General Supercharger Thread
  1. Jul 12, 2024 at 7:37 PM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    I think are supercharger is better then that whipple they put on fords for 3k.
    How much boost are those fords even making on stock pulley stock injectors? I highly doubt it’s doing 8psi at 6k rpm WOT.
  2. Jul 12, 2024 at 8:53 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Going from 43psi to 53psi will do that...
  3. Jul 13, 2024 at 12:10 PM
    blenton
    blenton New Member
    There was some discussion a month or so back about larger crank pulleys. I can't seem to find the stock crank pulley size. I seem to recall it being around 7". Anybody know?
  4. Jul 13, 2024 at 1:31 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Someone correct me if I’m wrong, but I wanna say it’s 6.125” IIRC.
    Mdl and blenton[QUOTED] like this.
  5. Jul 13, 2024 at 1:34 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Stock is around 6.2, ASP crank is 6.71 and XAT and Prospeed are 7.
    Fastlane47, reywcms, Silver17 and 2 others like this.
  6. Jul 13, 2024 at 1:35 PM
    blenton
    blenton New Member
    Thanks guys.
    Silver17[QUOTED] likes this.
  7. Jul 13, 2024 at 1:38 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Probably . I couldn't find my caliper so I guesstimated it...
    Silver17[QUOTED] and Wynnded like this.
  8. Jul 13, 2024 at 2:55 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Here is what $34 of catch can on Amazon gets you.
    This is what I have on my supercharged LS, and this one is going on my 2JZ as it gets boosted. On the LS it collects quite a bit of shit, though that's also on a fully built engine so not really apples to apples comparing to the Radium. For $34 there's a lot of stuff I like, all machined aluminum, has engravings for "in" and "out" which is really nice. Has a bunch of random fittings included. Has a dip stick. Includes some fuel line albeit not a lot. Includes a funky little bracket (not shown in photos). It's pretty basic, it includes 2-3x the amount of steel wool as needed, and you pack it into this little container thing and thread it in.
    So what does an additional $265 gain you for the radium? It gets a custom made sheet metal bracket for the Tundra (that personally I don't like). I think the Radium is quite a bit bigger. Oh and you get the weird check valve ball thing people show that seems useless :D
    Food for thought.
  9. Jul 14, 2024 at 10:32 AM
    Grenades4Bacon
    Grenades4Bacon New Member
    2019 Tundra
    I have a radium one - pretty useless... not a drop in it after the last oil change. However, the mesh filter looks a bit more dense and, puck-like.
    Ctaylor76 likes this.
  10. Jul 14, 2024 at 10:44 AM
    Ctaylor76
    Chaz
    Houston
    yeah I bought it because I didn’t want any oil getting back into the blower. So even if I don’t empty it past 10k miles I’ll still be happy.
  11. Jul 14, 2024 at 12:21 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    How much smeg are y'all collecting in your functional catch cans? About 4-5 oz over 2 oil changes, 6K miles. Very oily too.
    Mdl likes this.
  12. Jul 14, 2024 at 12:41 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Backpressure. How well your exhaust flows and one method to check to see if your catalytic converter is a major impediment to flow, or plugged. It just showed up in my recommended to watch list. Discuss away!
  13. Jul 14, 2024 at 12:50 PM
    Saltyhero13
    Love Julian Edgar's channel.
    Wynnded[QUOTED] likes this.
  14. Jul 14, 2024 at 1:02 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Essentially none
  15. Jul 14, 2024 at 1:04 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    Little to none in mine.
    Ctaylor76, Mdl and Saltyhero13 like this.
  16. Jul 14, 2024 at 1:54 PM
    Silver17
    Eastern PA
    Towing update for me for anyone who cares: Just got back from a 500ish mile trip towing the camper around, 95 degrees out both travel days. Plus an extra 200+ miles without the trailer on mountainous roads. This tow included some pretty wicked low speed hills with switchbacks in the mountains of Virginia near Shenandoah national park. The truck performed flawlessly, and I was pretty pleased as usual. Towing in S4 on the highway with the trans thermostat pinned I’d often see trans temps in the 180s, coolant temps in the 190s. Towing in S5 I was seeing more like 200-210 on both the trans and on the coolant. 65mph in S5 sits at 2200rpm, and in S4 at 65mph sits at 2800. I noticed about 1 mpg better in S5 despite it pushing 5psi on the hills in cruise control and being essentially under more load. I thought that was odd. 9.5mpg out and 8.5mpg back. It runs great either way, but putting it in cruise in S4 is pretty leisurely. It almost never unlocks the TC on hills unless it’s a whopper. Lots of torque on tap for sure. 34.5” tires on stock gears.
    Despite higher fuel costs for premium I spent almost $20 less on the trip out than my brothers 3/4 ton Chevy with the 6.0 gasser granted his trailer is a little heavier. Didn’t check on fuel expenses for return travel.
    Terndrerrr, ARES35, ZPhilip and 7 others like this.
  17. Jul 14, 2024 at 2:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I checked mine after 2k. I had about an .5 oz of mostly thin oil crud. I have the Amazon $21 special, it has the micro filter mesh on the inlet that can be cleaned. It's a small canister but hangs nicely off the side of the SC.
  18. Jul 14, 2024 at 2:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'd have to believe that with 3 inch exhaust piping and one 200cell cat on each side it would be flowing quite well.
  19. Jul 14, 2024 at 3:00 PM
    blenton
    blenton New Member
    About this much shmoeg every 1-2k miles. Usually see a 200 mile trip with a heavy trailer and hills at 70 mph in those miles.
  20. Jul 14, 2024 at 3:09 PM
    Saltyhero13
    I've seen some exhausts tested on a flow bench but I rarely see exhausts rated in this manner. You would also need to estimate what your needed exhaust output would be using online calculators.
    The quickest way to assess what is left on the table with any exhaust is to remove everything behind the headers and replace with an straight pipe extender (presumably to retain scavenging). This doesn't account for any size/length tuning for specific RPM bands and seems only focused on the big end of the RPM.
  21. Jul 14, 2024 at 3:13 PM
    Saltyhero13
    Thanks for the added details. I'm mixed driving (City/Hwy) on hilly terrain. A couple of hard pulls over the life of the oil.
    blenton[QUOTED] likes this.
  22. Jul 14, 2024 at 3:24 PM
    Saltyhero13
    Fastlane47 and Wynnded like this.
  23. Jul 14, 2024 at 3:53 PM
    Ctaylor76
    Chaz
    Houston
    5.29s nitro gears that’s with trac off. I also wasn’t all the way in it, I am pretty sure that truck will bald 35s.
    ssmokedz[QUOTED] likes this.
  24. Jul 14, 2024 at 5:27 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Agreed, and I think that this method applies more to testing a system that's already in place, such as a factory system.
  25. Jul 14, 2024 at 5:34 PM
    Saltyhero13
    Well fuck. So threw double rich banks and MAF code last week. Started idling rough with very low AFR 17s or higher. Reset codes. Cleaned MAF. No codes but very low AFR again. Replaced MAF, same issue. Thoughts?
  26. Jul 14, 2024 at 6:10 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Mine does that rough idle code if it’s 1605 I think
  27. Jul 14, 2024 at 6:18 PM
    Saltyhero13
    Yes. Rescanned and no pending or current codes.
    Only thing that has changed is exhaust and this heat wave.
    I'm reading some people throw codes after installing an exhaust. Going to give it some more time to reset.
    Mdl likes this.
  28. Jul 14, 2024 at 6:19 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Probably flows more now to throw somethings out of range. @snivilous thoughts
    Saltyhero13[QUOTED] likes this.
  29. Jul 14, 2024 at 6:41 PM
    Ctaylor76
    Chaz
    Houston
    if you put new exhaust on that truck probably needs a retune. Sounds like it’s leaning itself out. I thought you had full stainless works system already ? What did you add ?
    ARES35 and Saltyhero13[QUOTED] like this.
  30. Jul 14, 2024 at 6:49 PM
    snivilous
    SW UT
    Can you datalog?
    It's weird you have RICH codes but the truck is reading LEAN unless I'm not understanding. Exhaust doesn't usually seem to make enough difference to throw a code assuming the base tune doesn't have high fuel trims, but that's not to say it isn't possible. But I would expect lean codes, which it sounds like your AFR is showing. If the codes/AFR variance popped up after a modification then I wouldn't think twice that the tune just needs to get dialed in a bit. But if you have rich codes, and lean AFR, well that's a little weird---albeit could still just be as simple as needing the tune tweaked.
    ARES35, Wynnded, Silver17 and 3 others like this.
