  1. Jul 21, 2024 at 7:50 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  2. Jul 21, 2024 at 7:54 PM
    Hutcheson
    Hutcheson New Member
    Caleb
    2004 DC Limited
    Coming along nicely :101010:
    JakeJake[QUOTED] likes this.
  3. Jul 21, 2024 at 7:58 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I did a little something over the weekend. Not sure @shifty` will approve since the outside trim isn’t color matched ;) but I’m trying it out for now. I will have to figure out the bottom chrome piece along with the trim of the grill.
  4. Jul 21, 2024 at 8:14 PM
    tbugnet15
    tbugnet15 New Member
    2001 Access Cab v8 4wd TRD Limited
    Would have been nice to see this like 2 hours ago BEFORE i muscled the drums off lol. I didnt break anything tho, like when i did my 98 corolla rear brakes earlier this year.
  5. Jul 21, 2024 at 8:19 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    @Kimosabe I like that. Where is best place to get this grill?
    Kimosabe likes this.
  6. Jul 21, 2024 at 8:22 PM
    tbugnet15
    I used those holes, my harbor freight bolt snapped off in the threads right after the rust broke free thank goodness. The drums had just enough life that they didnt catch the shoes (like my corolla; bent pistons on the brake cylinders shoe retainer clips went flying, adjusters and parking brake hardware all bent) I was able to hammer and pry the rest of the way. I always presoak with pb blaster the night before and wire wheel or steel toothbrush as much as i can around the hub and in each lug hole. The drums cracked around the bolt holes so theyre getting replaced anyway with coated ones.
    oscardog86 and BroHon like this.
  7. Jul 21, 2024 at 9:02 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    oscardog86, khooiii, VR6T and 4 others like this.
  8. Jul 22, 2024 at 2:10 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    https://youtu.be/QuLpY-0dIg8?si=33bEKGmo2rqr4E9R
    I love a black grill on a blue truck.
  9. Jul 22, 2024 at 7:09 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
  10. Jul 22, 2024 at 7:27 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Any other power mods?
  11. Jul 22, 2024 at 8:00 AM
    Riverdale21
    OTP ATL
    Going to do a full thread on it later.
    OV Tune base high octane map w/shift points, Stan's Tri-Y headers (1-5/8" primaries), custom Borla 2.5" header back exhaust single exit, Dirty Deeds 12 hole injectors, AEM dry-flow drop in air filter (only using it because I got it for free).
  12. Jul 22, 2024 at 8:24 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So to be clear, the tune made these gains over your last dyno with all power mods minus tune? Stock vs tuned numbers would be dope too. :cheers:
    Edit: I see now you edited your post
    Riverdale21[QUOTED] likes this.
  13. Jul 22, 2024 at 8:32 AM
    Riverdale21
    OTP ATL
    Yup. Numbers posted were above already modded truck. Here's the breakdown:
    Stock: 248hp/278tq
    Headers, exhaust, injectors: 252hp/284tq
    All previous mods + OV Tune: 259hp/310tq
    Those peak numbers may not seem impressive but all mods combined I gained nearly 70tq over stock at around 3,000 RPM.
    I didn't realize until I left they didn't print an overlay of today vs previous run.
  14. Jul 22, 2024 at 9:25 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I got this one from Taco Vinyl. They had the best price and are only 2 hours from here so I went through them.
  15. Jul 22, 2024 at 10:07 AM
    I think having the bumper unibrow blacked out actually pulls it all together. Only reason I like the outer paint-matched is b/c it gives it that "OEM+" look, like it came from the factory that way.
    455h0le_dachshund likes this.
  16. Jul 22, 2024 at 10:36 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
  17. Jul 22, 2024 at 10:40 AM
    No I mean, like, are you a car person?
  18. Jul 22, 2024 at 10:40 AM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Never trust a dynojet always try and find a land and sea hub dyno. Good numbers tho
  19. Jul 22, 2024 at 10:46 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I'm just giving you a hard time.
    I held off on getting it because I knew it would be a while before I could color-match it, but the old one looked so bad I couldn't stand it. The guy put metal snaps on it for some reason. I totally agree and would prefer the OEM look. I can't decide what to do about the bumper trim piece though. Might look for color matched wrap.
    shifty`[QUOTED] likes this.
  20. Jul 22, 2024 at 12:19 PM
    Jasons2006Tundra
    Jasons2006Tundra New Member
    2006 Tundra DC SR5 4wd 4.7 TRD
    I need a new pcv hose. Is there anything wrong with using generic vacuum hose? The price on a hose from a dealer website is outrageous.
    Jack McCarthy likes this.
  21. Jul 22, 2024 at 12:29 PM
    VR6T
    There shouldn't be an issue. Just make sure it's a stiff or reenforced wall hose
  22. Jul 22, 2024 at 1:46 PM
    VR6T
    Doing a thing.... Finally. The other bulbs will be here in a hour or soIMG20240722154532.jpg IMG20240722154541.jpg
  23. Jul 22, 2024 at 2:15 PM
    VR6T
    Well I know why my Drive light wasn't working..... Like how? There's nothing loose inside the dash unit
  24. Jul 22, 2024 at 2:31 PM
    Maybe? I just bought 'em from Toyota. They came custom-formed, and insulated with the appropriate foam, pre-bent to avoid kinks. ~$20 ea, and that wasn't during a sale. #1 is driver side. #2 is passenger side. Current pricing for local pickup from a nearby dealer is actually 10% cheaper than these prices I got from LaGrange ...
    abcinv and FrenchToasty like this.
  25. Jul 22, 2024 at 3:04 PM
    bfunke
    bfunke Tundra Curmudgeon
    @shifty` - can you post a pic of that vent hose #2. The part # is close to the discontinued one for my 2000 and I wonder if I can make it fit. Thanks friend.
  26. Jul 22, 2024 at 3:23 PM
    Jasons2006Tundra
    $2 vacuum hose from Napa and I'm done. We will see how long it hols up. Passenger side hose was good.
  27. Jul 22, 2024 at 3:26 PM
    VR6T
    Can some one explain to me how I ordered the T5 and T10 LED bulbs the same day and the T5 package 1 showed up Wednesday, T5 package 2 showed up today and the T10s just shipped, at 458pm, but alledgedly are supposed to be here between 530 and 10pm today....
  28. Jul 22, 2024 at 3:31 PM
    Jasons2006Tundra
    They got Superman working in the shipping dept he's flying you those bulbs right now and will be ringing your doorbell momentarily
  29. Jul 22, 2024 at 3:33 PM
    VR6T
    ........... I would hope Superman would either fix or burn Amazon down. And fix and burn are interchangeable at this point
    Tlar25 and FrenchToasty like this.
  30. Jul 22, 2024 at 4:32 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    https://www.toyotapartsdeal.com/pag...ter=()&keywords=12261-50050 HOSE, VENTILATION
    I just ordered one for myself. Is it pricey? Yeah, but the original one has managed to damn near last this long why not. At 23 bucks I'll just toss it in with the rest of the order.
    FrenchToasty and VR6T like this.
