2020 Quality
Discussion in '2.5 Gen Tundras (2014-2021)' started by yakeng, May 24, 2024.
  1. May 28, 2024 at 9:38 AM
    2mchfun
    Have any proof of this "problem" on a 2.5"? I don't define poor cab soundproofing as a significant problem. More like quite the opposite, I want to hear what is happening while driving.
  2. May 28, 2024 at 10:00 AM
    yakeng
    yakeng [OP] 3URFE Apologist
    Not that there is any evidence to show that the CV's are really wearing due to this issue, but if they are, I would recommend swapping it sooner than later. It seems OEM CV's are getting harder to come by these days and they are definitely worth the extra $$$.
  3. May 28, 2024 at 1:42 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Humm needle bearings/ or 4x4 seems to be a minor common problem. Plus upgraded JBL stereo locking up. I don't have either of those...
    I guess the old saying is true..."Chrome Don't Get You Home Boy!".
  4. May 31, 2024 at 7:19 AM
    Wallygator
    Aren't the 3rd gen bearing problems in the engine? Or do they also have the front diff bearing issue?
    vtl[QUOTED] likes this.
  5. May 31, 2024 at 7:24 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Henry1jg, Nick W, LS3 and 1 other person like this.
  6. May 31, 2024 at 8:46 AM
    Kung
    KG, VA
    I've got a 2020; manufactured in January 2020, I believe, so prior to any major COVID issues.
    Only two real issues I've had:
    1. *VERY* occasionally, when it's below freezing, I *believe* the HVAC system (sensors?) malfunction or something. I say this because what will happen is that the "HVAC LCD" screen will be blank for about 30 seconds, during which time I believe it's doing some system checks. Everything starts up then...but only blows air through the defroster vents. The rest of the time, I can easily change which vents it blows through, no binding or noise or anything.
    2. Stock head unit is going out. It works 99% of the time, but occasionally it'll reboot - and I mean very occasionally.
    Annoying? Yes. With that said, ALL of the issues on ALL of the Toyotas I have owned don't equal all of the issues on my last truck alone ('13 F150), so while it's annoying...I'm not too upset.
    bulldog93 likes this.
  7. May 31, 2024 at 12:47 PM
    Wallygator
    :rofl: Yeah, those two bearing issues are quite different IMO.
    Henry1jg, Terndrerrr and 2mchfun like this.
  8. May 31, 2024 at 7:25 PM
    GaFFLe
    GaFFLe New Member
    Atlanta, GA
    2020 Toyota Tundra Platinum
    Undercover bed sway cases
    My 2020 Platinum was factory built in 2019. I've had no issues at all...
    Wallygator likes this.
  9. May 31, 2024 at 7:41 PM
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    Just checked the door jamb on my 2020. Built 8/19. No issues.
  10. May 31, 2024 at 8:06 PM
    yakeng
    Well, I’m replacing another blown speaker.
    And despite these little issues, I’m very glad I have a 2.5 gen….
    Tbrandt likes this.
  11. Jun 4, 2024 at 8:00 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Have had a nagging faint vibration/noise at vehicle speed-only dependent intervals of 30, 45, and 60 mph for a while. Definitely separate from the differential needle bearing noise I fixed a while ago. Thought it was crappy tires as I am still on an OEM set of Bridgestone Duelers that still have decent tread and no irregular wear, but figured the rubber was getting hard.
    This weekend the noise really took off and has reached honda civic fart-can exhaust drone levels of loud. The whole cab booms like I have a big subwoofer in the back seat at 45 and 60 mph. Whatever is vibrating feels like it has a rigid connection to the cab of the truck, definitely is coming from behind the drivers seat.
    Thinking it has to be in the rear driveline somewhere. Dealer is looking at it Saturday. Weird because it is harmonic with the peaks in volume at 15mph intervals, between those speeds it fades out and goes away completely.
  12. Jun 4, 2024 at 11:49 AM
    yakeng
    Kind of sounds like it is part of your drive line, maybe U-Joints or center bearing.
    Tbrandt likes this.
  13. Jun 8, 2024 at 2:29 PM
    Tbrandt
    Tristan
    Kansas City
    Update - dealer is replacing the passenger rear wheel bearing under warranty next week.
    Wallygator and yakeng[OP] like this.
  14. Jun 10, 2024 at 12:00 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    I have a 2020 1794, which is basically a Platinum. It has 57k on it and the only problem I've had was the driver's door check started catching and making a snapping noise in the first year. They replaced it under warranty and I have had no other issues except the headlight wiring recall. Everything else has been fine. It feels just as tight as the day I bought it. I'm even still on the original battery (I should probably knock on wood now).
    Terndrerrr likes this.
  15. Jun 10, 2024 at 1:56 PM
    yakeng
    I wonder if there was a bad batch of door checks, seems to be a somewhat common issue on the 2020's.
  16. Jun 10, 2024 at 2:43 PM
    ejes
    ejes New Member
    I would say yes as it is almost always the driver side.
  17. Jun 10, 2024 at 6:09 PM
    AtomicToyo
    AtomicToyo New Member
    Ontario, Canada
    2021 SR5 with 25K..less options so less stuff to go wrong. So far I've noted is this past winter was a squeaking from what sounds like the serpentine belt, it would come and go and I could never pinpoint it, and now has stopped. I noticed my coolant reservoir has lost about an inch. The "infotainment" screen is by far the most annoying. I use Apple Carplay with an iphone 14 and I all of a sudden last year the screen would glitch all the time, turn off/on at random. I found on the Rav4 forums people experiencing a same issue and recommended cheap wireless carplay dongle to at least get it working again, which worked but now the music info on the instrument cluster is stuck on the first song playing. Is it an Apple issue or a Toyota issue...and that's why I hate every new car, especially ones loaded with "tech." Just takes one update and all hell breaks loose. I'd rather have none of it.
  18. Jun 15, 2024 at 7:23 PM
    Tbrandt
    Tristan
    Kansas City
    Passenger rear wheel bearing replaced today under warranty and the truck is whisper quiet again.
    Now that it’s fixed I realize the bearing had become extremely noisy lately, I was getting varying noises and vibrations at basically all speeds. Much more enjoyable to drive again.
    The dealer tried to get me to pay $1450 for the replacement before I told them it was still under powertrain warranty. Looked like warranty payout on the invoice was just under $900. No wonder they tried slipping that one by me.
  19. Jun 16, 2024 at 6:31 PM
    ejes
    ejes New Member
    They're going to pull every trick they can to make/save money so they can pay for those 3rd gen engines...
  20. Jul 31, 2024 at 4:30 PM
    #50
    yakeng
    Well, my alternator bearing is going bad. Can’t believe I have to replace it, 62K on the clock. Pretty disappointing, my truck was either made Monday at 7:00AM or on a Friday at 4:59PM.
    bulldog93 and ejes like this.
  21. Jul 31, 2024 at 5:11 PM
    #51
    ejes
    ejes New Member
    Ironic. Since my post above on June 10th, I had to replace my OEM battery on July 24th. I guess I jinxed myself.
  22. Jul 31, 2024 at 6:13 PM
    #52
    Kentucky22
    Kentucky22 New Member
    21 Tundra Limited 4x4
    Issue I had with my 21 limited crew max was a seperating headliner. Replaced under warranty took dealer about ten tries they could not do it right wanted me to get toyota legal involved. I wanted my truck fixed they called in an engineer out of cincinatti. He fixed on the 1st try. New head liner is a little rough looking on fabric edges front and back where liner meets front and rear glass.
    Large Puff of smoke 2 times once at around 9 to 10 thousand miles 2nd time about 3 thousand miles ago. truck has 26 thousand miles on it. Bought it pre owned with a little under 8 thousand miles on it
    Just came back from florida to kentucky and it ran great.
  23. Jul 31, 2024 at 7:43 PM
    #53
    yakeng
    My truck still runs fine for the most part, it’s noisy as heck with the bearing going out and I need to replace this ASAP. Most of my issues are still relatively minor.
    Bothersome how many there are at this point; it’s approaching my F-150 on repairs.
  24. Jul 31, 2024 at 8:30 PM
    #54
    chingyeunglo
    chingyeunglo New Member
    Would you like to tell me what is the month and year made on the sticker?
  25. Aug 1, 2024 at 2:51 AM
    #55
    yakeng
    08/20
  26. Aug 1, 2024 at 9:50 PM
    #56
    yakeng
    To the engineer who put the power steering pump over the alternator.
    may you step on a 1000 legos tonight
    That is all.
  27. Aug 2, 2024 at 5:45 PM
    #57
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Sorry for all your troubles, @yakeng. Hopefully this will be the last issue for you for a long time
    My 2021 is coming up for 45k miles and was built in April of 2021. I had the factory battery go out and be replaced under the b2b warranty. My only other issues are that the lumbar support will make a crackling noise if it's at full extension and my arm rest is peeling near the shifter and driver seat.
    Luckily I don't like the lumbar all the way out, so that's a non issue.
    I will eventually address the arm rest. I'll try it myself with my heat gun and resort to a professional or a replacement if that doesn't work
  28. Aug 2, 2024 at 6:17 PM
    #58
    yakeng
    Well I fixed everything this afternoon. Was surprised at how much quieter it is now that the alternator is fixed. Guess it’s been bad for a while.
    Rdrcr and BoyHowdy like this.
