Transmission cooler or not Thread
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mad Max, Oct 12, 2020.
  1. Jul 26, 2024 at 4:00 AM
    #871
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    for the record - I learned something.
  2. Jul 26, 2024 at 4:18 AM
    #872
    Retired...finally
    A couple of points that have influenced my thinking that lower RPM was more efficient.
    First, in the Pacific Theater during WWII, Charles Lindbergh flew a few missions in the P-38. Twin Allison V12 engines boosted with either supercharging or turbo. ( Can't remember which one). He proved the theory of running over square not only didn't destroy the engine but increased efficiency. Over square is running at a manifold pressure higher than RPM ÷ 100. i.e., 30 inches of MP and 2,500 RPM. Or simply lugging the engine.
    His aircraft was noted to require less fuel to refill upon return from a mission.
    Second was a study done by BMW where they found the higher MPG was achieved at a lower RPM and higher throttle setting. But, this was a manual gearbox.
    There are so many variables such as the decreased torque required in 4th on the Tundra or the most efficient RPM that my old way of thinking has changed.
    Next trip south I'm just staying in S4 all the time instead of shifting to 5th as conditions permit.
    Cpl_Punishment likes this.
  3. Jul 26, 2024 at 6:09 AM
    #873
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    None of this thinking is wrong. It has been proven right but in every case that you have listed above, the power losses through the transmission are the same. Not true going form a 1:1 straight power transfer to a level of gear amplification like overdrive.
    In many cases you will get better efficiency at a lower RPM. You will nearly always make power more efficiently at higher throttle opening (this does depend on some other dynamics of your engine).
    The point here is making power. Every engine has a sweet spot. This sweet spot will vary based on how far open the throttle is. The key is finding that sweet spot for the power that you need.
    When you are poking a big hole in the wind at 60 plus miles per hour, you need to make a lot of power. Look at the torque curve of this engine. It makes peak torque at 3,600 rpm. That is where this engine makes power most efficiently. Now you are not running at full throttle so 3,600 rpm may not be the end game but am am sure that 2,000 is not :)
    Rule of thumb. A gasoline engine turns gasoline into power at about 33%. If you need 150 hp to run your truck and trailer down the road you will need to burn 450hp worth of gas to do it. Give or take.
    It is possible that your engine is more efficient at 2,500 but your transmission is less (it makes a lot of heat). So now your engine needs to make more power at 2,500 than you asking it to make at 3,100. Sure you are making power more efficiently but you are pumping that cheaper power to the front of your truck to your expensive cooler and litterly giving it to the wind. But we feel better because our engine is running slower and our transmission is running cooler :)
    I think that the best answer would be some 4.10 gears in the rear. This would give me a few less revs in 4th for towing and a better overdrive for cruising empty. Maybe......?????? but on second thought, this OD seems to be a little high for the Toyota engineers comfort. They are very quick to let it downshift..... Maybe this is to protect the trans? Maybe it is more efficient to drop a gear than to push that much power through OD?
  4. Jul 26, 2024 at 3:04 PM
    #874
    Retired...finally
    I just got my transmission fluid test results back from Blackstone. I'll try to post tomorrow after I blot out certain information to protect the guilty.
    I will say that my transmission isn't being hurt by the amount of towing I'm doing and can extend my drain and fills out to 50,000 miles. I'll still do it every other year if I continue to tow 2k a year.
  5. Jul 27, 2024 at 6:56 AM
    #875
    Retired...finally
    Here's the report and my letter to them. Don't know why my letter got scanned and saved twice.
    So it look like the transmission doesn't mind a little work now and again. I normally make one trip down and back each year but had to drag the trailer home in January only to go back in February. So I'll continue to do the D&F every other year if I do the once down and back.
  6. Jul 27, 2024 at 7:13 AM
    #876
    nobodyintexas
    nobodyintexas What?
    South of Houston
    What fluid are you using
    I can’t get the download on my phone
  7. Jul 27, 2024 at 7:44 AM
    #877
    Retired...finally
    Good old Toyota brand WS.
    ATV25 likes this.
  8. Jul 27, 2024 at 7:46 AM
    #878
    Retired...finally
    See if this helps
    B.Ross, mverkaik, Bammer and 2 others like this.
  9. Jul 27, 2024 at 12:22 PM
    #879
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    Installed transmission cooler @ 42k miles and today did a drain and fill @ 43k miles.
    Going out on a limb that this is the first one it’s had. Yikes.
  10. Jul 27, 2024 at 12:38 PM
    #880
    Retired...finally
    One easy way to compare color between old and new is to put each in the same size tubing.
  11. Jul 27, 2024 at 2:19 PM
    #881
    Bammer
    Monroe, CT
    Very interesting reading, appreciate the input, commentary,opinions and facts.
    Tripleconpanna and Oey12 like this.
  12. Jul 27, 2024 at 8:48 PM
    #882
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Without a cooler staying in 4th definitely helps keep temps down, they still get hot but not as quickly or as high. With a cooler the temps stay the same in any gear.
  13. Jul 28, 2024 at 5:25 AM
    #883
    mverkaik
    mverkaik New Member
    Hamilton, MI
    No disagreement here. Watching and keeping temperatures in line is very good practice. However, if we only do that, we may not be doing ourselves or our trucks any favors.
    We need to understand where is that heat coming from and why?
    What are the advantages of running in a higher gear and making the heat?
    What are the disadvantages of running in a higher gear and making the heat?
  14. Jul 28, 2024 at 5:31 AM
    #884
    mverkaik
    mverkaik New Member
    Hamilton, MI
    Perfectly red fluid in your transmission is not the goal. Your fluid changes colors because it is doing its job. This is not like gear oil.
    Transmission fluid is design it carry contaminates, wear particles, water etc. It does darken as it absorbs this things. It is capable of carrying a lot.
    Get an analysis done. It will probably show that the wear metals and other things that are being carried are well within the limits of that fluid.
  15. Jul 28, 2024 at 5:56 AM
    #885
    Retired...finally
    We've just about proven you don't save much if any fuel towing in S5. Since my OCI is 5,000 miles I don't think running at a slightly higher RPM is going to reduce the life of the engine enough that I'll ever notice. I do know that towing in S5 with the torque converter locked will increase ATF temps slightly. About 10° F if I remember correctly. I always attributed this to decreased coolant flow at the lower RPM. Here of late it's proven that is only part of the reason.
    One thing I can't see in the Blackstone report is the wear on the clutch packs and brakes. Since insoluble readings are 0 I wouldn't think that would be it.
    bflooks likes this.
  16. Jul 28, 2024 at 6:43 AM
    #886
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I drove commercial trucks prior to my current career. And when I had a heavy load I would run lower gears than when the truck was empty. It allowed for more power and it put less strain on the drivetrain. I have seen transmissions practically “blow” off the truck from the torque because the driver didn’t know what they were doing (too high a gear for a climb with a load). Literally looked like the truck pooped out a transmission. I have seen many cracked fly wheels as a result of the same issue mentioned above.
    Hence why I truly don’t understand the argument against not towing in a higher gear and/or overdrive…. Tundra or Mack…. Lower gear is better.
    The motor can handle the higher revolutions far better than any transmission can handle extreme torque/heat IMHO.
  17. Jul 28, 2024 at 6:56 AM
    #887
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I always have a hard time keeping the torque converter locked in S5.
    Oey12 likes this.
  18. Jul 28, 2024 at 7:32 AM
    #888
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Thank you for taking the time to post this video... It really helps having the visualization of what's happening w/the gears during the various shift points, but also explains why there are so many shift solenoids, etc and what they are each probably doing as the truck works it way through the gears... :thumbsup:
    So, I haven't towed anything significant w/my '21 yet, but my '08 saw a fairly decent amount of time towing a trailer about the size of yours... not having this knowledge or even blue tooth scan tool, etc. while driving, I based most of my driving decisions on the truck's behavior under various conditions. IE>>> If it was hunting for a gear, it wasn't being efficient and I quickly learned that I could mitigate that my remaining in S4 for the majority of time I was towing... (dumb luck I guess) :notsure: But that's where it spent most of its towing time, and I had flawless service while towing and never had the transmission temp needle climb on me and the truck is still in service as it nears 300k.
    Now, as look to possible towing on a regular basis again in the future (but w/the '21), I had been concerned about overheating issues due to the design change of these later year Tundras and had considered adding the cooler before I start towing w/it... This information is very helpful, and it gives me a more factual understanding of my vehicle's 'behavior' (while it had been towing in the past) in relation to transmission gear and performance; which leaves me a lot more confident about towing w/the '21 in OE configuration.
    So, out of curiosity, let me ask this question... How does a gear swap (let's say to 5.29s on 35" tires) affect the efficiency of the transmission and it's gear ratios after the swap?? Is fourth still the most efficient, or does that change? I would assume it changes, but that's only based on what others have said about towing (and just driving unloaded) after a gear swap. They talk about less up/down shifting and gear hunting, and I assumed it was because the truck is staying closer to the 3,000 rpm range so that transmission remains more efficient??
  19. Jul 28, 2024 at 8:05 AM
    #889
    Retired...finally
    On a level road with no headwind I could tow at 65 MPH with the TC locked. I think the turd shaped trailer I tow helps. Speaking of which, have you noticed some trailers that have a one piece nose section partially caved in while being towed? That and the membrane roofing with a big bubble? My Turd has a one piece fiberglass laminated roof that extends from the diamond plate aluminum in the front to the rear bumper. No cave ins or bubbles. Ugly but effective.
  20. Jul 28, 2024 at 8:08 AM
    #890
    Retired...finally
    I had wrongly assumed that 5th was a 1 to 1 drive through the transmission and only 6th was the overdrive. :anonymous:. Pretend the paper sack is a dunce cap.
    Terndrerrr and Cpl_Punishment like this.
  21. Jul 28, 2024 at 8:14 AM
    #891
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It seems like I have to keep my foot in it to keep the TC locked. So if I'm in S5, I can go 100 mph with it locked or I can go 60-65 with it unlocked. Or I can stay in S4 and watch the gas gauge go down.
  22. Jul 28, 2024 at 8:50 AM
    #892
    Retired...finally
    Look into TS-B-0087-21. I had this done proactively. After the reflash I did notice slightly delayed TC unlock but towing and unladen.
    Can't hurt to pester your dealer to do this. Quote the TSB to the service writer and of they blow you off like they did me, call corporate. That got me right in but the service writer gave me the stank eye and gave me the double stank eye when I demanded the under hood sticker to show it was done.
    Oey12 and Cpl_Punishment[QUOTED] like this.
  23. Jul 28, 2024 at 4:41 PM
    #893
    mverkaik
    mverkaik New Member
    Hamilton, MI
    You are welcome. I am nerd about this stuff :)
    S4 will always be the most efficient gear through the transmission. However, like you suspected the best gear for your speed may change. The hard part with big tires and a lift is the extra wind drag and the extra rotating mass. One pound of rotating mass is like adding three pounds anywhere else.
    Tripleconpanna[QUOTED] and ATV25 like this.
  24. Jul 28, 2024 at 4:44 PM
    #894
    mverkaik
    mverkaik New Member
    Hamilton, MI
    Clutch wear in these automatics is basically non-exsistant. The fluid does an excellent job of lubricating while providing enough friction.
    I have also read that transmissions work best with slightly dirty fluid. The particulate matter in the fluid provides almost perfect friction for the clutch packs.
  25. Jul 29, 2024 at 4:54 AM
    #895
    Retired...finally
    @mverkaik it's good to have you here and speaking for the forum, having you share your knowledge is greatly appreciated.
    What are your thoughts on the aftermarket deep transmission pans that hold an additional ~ 3 qts ATF?
    My sister who also owns a Tundra has a Doctorate in mechanical engineering specializing in heat transfer. Next time we talk I'm going to get her opinion on the benefits of the additional cooling of these pans. I have a feeling I'll get a lot of "It depends on ..." from her.
  26. Jul 29, 2024 at 5:10 AM
    #896
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'm going to chime in from the cheap seats:
    I don't think more fluid is better or worse.
    I truly think we should run the trans at a cooler temp than 195.
    I recently got internet jumped for saying one should pin the thermostat open.
    you know, to make it run cooler!
    pinning it open dropped from an avg 200 (unpinned) to 165ish pinned.
    the resident "Toyota engineers" were saying it would run too cool.
    good grief.
    get a trans cooler.
    pin it open.
    enjoy your transmission for years to come.
    Chip_Tundra and ATV25 like this.
  27. Jul 29, 2024 at 5:37 AM
    #897
    mverkaik
    mverkaik New Member
    Hamilton, MI
    Thank you. I enjoy this stuff and have a passion to learn as much as possible.
    More fluid will never hurt.
    It will take longer for the mass to heat up. This is good and it is bad. Toyota did design these to run at 200 degrees and works hard to heat up the fluid.
    It will hold more debris before the fluid needs to be changed. But if you are doing a drain and fill every 30k anyway.....????
    It will take longer for the fluid that is in there to break down. But you are monitoring fluid temp and have proven that the truck is not going to cook it.
    More pan area will provide some additional cooling benefits. But not much.
    Worth the money? IMO, not for you.
    Cool thing to have? Absolutely!
    I would install the cooler before I would do this.
  28. Jul 29, 2024 at 5:39 AM
    #898
    nobodyintexas
    nobodyintexas What?
    South of Houston
    <hat tip> to your absolutely reasonable insight to this question.
  29. Jul 29, 2024 at 5:44 AM
    #899
    mverkaik
    mverkaik New Member
    Hamilton, MI
    Toyota wants this thing to run at 185 or more. That is why the thermostat opens at 185. That is why the pre-heat the fluid with the coolant.
    Cooler fluid is thicker. Thicker fluid will not flow as well, will not pump as efficiently, and may not be doing all that you hope it would.
    Nobody wants to pound on their engine till it is warm. The cold oil is not as effective as warm thinner oil. The same applies to the transmission. Fluid at temperature flows better and performs closer to the design intent of the transmission.
    Now the goal here would be to keep the fluid as close to that 200 degree number as possible all the time. You can add a cooler to do this, you can run the trans in a friendlier gear to do this, you can drive less aggressively to do this. I would not promote pinning the T-stat open.
    Just my two cents.
  30. Jul 29, 2024 at 5:48 AM
    #900
    Retired...finally
    I have noticed that once we leave our wintertime campground on the Gulf we are on a 55 mph road. My transmission will not shift into 6th gear until the ATF reaches 100° F.
    Tripleconpanna and ATV25 like this.
