Poor man’s intakes
Discussion in 'Performance and Tuning' started by ARB1977, Jun 24, 2024.
  1. Jun 24, 2024 at 7:17 AM
    ARB1977
    ARB1977 [OP] New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Poor man’s intake. Installed AFE Prodry air filters and removed the carbon mesh at the bottom of the air boxes. At 600 miles took about an hour drive and got 20.5 mpgs. Hard to tell if there was any more turbo noise since the radio was on. Haven’t romped on it yet since it’s still a baby, lol. 24 SR5 4x4.
  2. Jun 24, 2024 at 7:36 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I def get more turbo noise without that pillow in the airbox and TRD filters.
    Yaboy likes this.
  3. Jun 24, 2024 at 8:10 AM
    Maine TRD PRO
    Maine TRD PRO New Member
    2023 Ice Cap Tundra TRD PRO(Rioja Red interior)
    is it easy to remove and is it only there for sound dampening?
  4. Jun 24, 2024 at 8:12 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Carbon emissions bs
  5. Jun 24, 2024 at 8:26 AM
    eddiefromcali
    Eddie
    100% Stock
  6. Jun 24, 2024 at 8:30 AM
    eddiefromcali
    Eddie
    100% Stock
    Easy...its plastic welded in place in 3 or 4 spots...so just drill that out and then remove the mesh/bag. I cant tell you if its emissions related...but it does provide sound deadening. I had one guy argue its an air straightener, but thats not the case here as air doesnt pass through the mesh/bag.
  7. Jun 24, 2024 at 9:04 AM
    ARB1977
    Anthony
    DFW
    I’ll have to try it without the radio on.
  8. Jun 24, 2024 at 9:05 AM
    ARB1977
    Anthony
    DFW
    I just pulled and it came right out.
  9. Jun 24, 2024 at 9:06 AM
    eddiefromcali
    Eddie
    100% Stock
    :rofl: never thought of just yanking it off. Did it break or just came off those plastic welded spots?
  10. Jun 24, 2024 at 9:07 AM
    ARB1977
    Anthony
    DFW
    It came apart from the weld spots.
    eddiefromcali[QUOTED] likes this.
  11. Jun 24, 2024 at 9:15 AM
    Maine TRD PRO
    Damn he deleted that comment too haha
  12. Jun 24, 2024 at 9:15 AM
    eddiefromcali
    Eddie
    100% Stock
    mods probably took care of it
  13. Jun 24, 2024 at 10:31 AM
    Hella Krusty
    Hella Krusty New Member
    Finally someone with common sense
  14. Jun 24, 2024 at 10:32 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    That vapor barrier padding is just something for the rats to chew on. Remove it if it’s too chewed up and install rat barrier in the snorkels. Super easy to do. Theres a space for it designed in almost like Toyota planned for it. 15 mins per side and a couple bucks.
    woods, Goobax, 303Gen3 and 1 other person like this.
  15. Jun 24, 2024 at 1:56 PM
    ARB1977
    Anthony
    DFW
    How did you secure the screen?
  16. Jun 24, 2024 at 1:58 PM
    eddiefromcali
    Eddie
    100% Stock
    looks like its wedged between the air box and the snorkel thing
    ARB1977[QUOTED][OP] likes this.
  17. Jun 24, 2024 at 2:32 PM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    charcoal carbon and cotton gauze or whatever rats ate mine at the dealer so replaced under warranty...ours aren't in the path of airflow to the turbos so really no benefit to removing performance wise just there to catch any fuel vapor creeping back towards the inlet...in many cars they are in the direct intake path and do create a restriction...screens are a good idea a little finer mesh would make a good rock guard for radiators and intercoolers
  18. Jun 25, 2024 at 9:20 AM
    PNW Tundra Mike
    Back in So Cal
    The air boxes are just held in on rubber grommets. Just pull up and they pop right off the steel posts. The snorkel part is two pieces snapped together with easily separated tabs. Just work your way around one at a time. In the joint between the two parts there’s a perfect indented tray to hold the screen. (Like Toyo designed for it) Cut screen to drop in and then just snap the parts back together. Easy. *You could use 1/4” screen if mice are your issue. Mine are fat rats and 1/2” will stop them.
    Tundrastruck91 likes this.
  19. Jun 25, 2024 at 10:43 AM
    mass-hole
    mass-hole New Member
    It catches gasoline and other PCV vapors that can leak out the intake when you shut the truck off.
    Maine TRD PRO[QUOTED] likes this.
  20. Jul 4, 2024 at 4:50 AM
    awpk03s
    awpk03s New Member
    I also tried this. There’s a slight favorable noise increase without the mesh padding and stock intakes with trd filters. Nowhere near the AFE for example, but it’s certainly better than bone stock. I like it.
    PNW Tundra Mike likes this.
