Rotor replacement
Discussion in '3rd Gen Tundras (2022+)' started by slowmod, Aug 23, 2022.
  1. Aug 24, 2022 at 11:07 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I've definitely paid a lot more attention to my braking while off roading because of this. Only had the issue pop up one time but the repeated hard slow downs fixed it.
  2. Aug 26, 2022 at 6:49 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    As previously mentioned, the rotor is different due to the six lug pattern. However, everything points to rotor rings as being the same size as the previous generation, 354 x 32mm. The pads are also same as the older generation, at least according to Bendix.
  3. Aug 26, 2022 at 7:13 AM
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    Have you seen how some people stop?
  4. Aug 26, 2022 at 7:16 AM
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    I'm on my 3rd set of brakes/rotors with my 2011... I got 50k on the first set, 70k on the second and am now on my 3rd with 130k on the truck... 17k sounds like something is not right there like others have said. (and I pull a 6500 lb boat/trailer with this truck, have done it 4 times across 1600 miles as well as around town too! so, that's a fairly good load with those numbers still)
  5. Aug 26, 2022 at 7:30 AM
    CMikeB
    CMikeB New Member
    My 2010 SR5 has 88,000 miles on the OEM Brakes. My Mechanic tells me I'll see 100,000 miles with no problem. When the brakes are ready for replacement, I'm trying OEM again. I can be CERTAIN, the new pads & rotors will wear much quicker.
  6. Aug 26, 2022 at 11:58 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Good points. Bedding in new pads and rotors is a good thing. Toyota owners manual will say "No hard braking the first 500 miles" or something like that. A better procedure is something like this https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=85
    Bedding methods vary, there's plenty of info about it from aftermarketers like Akebono etc.
  7. Aug 26, 2022 at 12:19 PM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    My Dakota warped a set of rotors in 12k and another by about 40. My 09 Crewmax’s were wobbling after about 25. I think new materials since the 90s have poorer heat dissipation capability which makes them prone to react poorly to scenarios old brake materials handled better. My 95 Ranger needed rotors turned at 60k which then lasted until after 100. Deficiencies in new materials probably exacerbated in heavier vehicles. Sedans in our family never have these problems but rotors on my last few trucks have always had short lifespans.
    I did resurfacing once on the Dakota when offered goodwill 12k/1 year free service. Not really officially warrantied but a discretionary thing I was told dealers can sometimes get the company to authorize. Otherwise I go aftermarket and never look back.
  8. Mar 24, 2023 at 2:16 PM
    Lotta
    Lotta New Member
    Mine got 20k miles and warped rotors. Did you end up replacing or resurfacing the existing rotors.
  9. Mar 24, 2023 at 2:21 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    My buddy just had his resurfaced at 800 miles on a 2023. The dealer told him it was from sitting in the shipping yard? Idk my buddies complaint was a shudder everytime he applied the brakes. They turned them (which I didn’t even realize was a thing anymore) and he said good as new.
  10. Mar 24, 2023 at 3:12 PM
    JDSTOY
    JDSTOY New Member
    2024 GMC 2500HD, 2022 Limited 6.5, 2000 Limited
    My first tundra (2000 model) ate rotors like candy. 3 rotors in 60000 miles. The problem was the caliper design on that model. My 22 tundra started shaking around 15000 miles. I had the rotors resurfaced and new pads put on at 20000 miles. So far they are acting normal but time will tell. Our highlanders have been bad on rotors as well. About 30-35000 miles each set. My Camry went 160000 on the original pads and rotors. Go figure.
  11. Mar 24, 2023 at 4:30 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    I do my best to time most of lights I come too. Makes life easier. That may not be answer but it sure makes life a little easier.
  12. Mar 25, 2023 at 3:20 AM
    CMikeB
    CMikeB New Member
    "S" mode is also your friend. No need to jump on the brakes every time you need to slow down a few miles per hour. Choose the gear YOU know is right for speed, road conditions and load.:thumbsup: My Mechanic tells me my original brakes will last for at least 100,000 miles, I have 88,000 on my 2010 now.
  13. Mar 25, 2023 at 4:38 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    Exactly. But I highly doubt the rotors in this care are really warped. The thing to note about this is that the deposits don't really create a warp or any high spots but rather change the friction in those spots where the pads were held in place after a hard hot stop and transferred material onto the rotors. The pulsing comes from the pad encountering zones of differing friction. Rebedding the pads might work. If not you can try sanding the rotors down, or get them lightly resurfaced.
    SC4333 likes this.
  14. Mar 25, 2023 at 5:41 AM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    Hey y’all,
    Something is wrong with this brake set up. I’ve had dozens of trucks and SUVs (brand new and classics) and my brakes are pulsing again. No… Not pulsing, it’s worse than pulsing. It’s an offensive shudder, approaching a violent shaking.
    I had them turned at 18k miles. Dealer noted runout of .003” and .002” on back and front rotors respectively. They were fine for another 4K miles, and now at 22k I have the same issue I had before.
    I know what some of you may say, but it is not driver error. I am a driving enthusiast and enjoy the art of good driving. I too time the lights, just for fun. I use the s transmission setting and select my own gears so I have more control of speed with my right foot. I am not abusing these brakes.
    Something is just wrong with them.
    I’ve read that the pedal applies rear brakes only for the initial 20% of the pedal, to stabilize the rears, then the front kicks in. It eliminates nose dive, and keeps the truck flat under normal braking. Maybe that’s what it is. Maybe it’s the caliper design. Maybe it’s the rotor material. Idk, but something is really wrong with these brakes.
    I hate it because I really really like everything else about this truck. I like it so much that I would just put better rotors and pads on it and move on. But I have not been able to find aftermarket pads and rotors.
    I will update after I go to the dealer next week, but I am really disappointed in these brakes.
    Lotta likes this.
  15. Mar 25, 2023 at 5:51 AM
    TopTierToyo
    TopTierToyo New Member
    2022 Blueprint Tundra 4x4 Limited
    I don't know if this is a Tundra thing or a modern rotor in New England environment thing, but if I leave my Tundra sitting for even a fews days then the rotors rust up really badly. It gets to the point where it will take a several hundred miles of active driving to scrape the rust off if I let it sit for a week.
  16. Jul 20, 2024 at 5:37 AM
    Del&FeFe2024
    Del&FeFe2024 New Member
    Del&FeFe
    2023 Toyota Tundra Limited Fuck It Edition.
    Stock at the moment, well I mean, added the Integrated DashCam, Carmate DX4000RA 360° DashCam. Window tint, Bed Mat, additional lighting, TRD Pro Grill
    My rotor Left Front @ 2200 miles:
    Towed to Dealership awaiting findings
  17. Jul 20, 2024 at 6:48 AM
    Yotaholic4life
    Yotaholic4life New Member
    24 TRD Limited CM LB, 23 SR5 8ft bed DC
    24 TRD Lift
    I just had the rear rotors and pads replaced on the 23 @23k kms . Granted it towed a trailer a lot but still early imo. Toyota warranty covered the rotors but I had to buy the pads .
