Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Aug 1, 2024 at 12:55 PM
    #451
    AZBoatHauler
    So.Arizona
    nodak67, Ausfahrt, in_the_mud and 6 others like this.
  2. Aug 1, 2024 at 1:12 PM
    #452
    AZBaldy
    AZBaldy I didn't choose the bald life. It chose me...
    Z
    NorCal - Wine Country
    2008 SR5 4Runner
    Just my opinion but I always felt that the date range of the engine recall had more to do with preventing a stop sale on trucks on the lot than what model years were truly impacted by whatever is causing the engine issues in general.
    I admit to being a Toyota fanboy but I'm just too cynical of business in general to think otherwise.
  3. Aug 1, 2024 at 1:38 PM
    #453
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    Agree.
    IMO this is likely the bean counters calculating the chances of a major accident or worse versus the financial and PR disaster of having thousands of Tundras sitting on their own “ice mountain.” We all know how that turned out for Ford with the Bronco the semi conductor shortage (and the bevy of major issues Ford deal with with the roll out). Bronco sales tanked, thousands of cancelled orders, prices crashed, and horrible press.
    https://www.autoevolution.com/news/...untain-the-reason-is-too-familiar-182056.html
  4. Aug 1, 2024 at 1:39 PM
    #454
    AZBoatHauler
    So.Arizona
    Not to mention the Tundra is the only high $ product they actually have in stock. It would crush revenue / cash flow.
    WNY PAT[QUOTED] likes this.
  5. Aug 1, 2024 at 1:39 PM
    #455
    Kap1
    Kap1 New Member
    San Francisco, CA
    Wow... :eek:
    Happens to the best of us.
    Did he do oil analysis prior and did it show any clues?
  6. Aug 1, 2024 at 1:41 PM
    #456
    AZBoatHauler
    So.Arizona
    I’ll ask but I doubt it. He shared it’s been an awful experience with Toyota corporate - if he had an oil analysis showing anything I think he would have said so.
  7. Aug 1, 2024 at 1:42 PM
    #457
    Kap1
    Kap1 New Member
    San Francisco, CA
    Hopefully he gets a long block replacement at least...
  8. Aug 1, 2024 at 1:44 PM
    #458
    AZBoatHauler
    So.Arizona
    I’m sure he will but it sounds like it will be many months without a full-size truck which I’m sure is a huge PITA, especially the day the payment is due every month.
  9. Aug 1, 2024 at 3:45 PM
    #459
    atrouth
    atrouth New Member
    Anthony
    2022 Tundra Platinum CrewMax
    This, when I’m driving around a Corolla or Prius because that’s the only loaner available -___- yet that car payment still comes due. Between mountain biking and hunting, I need my truck
    cmiles97 likes this.
  10. Aug 1, 2024 at 4:08 PM
    #460
    AZBoatHauler
    So.Arizona
    Not sure when it happened - but pics are now up of the tear down. Not a good look for Toyota - that’s for sure.
    kirkb and FrenchToasty like this.
  11. Aug 1, 2024 at 4:29 PM
    #461
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    After seeing the chad, do you now think it could be a debris cleaning issue after all?
  12. Aug 1, 2024 at 4:30 PM
    #462
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Which Facebook group is it?
  13. Aug 1, 2024 at 4:32 PM
    #463
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    2022+ Toyota Tundra Owners
    22whatwedo[QUOTED] likes this.
  14. Aug 1, 2024 at 4:35 PM
    #464
    22whatwedo
    The Open Road
  15. Aug 1, 2024 at 4:38 PM
    #465
    22whatwedo
    The Open Road
  16. Aug 1, 2024 at 4:40 PM
    #466
    AZBoatHauler
    So.Arizona
    I honestly don’t know enough about the design of the engine to say for sure - but that kind of looks like water jacket. If it is oil passage - it’s disturbing but doesn’t explain trucks with 62 miles failing last week or all the other trucks failing outside the recall window. They announced the debris issue in early-mid 2023?
    knoxville36, WNY PAT, kirkb and 2 others like this.
  17. Aug 1, 2024 at 4:44 PM
    #467
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Nope .... unless there is more debris in other areas causing oil starvation because pictures posted looks like return oil to pan. But I don't claim to be an expert and shit happens.
  18. Aug 1, 2024 at 5:11 PM
    #468
    MaineTundy
    This is the timeline per their document on NHTSA. A good read. Kaizen assumes they tightened the cleaning process right through May 2024.
    AZBoatHauler likes this.
  19. Aug 1, 2024 at 5:20 PM
    #469
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I can only imagine that large flapper coming loose over time and clogging up the pathway.
    Not really debris yet until it comes loose and travels. This could explain why it takes a while for the engines to seize.
    Retired...finally likes this.
  20. Aug 1, 2024 at 5:22 PM
    #470
    WNY PAT
    WNY PAT New Member
    Western New York
    At this point, in my amateur opinion. seems a lot more likely that the bearing is flaking apart… which explains the Blackstone oil analysis elevated silver and when it really starts to fragment… the catastrophic engine failure. IMO that bearing material circulating through the system fries the turbos (resulting in strange turbo behavior seen) eventually blocks the oil passages and starves the motor of lubrication. Makes a new long block the only solution IMO.
  21. Aug 1, 2024 at 5:32 PM
    #471
    AZBoatHauler
    So.Arizona
    For a long time that date was spring 2023 - alluded here.
    that’s when it was deemed the 2024 MY would be safe. Obviously that wasn’t the case.
  22. Aug 1, 2024 at 5:43 PM
    #472
    WNY PAT
    WNY PAT New Member
    Western New York
    Where are all the metallurgical engineers at? We need to get some metals engineer a failed bearing and a new part number bearing and get some expert analysis. But the idea that this is machining debris is becoming more and more farfetched. I mean, if the ‘24 really ends up having the same failure as a ‘22, even with the “new part number” bearing, Toyota has an even bigger problem on their hands. I hope that’s not the case.
  23. Aug 1, 2024 at 5:44 PM
    #473
    40man
    40man New Member
    Are you interpreting this to say the cleaning process took place after February 2023?
  24. Aug 1, 2024 at 5:52 PM
    #474
    AZBoatHauler
    So.Arizona
    Not the part I inserted but it does say that later in that document @MaineTundy linked.
  25. Aug 1, 2024 at 6:05 PM
    #475
    40man
    40man New Member
    I am not reading it that way from the NHTSA document. I read it that the cleaning process was implemented in February and they continued to research. I have not seen any document from Toyota that says they changed the cleaning process a second time.
  26. Aug 1, 2024 at 6:21 PM
    #476
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    My 6/23 build Gen 3 is still running great. But Im not betting any money on it will continue. I just use it as I normally do.
  27. Aug 1, 2024 at 6:33 PM
    #477
    sudobash
    sudobash New Member
    Read under September 2023 - January 2024
    Last sentence in the second paragraph.
    "It also continued to assess the effectiveness of the manufacturing process changes implemented earlier."
    This is Kaizen. Continuous improvement. If they are assessing the effectiveness, they would also be making changes if the assessment necessitated them.
    AZBoatHauler and MaineTundy like this.
  28. Aug 1, 2024 at 6:52 PM
    #478
    eddiefromcali
    eddiefromcali New Member
    Eddie
    100% Stock
    Of course....this weekend
    Black Wolf likes this.
  29. Aug 1, 2024 at 6:54 PM
    #479
    MaineTundy
    I’m also reading between the lines/assuming the ‘good’ engines they inspected covered all production periods/months. After the research of good and bad engines until May ‘24, they concluded engines produced after the cleaning improvements 2/23 had acceptable debris.
    It doesn’t explain why failures continue. But they do seem to have slowed.
  30. Aug 1, 2024 at 7:12 PM
    #480
    Hearsay
