEM Genuine Toyota Parts (oemgenuineparts.com)
    All totaled for brand new OEM parts you'd be looking at ~$815. If you could reuse your emblem or find a cheaper one, knock off $200-?.
    I also did a quick Google search of "2016 Tundra SR5 white grille", and it looks like there are various listings on Ebay for the grille and hood bulge for under $300. Factor in emblem re-use or aftermarket emblem and you'd probably be around $400 total. I can't speak to the quality of a knock-off Ebay grill though, biggest thing I'd worry about is the paint job, not so much the plastic itself, but white's probably the most likely to match well. Would still need to get an emblem and the cover for the top, although the top cover is to cover this connector which goes to the emblem for TSS stuff in the new trucks. If your truck doesn't have a connector here, you could probably skip the cover and save another $20 without any negative effect, but don't take my word for it lol.
  17. Aug 9, 2024 at 7:58 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    Search 90975-A2014 in ebay. Anything under $100 bucks, usually has a broken tab but they still work with no issues. I tried looking for ever on FB marketplace and could not come across anything. Anything from the dealer is like 200 bucks. I ended up getting on ebay myself for 80 with a broken tab and it mounted fine
    FabioXc[OP] likes this.
  18. Aug 9, 2024 at 8:28 AM
    FabioXc
    None
    Thanks man
  19. Aug 9, 2024 at 3:57 PM
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
    Sparks parts is where I got mine.
  20. Aug 9, 2024 at 4:17 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    I bought the color matched grill, bulge and new TRD headlights from Fred Anderson Toyota during the Memorial Day sale for 20% off plus free shipping. They had a sale July 4th also, I expect that will have a Labor Day sale also. Way cheaper than eBay also.
  21. Aug 13, 2024 at 1:06 PM
    sotasty8
    sotasty8 New Member
    Stephen
    2016 Toyota Tundra Pro
    Pics?
    I too am looking for options to update the look of my 16 Pro,, Can you post what is the exact trim for that 18 grille insert in the pic? thx!
  22. Aug 13, 2024 at 1:19 PM
    TacomaTRD4x402
    Southern California
    OP, the image I posted in post #9 is what I actually have for sale right now. I know you said you live in AZ but if you ever come out
    Sure. This is my truck prior to swapping to the Pro grille...
    Before
    After...
    This thread will give you more info about swapping...
    https://www.tundras.com/threads/the...ifferences-and-what-you-need-for-each.121515/
    If your Tundra is a Pro than you likely have the 1st version of Pro grille already.
    This is the outer trim(surround) that I painted from the part out. It's not perfect and not recommended to paint over chrome but gonna see how long this lasts me. I have my factory painted one set aside should I ever need or want to go back.
    Snert likes this.
  23. Aug 13, 2024 at 1:45 PM
    sotasty8
    sotasty8 New Member
    Stephen
    Thanks for these, and the details! I'm actually looking to change over to an option similar to the one you're selling (the honeycomb style) but I too live in AZ..
  24. Aug 13, 2024 at 1:56 PM
    TacomaTRD4x402
    Southern California
    Since your looking to swap, i'm sure you'd find someone on here that would take you up on a trade offer. If you have the Pro grille, you'll likely find someone quick on here. Looks like you may not be able to post in the classifieds section yet but maybe in the AZ region or the thread that I linked.
    Also check out post #16 by @Snert. The first link he provides has all the part numbers needed should you chose the factory brand new method. Oherwise, you can go the inexpensive route like me and piece it all together from part outs.
    sotasty8[QUOTED] and Snert like this.
  25. Aug 13, 2024 at 2:02 PM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    I had the chrome style, I wasnt looking to change it, but came across some good deals. Then i said screw it, ill change it. I dont know why i fought it lol
  26. Aug 13, 2024 at 2:32 PM
    Snert
    Snert New Member
    2021 SR5
    What steps did you take to paint it? Degrease, sand, mineral spirits, adhesion promoter, paint, clear, and most importantly a few Coors Banquets :rofl:
    Picking up a pair of color matched bumpers in a couple weeks from a guy that took them off his pro. Debating spending the money to just get all new OEM grill + surround, hood bulge, and sensor cover since my truck has the TSS stuff. Other option would be to paint my chrome surround and bulge and get one of the knock off TRD inserts and save $400-600 depending on if the aftermarket TSS garnish cover causes issues as it seems like they're hit or miss.
  27. Aug 13, 2024 at 3:00 PM
    TacomaTRD4x402
    Southern California
    Aww man I got tired of just reading all those steps. :rofl: I'm far from a pro when it comes to painting. I just scuffed up the chrome and hit it a few times with the right paint, let each coat dry well enough then I hit it was a couple layers of clear coat. A few weeks later(maybe a couple months) I wet sanded it n it honestly didn't come out too bad IMO. Will it last forever? Probably not, but this is just a spare piece that I had to be able to play around with.
    This is the paint I used...
    And this is a close up shot of the comparison..
    You can see the difference.
    If it becomes an eyesore, I'll switch back to my factory surround
    Snert[QUOTED] likes this.
  28. Aug 13, 2024 at 5:14 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You can see the difference in my OEM parts.
    Part of it is light reflection, but part is the color is tad off..
    Been on the truck since 2015.
    The average Joe Blow on the streets isn't going to notice..
    Stock in 2014
    713A8B9C-FDF8-4EAE-B363-D750EB6E34E7_zps_8974aaed102cb248ae5024f52bf9f79723514a29.jpg
    Recent pics after OEM LED headlights and bumper covers.
  29. Aug 14, 2024 at 6:03 AM
    TacomaTRD4x402
    Southern California
    OP, I believe you said you're in AZ but just found this browsing thru OfferUp out here in Lake Elsinore...
    https://offerup.co/LP8eVgOu3Lb
    Maybe if you know anybody or here in So Cal they can snag it for ya.
    @sotasty8 not sure if you're looking for white also but there ya go too
    sotasty8 likes this.
  30. Aug 14, 2024 at 8:40 AM
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    TacomaTRD4x402 and FabioXc[OP] like this.
