General Supercharger Thread
  1. Jul 18, 2024 at 3:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you got the 1900 you can hang it off the side of the blower just relocate the purge. But wherever is room for this stuff...
    reywcms and HulkSmurf14 like this.
  2. Jul 18, 2024 at 3:18 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Interesting location!
    Mdl likes this.
  3. Jul 18, 2024 at 3:19 PM
    pursuit2550
    pursuit2550 New Member
    Well, I said I would check my Radium CC after my trip. It's been 2300 miles and it has oil in it. Looks like it has a tad bit more oil than my JL CC caught after 5k. Needless to say, all that fancy crap they put in it was a waste of money, time, research, etc. and not needed.
  4. Jul 18, 2024 at 11:27 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Nope, got the 2650
  5. Jul 19, 2024 at 7:17 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    The box weighs more than the cable.
    Mdl and Wynnded like this.
  6. Jul 21, 2024 at 2:56 PM
    ARES35
    ARES35 New member for life
    Mile high
    Still tuning for downpipes here. Air fuel is almost dead nuts across MAF/PE but still fumbling above 4.53 WOT. Noticed when tune is fresh she is extremely rich 8/9 at wot for first few pulls. Once KCL learns then it leans out at it seems. I'm assuming that is how I blew a cat. Probably dumping fuel and then it ignited. At least for me it's been deceiving, tune MAF, rich as shit, then KCL adjust and correct a/f. Just sharing my experience since I've thrown misfire codes, blew up a cat.
    AZTundra, M3Tundra-JK, Mdl and 2 others like this.
  7. Jul 21, 2024 at 8:08 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  8. Jul 21, 2024 at 8:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    ARES35, AZTundra, HulkSmurf14 and 2 others like this.
  9. Jul 21, 2024 at 8:20 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mdl[QUOTED], AZTundra and HulkSmurf14 like this.
  10. Jul 21, 2024 at 8:30 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
  11. Jul 21, 2024 at 8:39 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  12. Jul 22, 2024 at 12:32 AM
    blenton
    blenton New Member
    Any concerns with the spacers being made out of Delrin? Temperature rating up to 250F. I have no plans to cook a motor. Also, any concerns with a blower putting more leverage on Delrin spacers and getting some movement out of them? How much heat do you suppose the blower creates as opposed to being heat soaked by the motor. I see they will make them out of aluminum, as well. I’m speaking mostly out of my hind quarters and asking out of curiosity without really know much about them.
  13. Jul 22, 2024 at 5:34 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Of course it’s cheaper, too! One of their prototypes is finally on my truck… been sitting in my barn since 2017. I’ll write a thread on my thoughts soon.
    Mdl, Land Bruiser, nags and 3 others like this.
  14. Jul 22, 2024 at 6:03 AM
    e30cabrio
    I have this question too.
    Why can't the OEM gasket be used?
    Wynnded likes this.
  15. Jul 22, 2024 at 6:13 AM
    HulkSmurf14
    2014 Tundra Limited
    I'd imagine if boosted, we'd need the aluminum versions... but that's purely an assumption... as far as the plenum spacer is concerned...
  16. Jul 22, 2024 at 6:56 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I also would think delrin may not hold up long term to the heat, pressure, and greater torque applied to it from use with a supercharger. It would provide a better thermal barrier though. I don’t know much about the material though, so just more speculating. Gonna need a guinea pig.
  17. Jul 22, 2024 at 6:59 AM
    e30cabrio
    Obviously, we need a sandwich. Delrin, Aluminum, Delirn.
    lol
    Also, don't these kinds of torque raising mods lose HP? (I like torque so it most likely is moot for me but I'd like to know)
    HulkSmurf14 likes this.
  18. Jul 22, 2024 at 7:01 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    About the only thing that I can add about the Delrin is that it's pretty tough, such that it needs to be machined. How it tolerates heat cycles, I don't have a clue.
  19. Jul 22, 2024 at 7:03 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Kind of like a reverse Oreo.
    I'm not even sure what the potential differences it would make with a S/C would be; data needed.
  20. Jul 22, 2024 at 7:10 AM
    Silver17
    Eastern PA
    I think it’s really all about the heat soak thermal barrier with the SC more so than any other potential benefits.
    blenton, e30cabrio and Wynnded like this.
  21. Jul 22, 2024 at 7:10 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    nags and e30cabrio[QUOTED] like this.
  22. Jul 22, 2024 at 7:41 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    PML chose not to design or machine the flange to accept the stock grooved rubber gasket. They supply a a cork gasket. Mine went in the trash. Bad memories of attempting to seal things with cork and Indian Head.
    Form in place gasket all day long here. While it certainly makes servicing the pan less convenient, it has a possible, and, if true, not insignificant benefit. Stiffening up the main transmission case. The flange is wide and .44” thick, not to mention the entire pan is straight beef at over 11 lbs. Bolting and essentially gluing to the case, thus becoming part of the structure along the entire perimeter.
    There are other benefits that this pan hold, with a little machine work. Should probably give it a thread.
    Mdl, Wynnded, e30cabrio and 1 other person like this.
  23. Jul 22, 2024 at 7:54 AM
    nags
    nags New Member
    Making a list of more things I don't need but need....
    nobodyintexas, Mdl and Wynnded like this.
  24. Jul 22, 2024 at 7:56 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Exactly...:facepalm:
    Mdl likes this.
  25. Jul 22, 2024 at 8:19 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Any pros/cons vs the B&M pan that uses the OEM gasket?
    Mdl likes this.
  26. Jul 22, 2024 at 8:33 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The only reason I'd go with aluminum is to add injection ports for extra injectors, methanol or NOS for individual cylinders. . Of course after doing that built forged engine...ha
    e30cabrio and Wynnded[QUOTED] like this.
  27. Jul 22, 2024 at 8:37 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I remember you posting on the other site when you got it. Was around the last time I was on there. Would like to hear more info...ideas you have!
  28. Jul 22, 2024 at 9:06 AM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    Only one con I can see is that you need more transmission fluid . I have the B&M pan under WOT my temps don’t cross 229 and this is without a cooler. Either pan is definitely worth it. Temps drop significantly at cruising speeds fyi , the bigger pans make a huge difference in heat transfer with double the capacity.
    nags and e30cabrio like this.
  29. Jul 22, 2024 at 9:49 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    The B&M looks a bit “tidier”.
    Comes with a massive magnet, but no inspecting/cleaning w/o pan R&R
    Uses the stock gasket, which is much nicer if the pan needs to be R&R’d.
    PML has baffles.
    Might(?) be structurally stiffer/stronger when installed with FPG and some larger M8 bolts or studs.
    Small magnet on drain plug.
    Mods for PML
    With mods to the overflow drain hole, a Fumoto or EZ Drain can be added. This allows an easier filling procedure as the overflow can simply be turned on/off with the lever when temp is reached. The B&M over flow is positioned where installing a valve is not possible. The valve will also allow easy sampling of ATF fluid to check condition. Slowly slide the lever and grab a couple drops, a teaspoon, or fill a sample bottle to send off for UOA, then close it up… no fiddling with a drain plug.
    There are three bungs on the pan, only one is machined for the drain valve. The other two could be drilled tapped for some large magnet plugs. All magnets can be removed and easily be inspected for debris, or cleaned during fluid service. Three of these should do it.
    Lowering the pick up tube inside the pan is also something we should look at. Neither pan offers this.
    nags, e30cabrio, Ctaylor76 and 3 others like this.
  30. Jul 22, 2024 at 9:55 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Looks good! May redo my radium setup when I pull the blower next month. Modded it and need to see if we're gathering more crap than before.
