  1. Jul 14, 2024 at 12:05 PM
    It's similar with my 5AT also.
  2. Jul 14, 2024 at 12:06 PM
    Most transmission are that way. The cold fluid makes the shifts rough. Most are programmed to delay cold shifts into fluid warms up. Even my 2019 does that.
  3. Jul 14, 2024 at 12:06 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    the a340 has all gears speed regulated regardless of lockup.
    squirt to the shift, then coast. OD off 3rd locks in 45-50. Depending on load. Get up to 50-55, turn on OD and let it lockup @50ish and coast. Helps to preemptively turn off OD to climb a hill slower because of traffic, as long as youre smooth, you're not burning extra fuel between 2-3krpm.
  4. Jul 14, 2024 at 12:54 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    My 4Runner had Pirelli Scorpions on it when I bought it. I hated those things, not real good in the rain, worse in the snow, and like you I replaced them with a set of Cooper's. You're going to like them. Never understood why the Scorpions were so bad with that tread pattern.
  5. Jul 14, 2024 at 1:30 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Interested to see if those rough country coils work with the Bilsteins.
    VR6T[QUOTED] likes this.
  6. Jul 14, 2024 at 3:04 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Yes but no
  7. Jul 14, 2024 at 3:22 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Not sure if you were just raising the circlip or not, but next time I recommend the “no spring compressor” method. Probably takes a bit longer, but way safer.
    Jack McCarthy and FrenchToasty like this.
  8. Jul 14, 2024 at 3:26 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I had concerns.
    Maybe @FishNinja or @Mr.bee has their stock coils still
  9. Jul 14, 2024 at 3:50 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    trashed mine
  10. Jul 14, 2024 at 4:10 PM
    Wasted opportunity.
  11. Jul 14, 2024 at 4:15 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    @VR6T I think my old coils are marked to be oem TRD's. pink yellow/yellow yellow. You are welcome to them for the cost of shipping.
    I know this doesn't help today, buuuuut.
    VR6T, bmf4069 and 455h0le_dachshund like this.
  12. Jul 14, 2024 at 4:50 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Don't remember where I clipped this from, but I went through this identifying thing when I replaced mine.
    Obviously didn't help me..... (Red-Blue) JY supposedly said it was 2000TRD 4x4
    455h0le_dachshund likes this.
  13. Jul 14, 2024 at 4:58 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Me too.
  14. Jul 14, 2024 at 5:13 PM
    daveeasa
    26k would be more than MSRP on my truck.
  15. Jul 14, 2024 at 5:33 PM
    My truck today is better than your truck when new. Even your truck now is better than your truck when new. We’re fucking awesome! :rofl:
    Tundra2, bmf4069 and FrenchToasty like this.
  16. Jul 14, 2024 at 5:35 PM
    daveeasa
    Chrome bumper is not an upgrade:)
  17. Jul 14, 2024 at 5:42 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  18. Jul 14, 2024 at 5:52 PM
    VR6T
    Well that only took all day ..... Luis came over thank God, and helped me figure it out. Pro tip of you have rough county springs and are going to put Bilstein 5100s on, just throw the springs out with the old shock body's and get factory springs
  19. Jul 14, 2024 at 6:02 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's what my gut was saying
    VR6T[QUOTED] and BroHon like this.
  20. Jul 14, 2024 at 6:02 PM
    It'll be replaced soon enough.
  21. Jul 14, 2024 at 6:13 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    looks like you're getting some green on the negative terminal post. Give it a scrub before you turn on the heat this fall. (house heat aka Thanksgiving day for you southern folk.)
  22. Jul 14, 2024 at 6:40 PM
    :eek2::eek2::eek2:
    you put the spacer back on top????!?!!!!?!
  23. Jul 14, 2024 at 6:41 PM
    VR6T
    Yeah I never planned to delete them
  24. Jul 14, 2024 at 6:41 PM
    My truck stickered for $32k new in 2000 dollars.
  25. Jul 14, 2024 at 6:42 PM
    Nooooooooooooooooooooooooooooooooo
  26. Jul 14, 2024 at 6:42 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Mine idles at right about 1K RPM, I drop it into reverse/drive, it drops to about 750, put it back in park, she goes back to 1K.
    BroHon likes this.
  27. Jul 14, 2024 at 6:45 PM
    Mine definitely drops idle under load, then returns after return to P.
  28. Jul 14, 2024 at 7:18 PM
    daveeasa
    Pretty big bump back then, wasn't it? Limited at 125% of SR5.
    Or, perhaps more to the point, the RC SR5 was a pretty dang good value, tons of truck for a reasonable price.
  29. Jul 14, 2024 at 7:45 PM
    Mine was the loaded version. Limited AC 4x4 V8 leather etc. didn’t even come with keyless entry though :rofl:
  30. Jul 14, 2024 at 7:48 PM
    daveeasa
    Many of us would jump for a v8, leather, limited 4x4 of any model at 32k today. Maybe even cartwheels.
