Air box pre air filter damaged
Discussion in '3rd Gen Tundras (2022+)' started by 40man, Aug 3, 2024.
  1. Aug 3, 2024 at 5:25 PM
    40man
    40man [OP] New Member
    On checking my filters, I note the bottom of the box pre air filter has some damage on the driver side. I don't want to risk it pulling the cotton material into the engine (even though filter should stop it, and the filter indeed had a bunch on it). Has anyone removed this filter on the 3rd gens? If so, is it just drilling out the plastic welds?
  2. Aug 3, 2024 at 8:19 PM
    Lee.M
    Lee.M New Member
    TN
    24tundra limited 4x4
    Level/35s
    Removed mine 3 days after I bought my truck that is Sound absorbing material.You will have a bit more turbo whistle even with stock filters. Sounds good go for it.
  3. Aug 3, 2024 at 8:31 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Removed mine about 2 years back and its been file ever since. Simply drill the plastic welds and it pulls right out. Doesnt take much to remove the weld. Very little drilling is needed.
    40man[OP] likes this.
  4. Aug 3, 2024 at 9:08 PM
    40man
    Thanks, came out easy, no drilling needed.
    SC4333 likes this.
  5. Aug 4, 2024 at 3:31 AM
    BlackNBlu
    BlackNBlu Cranks Nickelback in Target order pickup lane
    Rich
    MN
    I haven't popped open my airboxes yet so I'm just going by pictures here and in other threads.
    Dumb? question: Does the thin plastic with the hexes get removed as well as the gauze sound absorbing material?
  6. Aug 4, 2024 at 6:05 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Pulled mine out. They may absorb some noise but their main purpose is to catch any emissions coming from the intake when the vehicle is shut off. I used AFE prodry air filters as well.
  7. Aug 4, 2024 at 7:22 AM
    JayDee
    JayDee New Member
    It seems odd that the pre-filter isn't designed to be replaced. What happens when it gets clogged with dust and dirt? It will certainly eventually begin restricting the airflow of the intake.
  8. Aug 4, 2024 at 7:32 AM
    RobertD
    Robert
    DFW, Texas
    Probably get charged for a whole new assembly if the filter needs replacing.
  9. Aug 4, 2024 at 8:29 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    If you look at it. It’s not in the airflow path. Air flows on top of it. It provides no restriction.
  10. Aug 4, 2024 at 9:11 AM
    JayDee
    JayDee New Member
    That's good to hear. I haven't opened mine up yet. Still undecided if I want to remove it.
    ARB1977[QUOTED] likes this.
  11. Aug 4, 2024 at 12:48 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    There’s no flow through that carbon vapor mat and even if it did get loose it would just go up into the filter. The damage is from rodents. They chew on it and in some cases make a nest in there. They’ll even chew on paper air filters and no reports of them chewing oiled cotton filters. Theres a very easy cheap 10 min fix per side to stop rodents from entering your air box.
    https://www.tundras.com/threads/poor-man’s-intakes.144501/#post-3631293
    Tundrastruck91 and Tunrod like this.
  12. Aug 4, 2024 at 1:00 PM
    JayDee
    JayDee New Member
    The issue I have with oiled filters is that they leach oil onto any sensors that are in the airstream which may or may not be an issue for a particular sensor. In the old days with MAF sensors it was definitely an issue (especially after you cleaned and re-oiled the filter).
  13. Aug 4, 2024 at 1:03 PM
    PNW Tundra Mike
    Back in So Cal
    If that is happening someone is using way way too much oil. It just takes a whisp of oil spray to catch dirt. 4 trucks and two cars over 500K mi between them and I’ve never once cleaned a MAF sensor in my life.
  14. Aug 4, 2024 at 1:07 PM
    JayDee
    JayDee New Member
    But I had a whole can of K&N oil filter spray. I only used 1/4 of it. LOL
  15. Aug 4, 2024 at 1:11 PM
    PNW Tundra Mike
    Back in So Cal
    LOL. I’ve had to oil motorcycle filters for 50 yrs now and learned early, Less is More ;-)
  16. Aug 4, 2024 at 2:47 PM
    tundramh
    tundramh New Member
    OHIO
    Hold the box down and give the sides of it a yank. It breaks the welds. Put mine in the garbage and installed K&N filters. My engine hesitation when slow rolling a stop and hitting the gas to get into traffic quick seems to have disappeared. I try to get it to do it and can't so I'm pretty happy about the whole situation now.
    Tundrastruck91 likes this.
  17. Aug 6, 2024 at 9:21 AM
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    I open my air box the other day to remove the baffles and found this. Dam Mice! I cleaned up the mess and yanked the baffles out. I can hear the turbo a litDam mice.jpg
    If anyone is interested here the NAPA air filter number 201653.
  18. Aug 6, 2024 at 9:27 AM
    BlackNBlu
    Rich
    MN
    (If you hadn't seen already.)
    ARB1977 likes this.
  19. Aug 6, 2024 at 12:39 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Dont drive much?
