  1. Jul 15, 2024 at 5:30 AM
    #6811
    Yotaholic4life
    Yotaholic4life New Member
    24 TRD Limited CM LB, 23 SR5 8ft bed DC
    24 TRD Lift
    Yes, pretty simple to remove ! With them gone you can hear those little snails more and I would think it allows a lot more air in vs sharing the air boxes with a couple of sleeping bags lol
  2. Jul 15, 2024 at 5:39 AM
    #6812
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    I read through some user experiences here, and then watched many videos on youtube, including other brands. It has every feature I wanted which was the ability to capture video when the truck is parked. Video quality is very good. Install was a breeze using the OBD port, and running the wire to the rear was easy. I would highly recommend the mounting bracket I purchased for rear installation. Its not a cheap setup compared to most others, came in at $480 plus $20 for the rear mount.
  3. Jul 15, 2024 at 6:15 AM
    #6813
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I don’t think so since they stay at the bottom of the air box. They don’t restrict airflow. The turbo noise is nice though, lol.
  4. Jul 15, 2024 at 11:59 AM
    #6814
    Lambeau
    Lambeau New Member
    2024 Black Tundra 1794 Limited Edition
    285/60/R20 BF Goodrich KO2’s
    It looks like many manufacturers are considering a transition to 10k mile tires on new vehicles. Kinda like printer ink...gets you started but you need to buy better tires real soon. Sucks!
  5. Jul 15, 2024 at 12:24 PM
    #6815
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    I think the stock Falkens are adequate tires, at least for my current usage, but the spare provided is a disgrace. You are right in that cost cutting is getting to the point of being ridiculous now.
    Gonefishingdave likes this.
  6. Jul 16, 2024 at 6:58 AM
    #6816
    24LTD
    24LTD New Member
    Planning to get 275/60/20 on my limited. Any rubbing? Thanks!
  7. Jul 16, 2024 at 7:24 AM
    #6817
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    None...Youd have no problems running these stock
    24LTD[QUOTED] likes this.
  8. Jul 16, 2024 at 7:32 AM
    #6818
    VCheng
    VCheng New Member
    Upstate NY
    When the time comes, I would consider 275/65/20s if they fit on the stock suspension. What say you?
    TN Tundra2 likes this.
  9. Jul 16, 2024 at 7:39 AM
    #6819
    eddiefromcali
    Eddie
    100% Stock
    theyll fit. 65s were way more money than 60s in my case....stuck with 60s because of that, not due to potential fitment issue
    VCheng[QUOTED] likes this.
  10. Jul 16, 2024 at 7:43 AM
    #6820
    ChiefG
    ChiefG Limited 4X4 TRD OR
    Burlington Township, NJ
    2022 Tundra Limited Off Road 4X4
    Just minor stuff. For example, Undercover bed cover, Tufskinz custom door sill protectors, and TRD air filters.
    Absolutely love it! What bumper is that. The setup IMO is awesome.
  11. Jul 16, 2024 at 1:29 PM
    #6821
    Yotaholic4life
    24 TRD Lift
    Interesting couple of days ! With the sound bags removed and trd filters installed I haven’t experienced a dead pedal . I got it the first 10 mins of driving the new truck . Stopped at stop sign kinda sudden , hit the gas and blah. I pulled the crap and installed filters and put 500kms on in 2 days . No dead pedal ! Hmm , so if Toyota designed an airbox that size to work with the turbos , intake / map sensor / maf etc etc . Then , you get a tight arse in quality control that doesn’t like the sound of turbos spinning and ends up implementing a fix that cuts off half the airbox volume ?? Wtf ? It’s new so I’ll update as it goes but if you’re wondering if it makes a difference . Pull that crap and install filters that can breathe and let me know . Really curious about the comments, if you try it !
  12. Jul 16, 2024 at 1:39 PM
    #6822
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    What mode did you drive it in? I drive mine in normal. I floored it for the first time and it took it a second or two to finally get going.
  13. Jul 16, 2024 at 1:46 PM
    #6823
    produxnguy
    produxnguy New Member
    vernon
    Not turbo or Tundra related but a very similar experience. Back in 2016 I bought a new Tacoma Sport V6. Several times while attempting to dart across an intersection with oncoming traffic, I was immediately greeted with a deadly 'blah' sound and no acceleration. I immediately bought a K&N cold air intake. That eliminated the stall. I subsequently added a throaty better breathing Gibson exhaust. These did not add hp. They did cure the terrible stall/throttle lag at full throttle. That truck was unsafe in my opinion. Must be a flaw in the engineering.
    Yotaholic4life likes this.
  14. Jul 16, 2024 at 1:47 PM
    #6824
    Yotaholic4life
    24 TRD Lift
    I tend to drive in normal mode on highways . Sport around town , lots of hills here and a noticeable difference in tip in throttle now . The 23 has 23k kms now and I have experienced dead pedal since day one . Not all the time by any means but let me tell ya ,, when you need to get out in traffic and nothing happens , it’s a white knuckle event for too long . So , I’m pulling the sound bags in that one tomorrow . I’ll leave the stock air filters for comparison. I’ll get back with results .
  15. Jul 16, 2024 at 1:49 PM
    #6825
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I’ll be curious too.
  16. Jul 16, 2024 at 2:08 PM
    #6826
    Yotaholic4life
    24 TRD Lift
    Engines have to breath brotha ,, motors don’t :)
  17. Jul 16, 2024 at 2:13 PM
    #6827
    produxnguy
    vernon
    I too have been wrenching since the early 70's. Not a big CAI fan for general use. Had them on sports cars but this was a 1st for a truck. A year or so later tunes became available for that slug powertrain which I understand fixed that issue. I know I was ready to trade that truck in if I couldn't resolve that throttle lag. Fortunately they didn't force those 3.5 engines in the Tundra. If they did most would now be in an F150 forum.
  18. Jul 16, 2024 at 4:38 PM
    #6828
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Installed the 2.5” Ironman 4x4 Foam Cell Pro a couple weeks ago, absolutely loving it! Not a bad install either, definitely worth doing it and saving a bunch of money
    Ironman 4x4 Foam Cell Pro Lift Kit Install on a 3rd Gen Tundra. 2022 Toyota Tundra TRD Pro.
    https://youtu.be/GlwQHf3Wte0
    j-utah, RatPanda, Yaboy and 4 others like this.
  19. Jul 17, 2024 at 1:05 PM
    #6829
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    Saw that video, trucks looks great! Nice work! Crazy you had to cut the rear shock to get it out. But you might be able to send it back to Fox for a rebuild and they should be able to replace that. Will cost some money but not nearly as much as what those shocks cost new
    2020Platinum[QUOTED] likes this.
  20. Jul 18, 2024 at 9:42 AM
    #6830
    Lucky0402
    Lucky0402 New Member
    Dane
    3/2 Lift Gear Double Pump rims 295/70r18 Nitto Terra Grappler G2s
    With buying a TRD Pro, why spend the extra money on the Pro and then change the suspension? Is it better buy the Pro and then upgrade the suspension, as a opposed to buying a TRD Off-road (for the rear locker) and then upgrading the suspension? Or...would it be best to buy a 4x4 Tundra without TRD package, and then upgrade the suspension and an after market rear locker?
    This question is for anyone. I am genuinely asking and want to learn.
    Csteppe likes this.
  21. Jul 18, 2024 at 1:48 PM
    #6831
    eddiefromcali
    Eddie
    100% Stock
    Better off buying a Platinum TRD Offroad.
  22. Jul 18, 2024 at 7:23 PM
    #6832
    NashvilleBulldawg
    NashvilleBulldawg New Member
    Today I put the Predators on. I found it oddly very easy on my own despite many saying it’s a 2-man job. I’m not very mechanically inclined either. I’m done bragging…
    j-utah likes this.
  23. Jul 18, 2024 at 7:34 PM
    #6833
    2020Platinum
    Patrick
    Northeast PA
    Thanks man, I appreciate it! I was so frustrated with them rears it wasn’t even funny. I mean, looking back, it’s a little funny, but at the time I wanted to light them on fire. Lmao.
    hey Dane! So if you know you’re going to lift it, you are better off not getting the Pro. Unless of course you just want the other “Pro” styling. Which honestly, in my opinion, isn’t worth it just for some extra badging and small stuff like that. But to each their own. When I first got the Pro, I wasn’t sure I was going to lift it. Was on the fence until just recently. I also got the Pro because it’s my 4th Tundra, and one of the only trims I haven’t owned yet. I had a 2020 Platinum, great truck, but didn’t want another of the same trim. At the end of the day if you’re not interested in the styling of the Pro and you know you’re gonna swap the suspension right from the start, it would make no sense to get a Pro. Hope that helps!
    SM Tundra[QUOTED] and Bnewman077 like this.
  24. Jul 19, 2024 at 5:07 AM
    #6834
    Lucky0402
    Dane
    check out Nitto Recon Grapplers 295/70R18 in the 116S size. They weigh only 52.49 lbs. I have the previous version of this tire in this size. They are amazing. My MPG in the city is not affected in the slightest. On the Highway, I lost 1 mpg from stock. My truck has a 3" lift front, and 2" lift rear. My MPG dropped a total of 1 MPG on the highway, only. I realize I have a 2nd gen, but the MPG hit would be similar.
    • Stock Number: 218880
    • Tread Depth (1/32 in): 13.7
    • Inflated Dimensions - Overall Dia (in): 34.29
    • Inflated Dimensions - Overall Width (in): 11.77
    • Approved Rim Width Range (in): 7.5-(8.5)-10.0
      Min -(Measuring)- Max
    • Maximum Load (lbs.) @ Press. (PSI): 2756 @ 44
    • Weight: 52.49
  25. Jul 19, 2024 at 5:29 AM
    #6835
    Lucky0402
    Dane
    Extremely helpful response!
    I have heard all sorts of answers, but since you are a Pro owner, I hoped you'd reply. That all makes sense. I saw your video on YouTube and then when you posted your truck in the forum I recognized it immediately. Great looking truck!
  26. Jul 19, 2024 at 8:05 AM
    #6836
    eddiefromcali
    Eddie
    100% Stock
    Dropped off at dealer to get the seat frame replaced...this thing has been clunking like crazy for a while now
  27. Jul 19, 2024 at 8:09 AM
    #6837
    Lucky0402
    Dane
    The lifted look you have is exactly what I am wanting to do. What 2" coil overs did you use? did you need to do anything besides swapping out the stock coil overs? Is a diff drop needed for the 2"...or UCAs?
    What tire size are you running?
  28. Jul 19, 2024 at 8:22 AM
    #6838
    Lucky0402
    Dane
    Did you have to buy the red axles from a dealership for the Westcott TRD lift to work?
    Sisu87TRDOR likes this.
  29. Jul 19, 2024 at 10:16 AM
    #6839
    Sisu87TRDOR
    Sisu87TRDOR New Member
    Kirk
    2024 Ice cap Tundra TRD OR SR5
    Finally brought the truck in to get the front windows tinted 20%.
  30. Jul 19, 2024 at 5:43 PM
    #6840
    JMitch
    JMitch New Member
    James
    2023 Tundra Limited 4x4 Hybrid
    Added a 2” Front and rear lift to my 2023 Limited Hybrid Crew with rear load leveling. Now on 34” Nitto Recon Grapplers. Used the Readylift SST 2” lift for the rear, but replaced the shock rather than using shock extensions with an N3 from Rough Country. Added the N3 strut from Rough Country up front. Everything is an even 2” higher and has about 1” of rake. Rides same as factory as far as I can tell. I think it’s a nice proportion for these trucks.
    tonyusmc, Rockgate, CV60 and 3 others like this.
