  1. Aug 2, 2024 at 4:35 PM
    TheBeast
    TheBeast The Beach
  2. Aug 2, 2024 at 9:27 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Repaired the threads on one stud on both sides of my front end, all due to a locking lug that wasn’t deep enough to accommodate my extended studs. Also picked up a set of pro comp fenders. Going to order a set of new aftermarket fenders and cut those up opposed to my stock ones, then have it all painted Cavalry blue. Taped them on just for a mock up.
    thanks again @LILTRD
  3. Aug 3, 2024 at 11:37 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Many of those taillights let moisture in and they can short out the boards. Also, there is an error on some of those taillights where there’s an option to connect a resistor to the brake/parking light circuit in addition to the turn signal circuit. If that resistor fails from working overtime, you will have a short.
  4. Aug 3, 2024 at 1:09 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Look at that travel! I love new tire days.
  5. Aug 3, 2024 at 1:11 PM
    CaptRussia253
    Ruslan
    Took the family down to the snake river for some fishing.
  6. Aug 3, 2024 at 1:17 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    If that happens, is it as simple as removing the aftermarket LEDs and installing factory ones? Or would there be catastrophic electrical issues that could happen?
    Reason I ask is because I replaced my factory tail lights with aftermarket LED ones after I found a cracked hole in my passenger tail light. So rather than replacing just the one I thought I'd give it a go with LEDs.
    I do love the look of my LEDs :(
    BlueRibbon4x4[QUOTED] likes this.
  7. Aug 3, 2024 at 1:53 PM
    Azblue
    The Dirty T ( ^_^)_且
    These trucks are very sensitive to brake light changes, not the turn bulbs, just the brake light. I've replaced every light on my 2014, but had to go back to regular bulbs for the brakes. At first it was fine but after a while I started having problems where the truck would stop accelerating and slow down, the engine ran fine, just no acceleration. Took it to the dealer and was told that due to the floor mat BS, the vehicles are now programmed to kill the throttle when it senses brake and throttle while in motion. A faulty LED brake bulb sends this message to the computer. I put the old brake light bulb back in and it's been fine for years.
    mtkey, grant.ducckk, Silver17 and 8 others like this.
  8. Aug 3, 2024 at 9:41 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Little late afternoon run to break in the new tires and see how these containers hold up. Confirmed all fluid still contained.
  9. Aug 3, 2024 at 10:55 PM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    Making me think twice about keeping my LED tail lights, I hate my back up lights as it is. They are not bright enough and I cant change them. I'm glad it worked out for ya.
  10. Aug 3, 2024 at 11:06 PM
    AZBoatHauler
    So.Arizona
    Kind of like assless chaps, huh? I dig it.
    :fistbump:
  11. Aug 4, 2024 at 3:46 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Where's the 0w20 :boink:
    reywcms[QUOTED] and Jbehredt like this.
  12. Aug 4, 2024 at 6:53 AM
    BlueRibbon4x4
    Geno
    Correct. The turns aren’t the issue. My point was that if these aftermarket tails are connected to a resistor on the brake light circuit that the light manufacturer provides, it can cause issues.
    Azblue[QUOTED] and RobertD like this.
  13. Aug 4, 2024 at 7:20 AM
    Tboh1870
    Tboh1870 New Member
    Herman
    Just starting reno
    Got em exactly ... maybe 6 mos ago
    Just can't believe how much floor liners cost
    They are fine fit perfectly & s33m solid
    Anxious to see if they hold up but I can vouch they're great 6 mos in
  14. Aug 4, 2024 at 7:40 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    You’re so cheeky…. lol
  15. Aug 4, 2024 at 7:40 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Hahah right next to the blinker fluid
  16. Aug 4, 2024 at 7:41 AM
    TacomaTRD4x402
    Southern California
    Thanks! I did end up buying them and got em installed next day. I love the fitment
  17. Aug 4, 2024 at 10:54 AM
  18. Aug 4, 2024 at 1:39 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  19. Aug 4, 2024 at 1:46 PM
    I have mixed feelings. Still have my 2000 which will be my daily again. In the midst of a rejuvenation project for it. Just don’t need 2 trucks, or a really large one. Sold my camper, so the camper we are buying to replace it will be 4200# and could be pulled with anything else we own.
  20. Aug 4, 2024 at 1:56 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I totally get it and I’ve been loosely following your conversations about it on some of the BS threads. I’m glad you’re at least staying in the Tundra fam. And, of course, GLWS
    Tripleconpanna and ATV25 like this.
  21. Aug 4, 2024 at 2:01 PM
    It’s not the trucks fault. All it’s ever done was all I asked of it. Roomy, comfortable, capable, dependable. The 2.5 is Toyotas best full size truck to date.
  22. Aug 4, 2024 at 2:17 PM
    CaptRussia253
    Ruslan
    Drove the tundra along the Columbia and found a nice beach. Had it all to ourselves.
  23. Aug 4, 2024 at 6:21 PM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    I swapped my ditch lights from XL sports to lp4's.
    PXL_20240803_182242388.jpg PXL_20240803_182428582.PORTRAIT.ORIGINAL.jpg PXL_20240804_041516308.NIGHT.jpg
  24. Aug 4, 2024 at 7:08 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Had it washed and polished.
  25. Aug 4, 2024 at 7:10 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Y tho
  26. Aug 4, 2024 at 7:11 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    But really, looks great! Can’t wait to see you get it dirtied up again
  27. Aug 4, 2024 at 7:11 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Just to get it dirty again lol
  28. Aug 4, 2024 at 7:12 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Jinx
    reywcms[QUOTED] likes this.
  29. Aug 4, 2024 at 7:12 PM
    Kinda like making the bed in the morning.
  30. Aug 4, 2024 at 7:12 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Samsies
