Chalk bag 32oz cupholder mod
Discussion in '2.5 Gen Tundras (2014-2021)' started by EatSleepTacos, Feb 11, 2022.
  1. Dec 3, 2023 at 12:57 PM
    #151
    biebs96
    PA
    ATV25 likes this.
  2. Dec 3, 2023 at 6:27 PM
    #152
    I'll post a picture tomorrow.
    biebs96[QUOTED] and WFD473 like this.
  3. Dec 4, 2023 at 3:06 AM
    #153
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Moose jaw.com has the chalk bags. That’s where I got mine.
    Bammer[QUOTED] likes this.
  4. Dec 4, 2023 at 3:22 AM
    #154
    Bammer
    Monroe, CT
    :hattip:
    RusPro21[QUOTED] likes this.
  5. Dec 4, 2023 at 3:49 AM
    #155
    RusPro21
    Don
    Pa.
  6. Dec 4, 2023 at 5:20 AM
    #156
    Pulled up the window switch and mounted it just like the front way.
  7. Dec 4, 2023 at 7:21 AM
    #157
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    As an aside, the lady that owns static climbing is a sweetheart and while you might find a cheaper alternative she hand makes these things in the USA. It’s worth supporting her.
    BR73, ATV25, BOSSARU and 15 others like this.
  8. Dec 19, 2023 at 2:26 PM
    #158
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Did this mod today - very happy with the results! Now those little cup holders are freed up for coffee and the chalk bags are for water.
    Anyway, did things a little differently. Cut the loops to form a single strap as suggested by the OP.
    Driver's Side
    - Started by punching holes with a hot nail, similar to the OP. Rolled up with zip ties.
    - However this seemed somewhat weak so I did it again except with a piece of aluminum stock I had laying around
    - The rod now lays under the plastic lip inside the console, seemingly should be very strong
    Passenger Side
    - Did not want to obscure the little 'cubby' since I keep some stuff in there
    - Wanted the bag right next to the seat, as on the driver's side
    - Turns out there's potentially interference with some of the plastic posts of the console cover
    - Decided to "roll up" the left strap. The aluminum bar was too thick, used a piece of a nail
    - Undid the screws holding the inner sections of the console to gain some play and jammed it between. Put screws back in.
    - On the right strap there's no room to jam the roll anywhere.
    - Cut the strap to the size of the inner plastic shoulder and used a hot nail to create a pilot hole, then put in a sheet metal screw
    - This is even stronger than the driver's side
    - Note: I cut a little relief into the strap using a hot nail assuming one of the console posts would hit it. This cut was not needed. (No interference when assembled)
  9. Mar 8, 2024 at 2:19 PM
    #159
    centex
    centex New Member
    Did it for the wife. Gonna inspect her Durango and see if I can do one in there also.
  10. Mar 11, 2024 at 9:37 AM
    #160
    AZBoatHauler
    So.Arizona
    The typical response I’ve got is “you don’t go for yours and I won’t go for mine”
  11. Mar 24, 2024 at 6:06 PM
    #161
    SR5style
    SR5style New Member
    2019 MGM SR5 4wd Crewmax
    I couldn't find a drill or a hole puncher, so I used a utility knife and it worked fine for making the hole big enough for a zip tie to fit through.
    Fits the big Nalgene bottle great, and also works great for the 28 oz Blender Bottle.
  12. Mar 25, 2024 at 12:40 PM
    #162
    centex
    centex New Member
    Works the same in the Durango. I didn’t do an aluminum bar this time like I did on mine but it seems pretty secure.
  13. Apr 7, 2024 at 3:46 PM
    #163
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    Finally got around to doing mine! Finally have a spot for my Nalgene that works. Might do one on the driver's side too so the wife can put her obnoxious Stanley cup in the passenger side one.20240407_181540.jpg
  14. Apr 9, 2024 at 1:23 PM
    #164
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    Can anyone confirm if that tacticool option can roll up into that slot on the passenger side like the chalk bag can?
  15. Apr 10, 2024 at 3:35 AM
    #165
    Bammer
    Monroe, CT
    Took this pic last night, the bag has been in for several months. Looks like I need to get the console seated back in.:rolleyes:
    bulldog93 likes this.
  16. Jul 13, 2024 at 2:43 PM
    #166
    biebs96
    PA
    Did the bag mod to my wife’s Highlander.
    Not so sure it will be for a water bottle, as much as it will become a trash can (which is fine, because this bag has a one piece liner)
    Either way, it fits nicely and is easily accessible from the driver’s seat.
  17. Jul 13, 2024 at 4:53 PM
    #167
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    biebs96 likes this.
  18. Jul 14, 2024 at 6:19 AM
    #168
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
  19. Jul 14, 2024 at 8:16 AM
    #169
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Thanks 1up. That holder will be great for our family truckster
    1UP likes this.
