  1. Aug 1, 2024 at 2:55 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    I wouldn’t say unfortunately. They have some solid cabinets. Not all are great but if you look you can find some good quality stuff. I didn’t realize the amount of friggin options.
    partial overlay, full, inset, soft close, hidden hinges, et.
    BreyTundy[QUOTED] and T-Rex266 like this.
  2. Aug 2, 2024 at 6:25 AM
    Ok, my buddy pulled through (again) and is sending one of his employees over this morning to repair the AC. I told my buddy I would tip out his employee too. My question is, how much?
  3. Aug 2, 2024 at 6:31 AM
    NWPirate
    Zach
    WA
    $50-100 max, the employee is still getting paid to be there
    T-Rex266[QUOTED] likes this.
  4. Aug 2, 2024 at 6:43 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    If your Bud is going to hook you up meaning a freebie,and putting you in que before his clientele and on a Friday,you're pretty damn lucky.
    Pending on diagnosis severity,if it's just a cap ($15 ~ 40 part) duel or not yeah $60~100 tip would be a great compliment for that tech to kick off there weekend.
  5. Aug 2, 2024 at 6:46 AM
    He put me ahead on their schedule over others. Charging me his cost for the compressor ($936) and $600 labor. I will get him a nice bottle of booze for him?
    Sounds good on the tip for his tech.
    dondino, Azblue, NWPirate and 3 others like this.
  6. Aug 2, 2024 at 6:54 AM
    Blufin
    Bob
    23 Capstone
    Man, you have a good friend there for sure!
    Compressor swap change out give or take is out 4 hours to do it properly, I'm not going to itemize the sequence process, materials equipment and labor but for that price is pretty damn good my man!
    It's always good to have Buds in your corner.
    Pretty soon you'll be chillin!
    Cheers.
    NWPirate likes this.
  7. Aug 2, 2024 at 7:51 AM
    NWPirate
    Zach
    WA
    That's a solid hookup, bottle of booze and/or dinner gift cert.
  8. Aug 2, 2024 at 8:07 AM
    It’s 1536 I think (idk if he’s including taxes) if so, I’ll do 1600 cash
    ya I’ll get him some booze. We know him and his wife well
  9. Aug 2, 2024 at 8:26 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Since you know them well, you could also consider inviting them over for dinner... Takes cooking and clean up off the table for them for a night and makes the gift a little more personable.
  10. Aug 2, 2024 at 8:39 AM
    Nah. His wife is kookoo for Cocoa Puffs. He’s even mentioned it before.
  11. Aug 2, 2024 at 8:40 AM
    Also I have good reason to believe they’re swingers. :rofl:
  12. Aug 2, 2024 at 8:51 AM
    Tripleconpanna
    Key party :rofl:
    :bananadance::bananadance::bananadance:
  13. Aug 2, 2024 at 8:52 AM
    Tripleconpanna
    Pics???
    For science please :D
  14. Aug 2, 2024 at 10:11 AM
    Ok, compressor is good!
    Air blower is done. They believe the drywall from the basement finish clogged the coils, which overloaded the blower on a continuous matter. The noise I was hearing was the compressor basically saying fuck you, give me a beak as its dirty inside.
  15. Aug 2, 2024 at 10:22 AM
    Blufin
    Bob
    23 Capstone
    I would agree for the evap to get clogged, due to environment, and will prevent air flow across it,but in turn the evap would freeze up and that ice would chase the suction line back to the condenser and even incase the compressor in a Jacket of ice.
  16. Aug 2, 2024 at 10:28 AM
    They arent finding ice in there, yet. They took out the blower area, and that motor is done.
    The filter had some water on it from the condensation of build-up. They tested the compressor, which is good.
  17. Aug 2, 2024 at 11:37 AM
    $800 OTD
    Gonna tip each $100 and call it good. I’ll also send my buddy Crumbl as they get that all the time
  18. Aug 2, 2024 at 1:09 PM
    Whew, what a relief.
    They got the new blower in and it wasn't blowing much. They double checked everything and replaced it with another new one, which works brand new.
  19. Aug 2, 2024 at 1:32 PM
    Blufin
    Bob
    23 Capstone
    Roller coaster all day by the sounds of it,but it's Friday and all set for the weekend!
  20. Aug 2, 2024 at 1:48 PM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Any AC folks in here?
    Question: I need to replace the drip pan under the air handler. Does anyone have a method for lifting an air handler? Rachet straps maybe?
    Also the Ole push lawn mower needs a little TLC. Replaced the spark plug, cleaned the very dirty air filter. Still turning off after started. I am going to replace the carb next, hopefully that works or I'm going to be in the market for another.
    TaquitoBandito likes this.
  21. Aug 2, 2024 at 4:56 PM
    Azblue
    The Dirty T ( ^_^)_且
    I think the bottle is a good idea. Also, don't forget that I have provided you moral support through this whole AC thing, which is invaluable, and I also like booze.
  22. Aug 3, 2024 at 7:49 AM
    Blufin
    Bob
    23 Capstone
    It depends if it's strictly an airhandler or a furnace to,if a gas then you probably have a 1/2" Black pipe gas feed which would pretty much prevent vertical movement. Remember you already have a 3/4" copper suction line and the ductwork that's pretty ridged and is probably 32gage,and if 20 years or older it's 28 gage,
    the lower the gage the thicker it is, just like Ammo.
    So every case is different so maybe you have some wiggle room,I don't know,obviously so if you really feel the need for a project, you could get a pan and with tin snips cut a line down on just two corresponding corners and fold it flat and chase it under the unit.
    Then re fold it to its functional position and with scrap pieces of sheet metal you can re bond it with water proof/bondo or soldier it.
    Or make a mote, remove the old rotting existing one,build 2 frames around the base, one 2" bigger than the other with 2x4 or 2x6.
    Before hand clean the foor with muriatic acid where it will serve,remember concrete will adhere, bond better this way.You want no oils present.
    A safety pan is good for only so long before it spills over,and another avenue is a water puck that gets wired in series with your system.
    Good luck with your choices.
  23. Aug 3, 2024 at 8:02 AM
    TaquitoBandito
    Joel (AKA Bif)
    I think “like” is an understatement, sir.
    :cheers:
  24. Aug 3, 2024 at 9:21 AM
    Damie Street
    Edsel
    Thank you for the information. It is just an air handler. I think if I lift up slide the old plastic drip pan out and then slide in the aluminum one.
    Need to figure out a prep for it so it doesn't rust and maybe silicon the edges and corners to prevent leaking.
  25. Aug 3, 2024 at 10:23 AM
    Those secondary pans should never have water in them. If they do, that means you have an issue with your primary pan or condensate drain line.
  26. Aug 3, 2024 at 10:52 AM
    Damie Street
    Edsel
    Yes we had to clear out the condensate line. But we only found out about the condensate line because the pan had a cracked in it and started leaking through the ceiling in the living room. Line has been cleared. Now need to replace the cracked pan with a better pan. We have a switch that will cut the AC off if the water in the pan gets to high.
  27. Aug 3, 2024 at 11:07 AM
    Blufin
    Bob
    23 Capstone
    If the unit is in the attic with a safety pan, large or small most reputable companies will install a float switch.
    If the condensate drain plugs and causes back up and overfill that bleeds into the pan once the float switch starts to rise with water level it will open the circuit to the condenser which turns it off which stops the cooling but more importantly stops additional condensate.
    So in turn, the occupied space gets warm and and you call a tech because it's getting hot and they go to work and figure out ect...
    Damie Street likes this.
  28. Aug 3, 2024 at 11:20 AM
    Damie Street
    Edsel
    There is a float switch in place. The problem was the pan had a crack in it and so the float switch never switched off. We only knew the pipe was clogged because of it.
  29. Aug 3, 2024 at 11:29 AM
    They also make in-line float switches that can be installed on your drain line or a secondary port on the drain pan, wired in series with your other float.
    https://www.amazon.com/Rectorseal-9...64984ba45a5435e6af089cd5929fa5a3&gad_source=1
    TaquitoBandito, Blufin and Fotnot like this.
  30. Aug 3, 2024 at 11:52 AM
    Blufin
    Bob
    23 Capstone
    Ahhhh now all the pieces are coming together,I initially thought the unit was in the basement, hence a cement mote, then shit Brother bondo the crap out of it with JB weld or have a buddy come over to help swap out the pan man...
    Damie Street[QUOTED] likes this.
