Ode to FGT; a refresh story
Discussion in '1st Gen Tundras (2000-2006)' started by KNABORES, Jun 20, 2024.
  1. Jul 15, 2024 at 2:30 PM
    #91
    shifty` You can call 1 (800) PP5-1-DooDoo
    KNABORES[OP] likes this.
  2. Jul 23, 2024 at 6:38 AM
    #92
    KNABORES [OP] Sarcasm incoming
    Some more parts ordered. Hopefully some of my Serra order has arrived. Been on vacation this week, so zero progress.
    Fobroader, Weagle, BroHon and 6 others like this.
  3. Jul 24, 2024 at 8:25 AM
    #93
    Campershell lighting bits have arrived. Some Amazon prime day scores.
  4. Jul 24, 2024 at 11:43 AM
    #94
    Test fitted my Rhino rack off the 2019 on the FGT. These dang racks are $550 now. If I buy some new mounting rails for $150, I can reuse the bars and feet and save the $400. Whoever buys the 2019 can buy some bars if they want.
  5. Jul 24, 2024 at 12:25 PM
    #95
    Mawfawkin loot crate has arrived!
  6. Jul 24, 2024 at 12:40 PM
    #96
    My order-fu is not the best apparently. I only ordered one tie rod end (really thought it said it was a pair?) and one intake manifold gasket. Also got some internal cylinder component of the steering rack instead of a full set of rack bushings.
  7. Jul 24, 2024 at 2:33 PM
    #97
    Couple small things today:
    AC blower fan replaced. Super easy if you’ve never done it, one electrical clip and 3 bolts - 8mm. Lives under the glovebox.
    My old non-oem replacement from 15 years ago. I broke my original trying to get the fan off to clean it.
    Old vs. new:
    Also added my strut switch for my topper lights and cleaned up the wiring harness with some loom and zip ties to secure. Will do the LED strip install later.
  8. Jul 24, 2024 at 4:56 PM
    #98
    You got a grommet on that hole, bud?
  9. Jul 24, 2024 at 5:39 PM
    #99
    Nope
    bmf4069 likes this.
  10. Jul 26, 2024 at 7:23 AM
    #100
    More loot has arrived. Timing belt kit and new LED fog light replacements. Ordered the missing tie rod end, intake gasket and ball joint for the right side o_O. All told sitting around $1650 in parts (including exhaust). I would consider most of this stuff to be 10yr maintenance parts, so if it’s 10 years before all of this stuff needs to be done again, that’s not too bad.
  11. Jul 26, 2024 at 7:37 AM
    #101
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  12. Jul 27, 2024 at 5:35 AM
    #102
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Maybe I missed it but why did you replace the AC blower fan? Because it wasn't OEM and preventative maintenance? Wanna know if there are symptoms to watch out for on a failing fan.
  13. Jul 29, 2024 at 5:08 AM
    #103
    It’s a bit noisy. Whirring and whistling occasionally. Also had a mild bearing noise for years. New OEM is smooth and quiet and seems to have a bit more airflow.
    DarkMint[QUOTED] and BroHon like this.
  14. Jul 29, 2024 at 5:11 AM
    #104
    Swapped in the Phillips 9006 LED bulbs into the factory fog light housings. WOW. Very bright. A bit more light scatter than the modified 9012s. Light color temp matches the Colight mini projectors better.
  15. Jul 29, 2024 at 10:10 AM
    #105
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I should probably do this. I don't even run my fogs with the CO lights but that's partially because they don't match colorwise and look weird. I do occasionally run parking lights and fogs when it isn't real dark out yet.
  16. Jul 29, 2024 at 10:23 AM
    #106
    It's amazing the amount of low and medium range fill these 9006 LED's provide. A little concerned with the light scatter, I'll have to continue to assess. Really spreads light into the adjacent ditches, great for spotting suicidal critters.
    BroHon, 455h0le_dachshund and Mr.bee like this.
  17. Jul 29, 2024 at 10:26 AM
    #107
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    They must mow along the shoulders up there. Tall grass made my factory fogs useless.
  18. Jul 29, 2024 at 10:32 AM
    #108
    NickB_01TRD
    KY
    That's what I was worried about too. I'll let you test them out and see what it looks like.
  19. Jul 29, 2024 at 10:33 AM
    #109
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The yellow fogs on my 06 are awesome down on the south coast during the foggy months from january-march
  20. Jul 29, 2024 at 10:36 AM
    #110
    I thought about applying some of the yellow film to the fogs.
  21. Jul 29, 2024 at 10:37 AM
    #111
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Lamin-x is what I used. It comes pre cut. Easy to apply, no mess stick
    KNABORES[QUOTED][OP] likes this.
  22. Jul 29, 2024 at 10:38 AM
    #112
    Also seriously considering wrapping the hood and roof in satin black Vvivid+ film.
  23. Jul 29, 2024 at 10:48 AM
    #113
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If I ever wrap my hood, I'm going full 2000's ricer with carbon fiber wrap lol
    Fobroader and FrenchToasty like this.
  24. Jul 29, 2024 at 10:50 AM
    #114
    That’s available. The topo wrap looks kinda cool too.
  25. Jul 29, 2024 at 10:52 AM
    #115
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I see that a lot
  26. Jul 29, 2024 at 10:56 AM
    #116
    I’d want one of a local range not some random design though
  27. Jul 29, 2024 at 3:37 PM
    #117
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Speaking of fog lights- I've been brewing up this idea for a while.
    I'd quite like to have more powerful fog lights to match my mini projectors, but I'm skeptical of what change an LED bulb would do. What if one was to cut a square hole out of the back of the fog light housing, maybe exactly the same size as these: https://www.diodedynamics.com/stage...QEGqAK4o1Ph922ERSvLjM-H8bUu2uSawaAoKiEALw_wcB and then just glue them in place and wire them up?
    I feel like that would work pretty well. I'd keep the lens on the housing to retain a factory look but I think that would really increase the output and maintain a nice beam. Since the fog lights have height adjustments too, I think that you could get them aimed pretty well if you cut the hole accurately enough. Idk. Just an idea.
  28. Jul 29, 2024 at 7:03 PM
    #118
    Installed the camper shell lights tonight once the evil sun went down. Cleaned the wiring up as much as possible. We’ll see if the adhesive holds up, or if stronger stick ‘em will be needed.
  29. Jul 29, 2024 at 7:04 PM
    #119
    Also does fun colors and dances to the music cause, I like to party.
    activated by the prop rod switch, so they automatically come on when you open the cap.
  30. Jul 29, 2024 at 7:09 PM
    #120
