  1. Jul 19, 2024 at 2:56 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    What battery to put in my '21
    Original Toyota battery is at half strength now
    What is the biggest strongest it will fit and what are the pros/cons of such a battery?
    Thanks.
  2. Jul 19, 2024 at 4:09 PM
    Xcumminsguy
    Xcumminsguy New Member
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Took it fishing.
  3. Jul 19, 2024 at 4:10 PM
    SAGE63
    San Diego County
    Did she catch anything
    koditten likes this.
  4. Jul 19, 2024 at 4:10 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Took the trailer in for its first service:
  5. Jul 19, 2024 at 4:26 PM
    Xcumminsguy
  6. Jul 19, 2024 at 4:53 PM
    koditten
    Kirk
    Midland of the Mitten
    He said he took it fishing. Nothing was said about "catching".
  7. Jul 19, 2024 at 5:04 PM
    Xcumminsguy
    I’ll wet a line for a few minutes as I’m already here, but relaxing with the Mrs. A sandwich, and a few beers. If I bring something home for the freezer then good for me. Just need down time.
  8. Jul 19, 2024 at 5:11 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Look into either a X2 Power AGM, Odyssey or if you prefer to stay with water filled batteries, look at the Interstate varients...AGMs will need a diode in the ALT-S fuse under the hood to trick the ECM into charging it at its preferred rating of 14.6-8volts...the diode is on Amazon, O'rielys, ebay...most places for like $8...more CCA, better amp hour ratings and better in both extreme temperatures of hot/cold...best battery I've ever owned is my X2Power...I have them in ALL of my different vehicles because they work and are very reliable if you charge them at their preferred voltage...
  9. Jul 19, 2024 at 6:07 PM
    That doesn't look like a LI beach.
  10. Jul 19, 2024 at 6:58 PM
    Xcumminsguy
    Democrat Point, Suffolk County. Finishing the evening off with a nice Woodford Reserve, poolside.
  11. Jul 19, 2024 at 6:59 PM
    French Avocado
    Utah / Wyo
    Timely - my original just gave up the ghost. Which X2 battery do you recommend? how many CCA? Can you help the stupid guy with a link to the specific diode replacement?
  12. Jul 19, 2024 at 7:17 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    I got mine replaced under the b2b warranty. Have you given that a try?
  13. Jul 19, 2024 at 7:30 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    I think that ended at 20,000 or two years
    Battery still works, I just want a strong upgrade
    Henry1jg[QUOTED] likes this.
  14. Jul 19, 2024 at 8:07 PM
    HulkSmurf14
    2014 Tundra Limited
    Hell yeah brutha! https://www.tundras.com/threads/charging-diode-for-agm-batteries.111426/
    https://www.tundrastall.134029/
    https://www.tundras.com/threads/agm-battery-charging.97564/
    Best link is the last...Ford/GM...same coin, different side :anonymous:
    930CCA: https://www.batteriesplus.com/productdetails/sli27fagmdp
    bulldog93 and reywcms like this.
  15. Jul 19, 2024 at 9:18 PM
    TundraJedi
    TundraJedi New Member
    Eric
    2021 Tundra Pro
    IMG_0008.jpg IMG_0009.jpg IMG_0007.jpg Installed Borne 1” spacers. Running BF Goodrich tires 275/65/18, and Tundra is looking a bit meaner today.
  16. Jul 19, 2024 at 9:56 PM
    French Avocado
    Utah / Wyo
    $340 for the AGM with discounts (plus diode etc / 930 CCA) - 4 year warranty - assuming 4 years then $85/year
    $115 for Interstate/Costco - 3 year warranty [710 CCA] - assuming 3 years then $39/year
    Isn't that at worst less than half price? Disregarding warranties it is 1/3 cost. Not to be cheap (well maybe) but is there that great of an advantage to AGM batteries (220 CCA) to pay three times the price? As I read the reviews on here they are mixed.
    Edited to add CCA numbers
  17. Jul 20, 2024 at 2:17 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Might be colder where you are, but in Mass, my OEM battery has started no problem at and below 0 degrees. 3 years and fingers crossed. It's fun to upgrade things, but I am with you, without a lot of extra electronics to power, I don't see the point.
  18. Jul 20, 2024 at 3:10 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Pulled into the driveway this morning and missed it by a mile... (not the driveway) :thumbsup:
  19. Jul 20, 2024 at 4:44 AM
    centex
    centex New Member
    The internet is good for wasting money on stuff you don’t need. I just grab the cheap batts and they usually last me about 5yrs in the Texas heat and then I get a new one. Been working for the last 25yrs.
  20. Jul 20, 2024 at 5:21 AM
    koditten
    Kirk
    Same.
    Whatever is on sale. It's a battery. Walmart and AutoZone are everywhere. It goes bad, I change it.
    I'm not wasting my time installing an AGM. The reliability isn't great enough for me to offset the extra money they cost.
  21. Jul 20, 2024 at 7:39 AM
    HulkSmurf14
    2014 Tundra Limited
    For sure, same can be said with suspension, air filters, tires , etc...I enjoy the faster starts in winter and the higher amphour ratings when the truck isn't running but power is needed for music, et al... go with whatever works for you and enjoy the many options that are available...freedom is awesome!
  22. Jul 20, 2024 at 12:03 PM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    Think I trashed the airbag clock spring removing the steering wheel. It came flying off and unwound itself, and it looks like part of it is torn. How screwed am I?
    Can you rewind it? It looks worse than a cassette tape that got eaten by a tape deck.
    koditten and ATV25 like this.
  23. Jul 20, 2024 at 12:36 PM
    centex
    centex New Member
    Buy a new one. I’ve never had success rewinding them and if the ribbon cable looks torn then it’s broken.
    bulldog93 and HulkSmurf14 like this.
  24. Jul 20, 2024 at 12:54 PM
    FireFinder44
    Albany, OR
    Yeah it's $640. If I want to drive 1hr+ each way or wait until Tuesday with the truck in the middle of the driveway. Then it's about a $100 cheaper.
    Guessing that my lightbar, reverse lights and stereo will have to wait.
    You always remember the mistakes you make that cost you money.
  25. Jul 20, 2024 at 1:05 PM
    RobertD
    Robert
    DFW, Texas
    Were you using a steering wheel puller?
    I know most say its not needed but I got the one from Harbor Freight for like $14. I haven't used it yet since I still haven't had the time to wrap the wheel. But I thought it was worth the piece of mind.
    Sorry yours broke. That definitely sucks. But everyone will mess up something at some point and have to pony up. At least you are safe
    Tripleconpanna and bulldog93 like this.
  26. Jul 20, 2024 at 1:35 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Costco also has Interstate AGM 24F with 710 CCA for about $200 shipped to your door. Saves a little room and weight is a wash with the factory battery.
  27. Jul 20, 2024 at 1:51 PM
    FireFinder44
    Albany, OR
    Update on the steering wheel replacement.
    Going to test drive shortly but I believe that I got the spring rewound and it's not broken.
  28. Jul 20, 2024 at 2:01 PM
    FireFinder44
    Albany, OR
    Boy was I seriously optimistic. Made it to the end of the driveway, started turning the wheel and everything went bonkers on the dash. Looks like I am off to get a new clock spring.
  29. Jul 20, 2024 at 2:02 PM
    RobertD
    Robert
    DFW, Texas
    Oof, sorry
  30. Jul 20, 2024 at 2:03 PM
    HulkSmurf14
    2014 Tundra Limited
    To those owning a gen 2 NSV bulge lightbar that was re-wired to defeat the strobe: the greatest discovery was made...I was swapping out my bulge for one that did have broken tabs...I added some more strength with JB Weld on the tabs that are known to break when anything breaks on the bulge...I figured I might as well try the pin #8 to empty pin #3 I've been wanting to do for years...definitely a tricky depinning but, the video (https://www.tundras.com/threads/nsv-light-bar-question.59292/#post-1704354) works for this; I now have the strobe feature in-lieu of the boring "DRL" look ...I feel like drinking now!! Cheers!!
