Rock Slider Recommendations for... kids and door dings?
Discussion in '2.5 Gen Tundras (2014-2021)' started by DZ_, Jun 18, 2024.
  1. Aug 1, 2024 at 9:14 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Got my RCI sliders installed a few days ago. No top plates. Wife and kid dig them for climbing in and out. Slapped some 3m traction tape on the outer rails to make it easy to get in and out. With the Tundra doors being wider than the rockers, they sit almost as far out as traditional tube steps but not quite as low.
    I got lucky, my 4th hole was right next to the front gas tank strap so I was able to wiggle it into place. The frame in my truck did not have another big hole for the 5th bolt on the driver side near the middle of the tank. I did have a couple smaller M8 holes at the rear of the mounting plate and was able to use those.
  2. Aug 2, 2024 at 4:35 AM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    So you are saying they sit flush with the door?
  3. Aug 2, 2024 at 6:10 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    You’re probably speaking about the rocker panels if this is the question you’re asking. Rock sliders bolt to the frame which protects your rocker panel from damage while off roading/wheeling.
    If you want to spend a pretty penny, then yes, rock sliders will act as a step and as protection from damages (door dings, maybe, if your truck is lifted to a certain extent).
    If you want to save a couple bucks, then running boards would be your other option and a cheaper alternative to steps.
  4. Aug 2, 2024 at 6:25 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    These 2 give you an idea about the mounting setup, strength, durability of these units...
    Hopefully this will give you an idea about coverage... Also, I have no top plates on mine... But, if you want a better step surface and more paint protection from rocks, etc. you can order them w/top plates. If you are in snow and ice regularly, I'd recommend them as the powder coating is slick in icy conditions :thumbsup:
    Timberline likes this.
  5. Aug 2, 2024 at 6:55 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Westscott designs sliders have worked very well.
  6. Aug 2, 2024 at 8:09 AM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    +1 for westcott sliders. I’ve really beat mine up and they are stout. I love how clean the lines are and you can get them in a 20 degree which I have. Can’t to wrong with RCI either.
    DZ_[OP], Tripleconpanna and reywcms like this.
  7. Aug 2, 2024 at 12:59 PM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    @pvn.beluga the above quoted message is what I'm asking about
  8. Aug 2, 2024 at 1:00 PM
    DZ_
    DZ_ [OP] New Member
    Frederick Co., MD
    Thanks, guys. These look like really good options as well. I'll take a closer look.
    reywcms[QUOTED] likes this.
  9. Aug 3, 2024 at 10:15 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    You have a nice setup! :thumbsup:
  10. Aug 3, 2024 at 10:57 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Thanks!
  11. Aug 3, 2024 at 10:59 AM
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
    anybody have any input on bolt or weld on?
