The Great HU Install of 2023
Discussion in 'Audio & Video' started by RainMan_PNW, Aug 19, 2023.
Did you get in on the recent Best Buy clearance frenzy? What did you get?
  1. Alpine ILX-F511
    35 vote(s)
    27.6%
  2. Alpine ILX-F509
    3 vote(s)
    2.4%
  3. Alpine ILX-F507
    0 vote(s)
    0.0%
  4. Kenwood DMX-1037S
    16 vote(s)
    12.6%
  5. Something else (let us know in the thread)
    4 vote(s)
    3.1%
  6. I bought enough to start my own car stereo franchise
    2 vote(s)
    1.6%
  7. No - I was late to the party
    52 vote(s)
    40.9%
  8. No - I didn't need a new head unit
    19 vote(s)
    15.0%
Multiple votes are allowed.
  1. May 23, 2024 at 5:26 PM
    #961
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I've got a whole fucking basement of that.
  2. May 23, 2024 at 5:28 PM
    #962
    You welcome to my stache, just in case you know
  3. May 23, 2024 at 8:24 PM
    #963
    RainMan_PNW
    Casey
    Clark County, WA
    A question came up today separately, so thought I'd put the answer up here to help clarify things.
    Do I need the HRN-RR-TO3 or the HRN-HRR-TO3 harness for the Maestro? A similar question applies to the Gen2 with the "TO1" harness and the Gen2.5 2014-2019 trucks with the "TO2" harness.
    As shown in the flow chart, the RR harness is not "Plug and Play" while the HRR harness is. But what does that mean exactly?
    The RR harness looks like this. You have bare wires for the speaker connections and you will need to connect all of these bare wires to the harness(es) that came with your radio.
    The HRR harness looks like this. It has a connector with all of those wires running into it. That connector means you will need to buy another harness (specific to your head unit) that will go between that connector and the head unit.
    Here is the Alpine harness (as an example). The purple arrow connector will mate up with the HRR purple arrow. The teal arrow connector will go directly into the back of the head unit (replacing the harness that came with it).
    Do note that if you use the HRR, that doesn't mean you won't still have wires to splice...just a few less of them. Also know that the connector between these two harnesses takes up some space that you might not otherwise need if you were to stagger your splices and shorten up the wires a bit.
    Azblue, TaquitoBandito, GWill and 2 others like this.
  4. May 24, 2024 at 7:47 AM
    #964
    daveeasa
    I’ve been just crimping terminals on the ends of my Pioneer pigtails. Then inserting them directly to the Toyota connectors. Makes for a clean install with or without maestro. Last few have been without (dad’s ‘04 RAV4 and ‘06 Tacoma).
    bulldog93 likes this.
  5. May 24, 2024 at 8:15 AM
    #965
    RainMan_PNW
    Casey
    Clark County, WA
    On older vehicles where there’s no real integrations between the vehicle and the HU, that’s a great way to go (even newer rigs if just connecting directly from the HU to the factory speaker wiring).
    TaquitoBandito likes this.
  6. May 24, 2024 at 12:15 PM
    #966
    Azblue
    The Dirty T ( ^_^)_且
    Anyone else having an annoying issue when changing XM stations up/down using the steering wheel buttons? When I hit the button it switches to a screen with icons for the stations you can scroll left/right. After you've selected a new station there is a few seconds pause and it changes back to the main XM screen. Problem is that the the sound cuts off during the screen change. Occasionally it doesn't cut out, but most of the time it does.
    TaquitoBandito and bulldog93 like this.
  7. May 24, 2024 at 2:18 PM
    #967
    TaquitoBandito
    Joel (AKA Bif)
    Have you tried punching it?
  8. May 24, 2024 at 3:08 PM
    #968
    Azblue
    I have considered it
  9. May 25, 2024 at 7:38 AM
    #969
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    Well shit
  10. May 25, 2024 at 8:16 AM
    #970
    centex
    centex New Member
    Has anyone found a way to add PID’s to the RR2? I got a Sony XAV-AX4000 with the rr2 installed yesterday. I’d really like to get rid of my scan gauge and use just the head unit but it won’t read trans temp.
  11. May 25, 2024 at 8:34 AM
    #971
    RainMan_PNW
    Casey
    Clark County, WA
    Just as it’s too late to cancel that order I’m sure
  12. May 25, 2024 at 12:49 PM
    #972
    GWill
    Willis
    2020 MGM TRD Pro
  13. Jun 1, 2024 at 3:13 PM
    #973
    GWill
    Willis
    2020 MGM TRD Pro
    Alright I have one for you guys.
    Alpine F511
    2020 W/ JBL
    • My compass on my dash isn’t working
    • When I hard wire my iPhone into the CarPlay port, it charges my phone but I get a message that says cannot connect to device
    • Clock on alpine doesn’t work
    • When I try to wirelessly connect to CarPlay, it says my GPS antenna isn’t connected.
      • I’m connected to the white OEM connector with the pigtail from discount electronics
      • XM is working so I should have the right antenna, right?
    I have torn this thing apart a few times now and am now seeking help from the pros. Anyone run into something like this yet? IMG_9836.jpg IMG_9837.jpg IMG_9835.jpg
  14. Jun 1, 2024 at 4:26 PM
    #974
    1794TX
    Steven
    N.TX
    '20 1794
    The compass on the dash was driven by the nav unit in the factory HU, and I don't think you get that back. I use that as my default dash gauge as well, so it's gonna suck a bit when I get a new HU.
  15. Jun 1, 2024 at 6:31 PM
    #975
    Azblue
    You did install the additional GPS antenna, not just the stock XM one, right?
  16. Jun 1, 2024 at 6:40 PM
    #976
    GWill
    Willis
    2020 MGM TRD Pro
    I used the adapters rainman found to connect to the oem antennas. I didn’t use the additional antennas for either the gps or XM
  17. Jun 1, 2024 at 6:47 PM
    #977
    Azblue
    Should be good then. I used the factory XM and the GPS from the Alpine. But as long as you have the 2, I would assume it's good.
  18. Jun 1, 2024 at 7:38 PM
    #978
    RainMan_PNW
    Casey
    Clark County, WA
    You’ll lose the instrument panel compass. It’s tied to the factory HU Nav, not much else you can do but get a dash compass or replacement rear view with the integrated compass.
    As for the others, it sounds like a loose connection. White is correct for the GPS (same color as the adapter cable).
    And are you 100% sure you’re connecting hard wire to the CarPlay USB cable (one works for CarPlay, one doesn’t).
    bulldog93 and FrenchToasty like this.
  19. Jun 1, 2024 at 7:50 PM
    #979
    GWill
    Willis
    2020 MGM TRD Pro
    Ill pull it apart and snag some pics tomorrow. Im pretty sure due to the fact that is says "Unable to connect to device" when I plug in at the bottom of the dash
  20. Jul 10, 2024 at 9:01 PM
    #980
    NewOwnerHere
    NewOwnerHere New Member
    Finally installed the ILX-F511, bypass module, and hdmi/usb port. Thanks to those that posted their experiences. I really found post #8 and #249 helpful trying to figure out how to connect the bypass module. Also, the YT video how to take the dash/glovebox apart to route the hdmi/usb port.
    I have only taken out the head unit 8 times. One more time to get the screen closer and I will be done for the installation part.
    Likes
    1. Play videos for the kids while driving via laptop or USB flash drive
    2. Mirror phone screen to play more videos for kids. For those with a Samsung phone, turn off auto start option for Samsung DEX.
    3. Screen size
    4. Gauge screen (yes, transmission temp shows up for me. I have a 2021 SR5)
    5. Wireless android auto
    Dislikes
    1. Wireless android auto. Does not work all the time and I have to manually connect it.
    2. Backup camera grid lines. I need to adjust the indicator lines.
    3. No split screen for different inputs. I would like to have Google maps and a video playing but I don't think that is an option.
    4. Cost. Wish I got in on the BestBuy deal.
    bulldog93 and RainMan_PNW[OP] like this.
  21. Jul 10, 2024 at 9:59 PM
    #981
    meagain
    meagain New Member
    Do you know if screen mirroring works with the iPhone? I see you have Android, but hoping you or someone else knows how and could fill me in
  22. Jul 11, 2024 at 5:12 AM
    #982
    NewOwnerHere
    No, I don't know about iPhone personally. I did see a few YT videos where people screen mirrored with the lightning cable. For my android phone I'm hardwired via hdmi to usb-c. I imagine if you use a similar cable for iPhone it should work the same.
    meagain[QUOTED] likes this.
  23. Jul 20, 2024 at 4:31 PM
    #983
    Well 6 months later I finally got the 9” installed in the 4R!!!! The most difficult part seemed to be pulling most of the dash to fish stuff thru, you almost have to take every panel off just to get to one you need
    Big thanks to @TRDFerguson and @AT x AT for the help with installing! And thanks to @Uncle Bif for the head unit!
  24. Jul 20, 2024 at 4:48 PM
    #984
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I’m just glad we remembered to hook up the damn mic before we buttoned it back up :rofl:
  25. Jul 20, 2024 at 4:49 PM
    #985
    RainMan_PNW
    Casey
    Clark County, WA
    that looks like rocket surgery!
    I can only imagine missing a connector somewhere and having to pull it all back apart.
  26. Jul 20, 2024 at 5:02 PM
    #986
    I’m also impressed with our retention of all the bolts and screws, even with some jumpers in the show
  27. Jul 23, 2024 at 4:59 PM
    #987
    TaquitoBandito
    Joel (AKA Bif)
    :hattip:
  28. Sep 20, 2024 at 3:44 AM
    #988
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Need some help.
    Ordered this. And now I'm trying to figure out what to do with these wires.
    The USB adapter, what is that for? It doesn't plug into my head unit does it? I don’t see a USB plug.
    Did your antenna connector require wiring in the blue wire for power? If so, where do I do that?
    The other two shown not used are gps and xm right? I appear to have a different gps antenna and plug in?
    Will the xm adapter suggested on page one work for the oem xm antenna with thus HU?
    Did anyone's back up connecter have to literally be forced on? Mine required scary force.
    Post with pics and me begging for help is here - https://www.tundras.com/threads/need-some-help-with-my-kenwood-dmx1057xr-install.148413/
  29. Sep 21, 2024 at 6:31 AM
    #989
    1UP
    1UP Truck Gang
    Anyone know why I am getting this refuel message? My install list is in the post above.
    EDIT - Solved. Took a while but the range just popped back up.
  30. Sep 21, 2024 at 12:47 PM
    #990
    1UP
    1UP Truck Gang
    How is everyone changing the boot screen for the dmx1057xr? The threads referencing carboncarsystems website and download the file seem to be OBE. That site is no longer operational from what I found and the download doesn't exist.
    I know the file size must be 1200x720 and your thumbdrive has to be FAT 32 formatted. But when I tap two top left and two bottom left and the one tap top left and bottom left, all the custom options on that "secret" screen show red with NG in the center.
    EDIT - answer is in here.
    https://youtu.be/FS9KdDIyl2o?feature=shared
