Need help wiring light bar to switch
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Aug 3, 2024.
  1. Aug 5, 2024 at 9:34 AM
    SDHNTR
    SDHNTR [OP] New Member
    Yes, I understand that. The confusion lies in how I get those three wires from the BD harness connected to the 5 wires (or 4 if you consider the combined grounds) from the switch harness. The pin diagram from the switch is confusing. Posted again here for reference.
  2. Aug 5, 2024 at 9:36 AM
    AZBoatHauler
    So.Arizona
    It goes together just how it shows:
    Red is illumination/dash light +, green is 12v, white and black are ground, blue to the relay.
    I’d pull out a meter or test light and verify the black wire on the BD harness is your 12v.
  3. Aug 5, 2024 at 9:46 AM
    SDHNTR
    no. Black is ground and white is hot.
  4. Aug 5, 2024 at 9:49 AM
    AZBoatHauler
    So.Arizona
    :thumbsup:
  5. Aug 5, 2024 at 9:50 AM
    SDHNTR
    Success! Finally got it. Thanks all. I had my red and green swapped.
  6. Aug 5, 2024 at 10:47 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I had no problem wiring up my baja bars to a switch like yours...All I had to connect at the switch was grounds...tan wire tap from a neighboring switch for the backlight and the trigger to the relay. Is that not how youre wiring it up?
    edit: nm...took too long to reply
  7. Aug 6, 2024 at 1:36 PM
    HGParrish004
    HGParrish004 New Member
    Harry
    Raleigh, NC
    2023 Tundra SR5 - TRD Offroad
    TRD Factory 3" Lift Kit, CBI Front Bumper, Baja Designs lighting and Retrax Pro XR bed cover.
    I think I'm going to pay a BD dealer to install.
  8. Aug 6, 2024 at 1:39 PM
    SDHNTR
    Totally unnecessary. It’s an easy bolt on job. Super easy if willing to use the stock BD switch. Even if using a factory lookalike switch like I did, it’s still not hard, I just had a confusing diagram. Once I figure out what was what, easy peezy.
    PBNB likes this.
  9. Aug 6, 2024 at 1:52 PM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Can you share pics of end result, switch and cable management under hood?
  10. Aug 6, 2024 at 2:03 PM
    SDHNTR
    I can, but it’s gonna be a few days. The cable management part is stupid easy. BD has an entirely self contained harness. It’s pretty self explanatory. There are also multiple YT videos on installing a 20” hidden light bar.
    MaineTundy likes this.
