2022 SR5 Check Engine Reduced Power
Discussion in '3rd Gen Tundras (2022+)' started by gntreg, Aug 7, 2024.
  1. Aug 7, 2024 at 9:00 PM
    gntreg
    gntreg [OP] New Member
    2022 SR5 TSS
    Howdy Guys,
    I had my 2022 SR5 malfunction today. 73,775 miles on the odo, mostly highway miles, light towing, maintenance routinely performed by Toyota service, per their recommended service intervals with the exception of a 1k mile oil change that I asked for.
    While passing on a two lane highway the power dropped out. A message appeared saying “check engine reduced engine power visit your dealer”. When I tried to give it more power the truck would shutter horribly. I took pics of the dash and a video of the rough idle (sounded like a mini diesel) once I got stopped and was waiting on a call back from the dealership. There was a burning smell once I got out of the truck somewhere between burnt oil/electrical. It was an odd smell. There was a check engine light that was flashing and the infotainment screen was giving warnings to call dealer. I turned the truck off and immediately restarted it to no codes and a smooth idle.
    I started driving towards the dealership. I drove the truck for approximately 6 miles and by this time had my wife behind me so decided to give it some throttle again to see if it would replicate. This time the truck completely shut off. No power steering, no brakes, but everything inside was working…dash, screen, ect. I was able to get the truck restarted again and drove slowly the rest of the way to the dealership.
    the truck has had a intermittent rough idle since I purchased it new. The dealer has never been able to replicate the issue. So nothing has been done to remedy this.
    I came home to the notice in the mail that my truck is one of the affected vehicles for the engine replacement.
    The dealership is going to diagnose tomorrow, but my advisor (who has been great to work with for the last couple of years) does not think this issue is related to the engine malfunction since the truck restarted and was able to drive to the dealership.
    any thoughts or similar situations? Everything I have been able to find seems to be trucks that shutoff for the reduced engine power and then require a tow into the dealership.
    I will try and post the videos of the dash and engine idle.
  2. Aug 7, 2024 at 9:05 PM
    gntreg
    2022 SR5 TSS
  3. Aug 8, 2024 at 1:22 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Sorry to hear this. Most important thing is that you're safe, especially since you said there was no brakes and no power steering.
    Not sure what exact issue your truck is having, but the only one issue that is known about this engine is the motor loosing power and bearings are spun/seized. The only other issue is turbos, but that seems to be rare.
    Make sure to push for long block (as per recall) if they need to replace the engine and try to avoid them rebuilding with the short block.
    troutback and ColoradoTJ like this.
  4. Aug 8, 2024 at 4:05 AM
  5. Aug 8, 2024 at 4:36 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Newer engines are a big ball of sensors. Any of which can throw itself into limp mode to protect itself. The causes are pretty vast from trivial to total FUBAR
  6. Aug 8, 2024 at 5:35 AM
    gntreg
    2022 SR5 TSS
    the dealer did tell me that my truck will be receiving a full new engine per the recall whenever available, regardless of what todays outcome is. That is somewhat reassuring. The rough idle has made me nervous since owning the truck.
    I have found one other thread that had the total failure and in the few days leading up to complete failure he started having very similar issues to what happened to me yesterday. Truck would die, restart, keep driving, until it didn’t. Regardless, my truck is for sure one of the 100,000 that are part of the recall so there is a good chance that this is what happened/is happening. The dealer did confirm the truck would be part of the recall.
  7. Aug 8, 2024 at 7:32 AM
    Breathing Borla
    Northern Illinois
    sounds like the guy who had a misfire, there is a thread around there somewhere with it
    with that many miles, did you do your plugs at 40K? should be almost to the second set
  8. Aug 10, 2024 at 1:08 PM
    gntreg
    2022 SR5 TSS
    No word back from the dealer yet on the issue. Hopefully I will have answers early next week.
  9. Aug 10, 2024 at 1:47 PM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Any change in oil pressure that you noticed?
  10. Aug 10, 2024 at 10:51 PM
    gntreg
    2022 SR5 TSS
    I was able to grab a picture of the gauge from the Live Photo. I believe that is pretty much where it has always read.
    BoulderGT3[QUOTED] likes this.
  11. Aug 11, 2024 at 4:42 AM
    BoulderGT3
    Glen
    Looks about normal for warm engine and 2k rpm to me too.
    Good luck at the dealer.
  12. Aug 11, 2024 at 5:37 AM
    Markysharky
    Markysharky New Member
    Oil pressure looks low. At idle warmed up that would be normal, at 2k it usually reads in the middle.
    Ausfahrt likes this.
  13. Aug 11, 2024 at 6:22 AM
    j-utah
    j-utah lost member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    Same, I think my pressure gauge only looks like that at idle and stopped at a signal.
  14. Aug 11, 2024 at 9:13 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My oil pressure gauge sits at that point as well. It might pop up to halfway when first started but will sit at about 1/4 afterwards.
    There were some issues with these analogue gauges with the early trucks and I think a TSB came out. I took mine in to see about the gauges including the fuel gauge and the service department didn't know anything about the issues so I handed them a print out of the TSB and after a while they told me that Toyota hasn't given them the software to fix the issue but check back in 6 months!
    If the oil pressure drops to a dangerous level, I am sure the gauge would be the last thing to tell you. You should see the red oil light pop up first.
    This would be a good place to add a Scangauge or additional gauges that actually work.
    I am not too sure how accurate the digital gauges in the digital cluster are, but I am sure they look cool!
  15. Aug 12, 2024 at 12:18 PM
    gntreg
    2022 SR5 TSS
    Just received a call from Toyota. They cannot replicate the issue, however there is a code for a misfire on multiple cylinders. They are thinking bad fuel, and are pulling fuel samples shortly.
  16. Aug 12, 2024 at 12:59 PM
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    My oil pressure gauge has never been that low. Hoping the best for you. good luck.
  17. Aug 12, 2024 at 1:33 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Careful, another member on here had his dealership blame it on bad gas and refused warranty. Had to pay out of pocket and now is in litigation.
    cmiles97 and KNABORES like this.
  18. Aug 12, 2024 at 1:35 PM
    gntreg
    2022 SR5 TSS
    Either way I am out of warranty and will still be receiving a new engine once the recall is rolled out. If it is bad fuel the gas stations insurance should cover the bill, per the dealer. We will see.
  19. Aug 12, 2024 at 1:55 PM
    Classic.
    AZBoatHauler, woods, Kap1 and 2 others like this.
  20. Aug 12, 2024 at 2:17 PM
    Breathing Borla
    Northern Illinois
    its not bad gas, geez..
    thats really rare and it usually involves water penetrating the system somewhere and you have a lot full of dead cars all at once.
    cmiles97, Lee.M, woods and 3 others like this.
  21. Aug 12, 2024 at 2:32 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Bad gas is the excuse they use when they can’t figure out what the problem is. Exactly what happened to the other member. He had the gas tested and turned out not to be the cause. Toyota wouldn’t cover the warranty blaming gas. Insurance wouldn’t cover the repair saying the gas was ok. No one left to flip the bill other than the owner. You might want to get a sample from the tank. Don’t take their word because it’s probably BS. Also your powertrain warranty is longer. 5yr/60k I believe.
    Lee.M, AZBoatHauler, Kap1 and 2 others like this.
  22. Aug 12, 2024 at 11:13 PM
    gntreg
    2022 SR5 TSS
    I have almost 74k.
    joonbug[QUOTED] likes this.
  23. Aug 13, 2024 at 4:16 AM
    WildBillThe2nd
    WildBillThe2nd New Member
    2022 Tundra, SR5, TRD-OR, Advanced Tech
    I got one of these last week. When I hooked a code reader up I pulled a "P25B4" code. Turbo A Wastegate stuck closed. Dealer is replacing the passenger turbo this week.
    My Mfg date is 03/2022, Mileage @ turbo Failure 25,250
    Hopefully yours is "nothing" and it continues to stay nothing until your engine gets replaced...
  24. Aug 13, 2024 at 4:26 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    You ever do your plugs? 40k is the interval on the truck.
    I hope they get it all squared away for you. And yeah blaming gas is a real excuse. Ask them for a sample.
  25. Aug 13, 2024 at 5:20 AM
    BoulderGT3
    Glen
    Different gauge set on mine but here's the reading on mine. Motor fully up to temp at idle on level ground. I'm about 3/4 at 1500rpm when the motor is cold. FWIW.
  26. Aug 13, 2024 at 10:23 PM
    gntreg
    2022 SR5 TSS
    I picked the truck up today. So far it seems to be running normally. The tank was flushed. Here are the results with the fuel. Attachment.jpg Attachment.jpg Attachment.jpg
  27. Aug 13, 2024 at 10:50 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    Yowsa, that's some really bad gas. Damn, here in Phx I'm pretty sure that's how the test would show the water coming out of my garden hose. How much did it cost you?
  28. Aug 14, 2024 at 4:38 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    Oh damn. Off to the station you go to hopefully get your money back for the repairs.
  29. Aug 14, 2024 at 4:43 AM
    Breathing Borla
    Northern Illinois
    I’ll be damed, time for ust removal at the station , give them my number lol
  30. Aug 14, 2024 at 4:45 AM
    Lee.M
    Lee.M New Member
    TN
    24tundra limited 4x4
    Level/35s
    Geesh that bad you would think cars would be broke down all around that gas station.
