5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Jun 24, 2024 at 10:38 AM
    #1621
    bflooks
    bflooks New Member
    Metrowest MA
    I wouldn't call that good enough, not even from my house. YMMV
    Which way is front on that photo? If you need the rear to drop, dry deflating the tires to see if that is enough. If that is a driveway, you can also attempt to use the grade in your driveway to your advantage. Otherwise, if those don't work, really wide planks or you can try using leveling blocks (most commonly used by the RV community).
    bulldog93, Mdl and bucketlintels02 like this.
  2. Jun 24, 2024 at 8:22 PM
    #1622
    Jnickoles
    Jnickoles New Member
    2021 Tundra sr5
    Following for when they’re back in stock. I would love to get my hands on one of these
  3. Jun 27, 2024 at 5:12 PM
    #1623
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
  4. Jun 28, 2024 at 4:34 AM
    #1624
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    No kit - just ordered the parts. All arrived fast except the pipes. Last one took some digging since it was ordered just before the nationwide dealer system takeover - so when I called to ask for my part they said they needed a part number to look for it - found it 10 mins later by looking thru their racks - computers were pf no use. This could be why Gen Cooling is behind on orders.
    I added mine on yesterday - 4 OEM parts + a haydon 699.
    Bottom line - easy install - test drove - the overall change is about 35-44 degrees cooler under All circumstances. Before the highest during repeated SG was 248 now the highest is 209 - which can cool down to 185 in about 1 minute of idling. Now that is transmission cooling like never before on my Sequndra - woohoo.
    Adding in parts - cost list
    I used the attached for the part nums plus its good to visualize the setup. The cost breakdown was thermostat 142 - pipe 120 - thermo hoses to pipe (both) 70 - o-rings (2) 8 - haydon cooler 46 hose & clamps 15 1.5 rts trans fluid 12 Total $413
    Took about 4 hrs total to install - test for leaks. So glad I did this. Upset with Toyota for labeling the vehicle with a "Tow Package" that does not include a real trans cooler.
    https://autoparts.villagetoyota.com...NER&model_year=2010&model_year_code=2010:8648
    DPF88130, BushBandit, sd172 and 4 others like this.
  5. Jun 28, 2024 at 4:47 AM
    #1625
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    pin the thermostat & run that rig @ 170degrees.
    ATV25 and Mdl like this.
  6. Jun 29, 2024 at 3:13 AM
    #1626
    Jnickoles
    2021 Tundra sr5
    How do you pin the thermostat?
  7. Jun 29, 2024 at 4:56 AM
    #1627
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  8. Jul 18, 2024 at 1:22 PM
    #1628
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Well I wasn't quick enough when I got my notice that the kits were in stock and so I'm back on the list :( No problem selling at $1300 per kit
    Pig Rig likes this.
  9. Jul 20, 2024 at 5:56 PM
    #1629
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Got my notice and cooler kit is ordered from GCS.....oh yeah
    OHwendTrd and ATV25 like this.
  10. Jul 23, 2024 at 11:49 AM
    #1630
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    PXL_20240723_183858829.jpgNow the work begins
    Set up the OBD sensor and app 7/23
    Mounted the brackets and fittings on the cooler 7/24
    Tripleconpanna, sd172, ATV25 and 3 others like this.
  11. Aug 17, 2024 at 6:48 PM
    #1631
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Question..
    Are you guys using the Sparks parts 2017 tundra part with the thermostat and external cooler OR one or the other?
    BR73 likes this.
  12. Aug 17, 2024 at 6:54 PM
    #1632
    bflooks
    bflooks New Member
    Metrowest MA
    Someone else correct me, but <=2018 are the parts. Better aftermarket coolers are available if you are willing to fab your own bracket, else stock will work and return everything to pre-2019 status.
  13. Aug 17, 2024 at 6:59 PM
    #1633
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I dont understand you question.
    you need to use a an aftermarket cooler because the 2018 and under used a section of the AC condenser for cooling.
  14. Aug 17, 2024 at 7:04 PM
    #1634
    bflooks
    bflooks New Member
    Metrowest MA
    AND that's why the forum is so great. I was 1/2 right, and that almost makes the 80% rule.
  15. Aug 17, 2024 at 7:15 PM
    #1635
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Look up GCS AT cooler kit in this forum
  16. Aug 17, 2024 at 8:10 PM
    #1636
    Johnsonman
    Austin
    Sequoia
    Just buy the parts from a dealer - thermostat - to/from pipe - 2 custom toyo hoses - cooler of your choice - some connectiong hose and clamps. Attach the cooler directly to the AC condensor and yes your cooler kit will come with cushion pads to protect cooler and condensor. This will cost sub $500 maybe 450 is you shop well. Direct attachment to the condensor yields Best cooling - mouning 4" or more away reduces cooling by about 30-40% then under heavy SG it may need an aux fan to help out. Luck deciding.
  17. Aug 19, 2024 at 5:21 AM
    #1637
    xcalbr2
    xcalbr2 New Member
    Can you explain this more?
    If its mounted like the GCS kit and not directly on the condensor, why is it not getting good cooling?
    thanks,
    X
  18. Aug 19, 2024 at 6:06 AM
    #1638
    Johnsonman
    Austin
    Sequoia
    If mounted there and its still not enough then I would add an Aux fan over it. Use a 5 way relay. The signal wire goes to the Ignition via an Add a Fuse connection and the constant hot can go to any free 20amp+ source (I used the trailer sway control for example). Using this your rig should run 170 in most situations with temporary spikes to 200 under the most extreme SG situations yet it will cool down to mid 180s in seconds after speed is stabilized. Luck.
    Tunrod and bulldog93 like this.
  19. Sep 16, 2024 at 7:31 AM
    #1639
    xcalbr2
    xcalbr2 New Member
    Question: what are you all running temps wise after the install - drove truck about 10 hours home from vacation and exited the highway. My scan gauge 3 was set to alarm at 210* and the converter (I think) temp alarm went off while sitting in traffic on side roads. Usually the two temps (pan and converter) are within 2-4* of each other and did very well while on highway. I have driven to work etc prior to my trip and had no alarms.
    I checked the fluid level and all good and no leaks. Is 210* ok and just due to the long drive maybe?
    Thanks in advance,
    X
  20. Sep 16, 2024 at 7:37 AM
    #1640
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    My can go 220+ in hot weather when pedaling hard. Way better then 270+ in chilly weather when not pedaling at all.
  21. Sep 16, 2024 at 7:38 AM
    #1641
    Johnsonman
    Austin
    Sequoia
    I drove mine mid-aug (100+ outside temps all the way) for 14 hours - cruising 75-80 the trans tc (higher of two) would be at 170 - during multiple stop-go lights in towns it would climb to 190 for a few seconds then back down again.
    I've got a fan going on the trans cooler. Without it the temps would be about 20 or more degrees hotter in all cases.
    I think 210 is ok for momentary temps (like in multiple stop/go's)- not constant cruising but that's my opinion only.
  22. Sep 16, 2024 at 7:52 AM
    #1642
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I've seen 210+ TC on a few occasions mainly going up hills in D then I slap over to S4 or S5 and it cools back down to pan temp very rapidly. My question with the vertical mounted GCS cooler is that the trans fluid out line is connected to lower port of radiator and trans in is connected to the top. I was always led to believe for thermal efficiency vice versa like engine cooling system. I called them about that and they said trans out connected at the bottom is better for removing air?
  23. Sep 16, 2024 at 8:08 AM
    #1643
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Can you show us how you mounted the Hayden?
  24. Sep 28, 2024 at 4:34 AM
    #1644
    Hat and Beard
    Hat and Beard New Member
    Southern New England
    2020 Toyota Sequoia TRD PRO
    Which shop did it? I live in RI, and wouldn't mind the drive to have someone with experience do it right. Thanks!
  25. Sep 28, 2024 at 5:06 AM
    #1645
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yes. In vertically mounted oil coolers hot fluid flows upwards.
    Tunrod[QUOTED] likes this.
  26. Sep 29, 2024 at 6:46 AM
    #1646
    Bammer
    Monroe, CT
    Fairfield Automatic transmission in Fairfield CT. Ask for Scott
  27. Sep 29, 2024 at 3:41 PM
    #1647
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    I'm getting my wires crossed.
    Are you saying that the GCS cooler instructions are correct in that the transmission out/GCS oil cooler-in is at the bottom of the vertically mounted cooler, and the transmission-in/GCS cooler-out is at the top of the vertically mounted cooler? Or the opposite?
  28. Sep 29, 2024 at 3:50 PM
    #1648
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Hot/in - at the bottom, cold/out - at the top.
    ATV25 and BR73 like this.
  29. Oct 14, 2024 at 6:30 PM
    #1649
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    Finished installing mine today. It was a bit of a PIA. Had to remove my Valhalla plates and some of the tight areas really suck. My hard lines mounting seemed to be a bit further apart than the holes and took a long time getting it put in. But done and ready to see the lower temps. Oh and still need to put the plates back on. Tomorrow's problem.
  30. Oct 14, 2024 at 6:39 PM
    #1650
    bucketlintels02
    NW Georgia
    Great job. It’s well worth the time, money, and effort (and sore body aches).
    OHwendTrd, Explorer[QUOTED] and BR73 like this.
