DD exhaust w/LT headers w/sound clip pg 8 post 229
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Jun 6, 2024.
  1. Jul 11, 2024 at 6:32 PM
    #211
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So any plans to dyno your truck in the future?
    Once I get tuned, geared to 4.10, and install a Transgo shift kit, I'll probably try to find a place to dyno mine for fun.
    Are you on stock size tires and stock rear gears?
    Weagle[QUOTED][OP] likes this.
  2. Jul 11, 2024 at 6:33 PM
    #212
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Stock gear size. 32 inch tires.
    I believe mine are about 30 1/2 inches from the factory
    265 65 17" from factory
    305 50 20" now
  3. Jul 11, 2024 at 6:41 PM
    #213
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    My 04 AC SR5 didn’t come with an immo
    Weagle[OP] likes this.
  4. Jul 11, 2024 at 6:42 PM
    #214
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    I wanna dyno mine. It spins 35s at 40mph
  5. Jul 11, 2024 at 6:43 PM
    #215
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yours is a whole nother beast than ours though haha
    I'd kill for a SC'd 5.7 RCSB
    Ctaylor76[QUOTED] and Weagle[OP] like this.
  6. Jul 11, 2024 at 6:44 PM
    #216
    Weagle
    Prattville, AL
    I just found online where it said base work trucks and SR5's did not come with an immobilizer. Mine is an SR5.
    I can get cheap keys for mine
  7. Jul 11, 2024 at 6:50 PM
    #217
    Ctaylor76
    Chaz
    Houston
    I honestly have no idea how much HP that truck is putting out, my tires are probably going to go bald before I even find out
  8. Jul 11, 2024 at 6:55 PM
    #218
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Have you done any other power mods?
    That makes sense, the immobilizer chip is in the fat keys. I have skinny keys for both trucks.
    My 06 has Dirty Deeds 12 hole injectors, Airaid modular intake tube, JBA longtubes, VF Tune, Dirty Deeds race exhaust, and 4.56 gears with 33's.
    My 03 has DD 12 holes, Volant intake, JBA LTs, TRD dual exhaust, and will soon have the tuned ECU, 4.10 gears with stock tires, and Transgo shift kit on "truck" setting.
    I can tell you best 0-60 time in the 03 is 6.1sec, using the Track Addict app. I haven't done my 06 yet because it's been sitting in need of repairs for about 9 months now. I was unemployed for about 6 months, so I been slowly fixing it.
    Once I get the 06 fixed I need to do 0-60 run and maybe find a place I can drag race the two trucks.
    Either way they both will likely get dyno'd in 2025.
  9. Jul 11, 2024 at 8:41 PM
    #219
    Weagle
    Prattville, AL
    I have not other than the headers and the DirtyDeeds cat back racing exhaust / duals. Everything but the tailpipes. I had a local shop put on the tailpipes.
    I was going to get those 12 hole injectors. I know there's been a lot of debate on them, but I believe that is what they're putting in the Newer ones
    I've done enough and crammed way too much into the last six months. Going to do the timing belt this weekend and I'm gonna slow down and work on the interior door panels next
    Won't take on any more mechanical or performance projects until next year unless I have problems
  10. Jul 11, 2024 at 8:49 PM
    #220
    Weagle
    Prattville, AL
    I had a brain fart. It wasn't the check engine, but rather the maintenance required light. I haven't timed it, but it blinks for way too long.
    Also just went out to test to be sure we had the ABS sensor issue resolved which it does appear to be. I'll try all the low-speed test and then realized I should do a higher speed stop
    this time it was the check engine light as I was stopping. It went into safe/limp mode for the first time ever. P2111
    Had to clear the code with my OBD app to get out of safe mode. It did not come back on, but I also did not do another hard stop.
    BluegrapeVr6[QUOTED] and shifty` like this.
  11. Jul 12, 2024 at 5:36 AM
    #221
    Was is the sensor O-ring
  12. Jul 12, 2024 at 5:37 AM
    #222
    Weagle
    Prattville, AL
    Yes
    BluegrapeVr6 likes this.
  13. Jul 12, 2024 at 7:00 AM
    #223
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Whats the countdown to your trip? Sounds like you pulled it off w shakedown time to spare.
    Fyi, i will dyno my 02 ( throw stock 265 tires on) , i will have a different set up ( x pipe, hidden tips) and not make the power you vtec guys make lol. And 0-60 in 6 SECONDS? , damn. Thats impressive, i may be getting old
    ..i remember looking on back of CAR AND DRIVER , low 7's=fast, 6= really fast, 5= i cant afford the insurance fast lol. Could anybody log their iat and post? It was 98* here and sitting on RT 97 IT WAS hitting 140* heat soak at dead stop. ( AC cranked , 2 mile long mess if idling cars)
    As soon as traffic clears us , the factory airbox w my crappy ram air mod gets it down to right around ambient. When i stick my hand in front left wheel well its cooking w fan blowing hot air off pass exhaust heat shield. Trying to figure out if my air box mod ( located next to pass headlight is helping or hurting) def lowers iat's above 40 mph. I have a stock box to swap in. But contrary to info on here, the truck does not feel like its breathing through straw anymore.
    455h0le_dachshund likes this.
  14. Jul 12, 2024 at 8:19 AM
    #224
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    6.1sec without VVTI or a tune. But it was like 50° out that morning.
    I monitor my IAT with my scan gauge. What app did you use to make that graph?
    My scanguage can't do that!
    With Volant intake, which has its own airbox, temps get really hot at idle with the headers. I've seen it hit 140° at a light before. But it's also like 100° in TX this summer.
    Once I get up to 60+ mph for a few minutes, it gets down within maybe 3° of ambient.
    I have plans for a hood scoop that would plumb into the top of the Volant box.
    BluegrapeVr6[QUOTED] likes this.
  15. Jul 12, 2024 at 1:59 PM
    #225
    BluegrapeVr6
    J
    Dont want to high jack thread. That graph is from OBDLINKmxpro . I stole a stock bottom half of airbox from a 01 SR5. IMO, YES , at low rpm the struck feels bottlenecked with stock airbox set up. So, i would disagree with the theory the stock air box is not a restriction. No hard data to back it up but it gets better fuel economy by about 2mpg and downshifts less. I dont need a dyno to know it works. I just use cap that " plugs" on to seal if I ever plan to nosedive it into deep water which i do not. I will say, people here are correct when they say our trucks dont like the K&N filters,
    Made my truck idle low until i switched back to oem.
  16. Jul 12, 2024 at 2:01 PM
    #226
    BluegrapeVr6
    J
    Yea you can see the correlation between sitting in traffic and getting truck up to speed pretty clearly.
  17. Jul 12, 2024 at 5:35 PM
    #227
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah cutting an extra hole in the air box is a good move for more air flow. On Tacoma World they use a deck plate from a boat to get the same effect as you and can close it when necessary. "Deck plate mod".
    I've seen references to a "stock airbox mod" but I haven't seen it myself. I suspect it's basically the same as what you did.
    Another similar mod I've personally used in the past is the "swiss cheese air box mod" on my Ranger.
    One last tidbit you can do for a better flow and a little noise is cut off all the baffles and resonators from the intake tube and seal them so it's smoother.
    I use the Airaid modular intake tube with stock air box on my 06. K&N also has a similar tube, I think it's called the "junior" or something.
  18. Jul 16, 2024 at 9:19 PM
    #228
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Definitely made a difference as it's about to be July 17 and I haven't so much as received a shipping notification email.
    I placed the order July 7 and was asked my part number July 11.
    I'm getting impatient lol.
    Everytime I get a new email I think it's going to me the shipping notification and racking number. The dude didn't ever reply when I sent em a pic of the label on my ECU.
  19. Aug 15, 2024 at 4:41 PM
    #229
    Weagle
    Prattville, AL
    I was finally able to record the sound of the new racing dual exhaust, 16" BAM mufflers, and long tube headers from DirtyDeeds on my 06 4.7 DC
    this is after a warm start, rev to 2000 RPM's, a couple to 4000, and then once more to 2000
    very quiet at idle. Relatively tame if you're driving slow, but as you can hear in the video it wakes up when you get on it.
    https://youtu.be/NLg2tPO3t5o?si=6Hp6_uNOawcUmBZl
  20. Aug 15, 2024 at 5:13 PM
    #230
    Weagle
    Prattville, AL
    Did you ever get it? I'm not too terribly impressed with this guy
  21. Aug 15, 2024 at 5:13 PM
    #231
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Hell yeah dude. Sounds great!
    Pretty much identical to mine.
    https://youtube.com/shorts/EdzqZqCMOjY?si=4DCS8ffNHy1pOvSf
    I'm still waiting on my ECU. I talked to Brandon today and he expects to have it ready by the end of next week.
  22. Aug 15, 2024 at 5:14 PM
    #232
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Not impressed with the tune?
  23. Aug 15, 2024 at 6:25 PM
    #233
    Weagle
    Prattville, AL
    there are some quirky things with the idle. When you crank it, it is at 1800 RPM which it has never ever done. It will gradually come back down to normal as though it was just the fast idle when cold
    And there is a condition where you give it gas while stopped and let off and it will drop down to about 500 RPMs. I haven't been able to drive it enough yet identify the exact conditions
    And that guy has not responded to my emails. But I was down with Covid for a couple of weeks. I've hardly driven it because I've been working on the timing belt so I haven't pushed him hard. But just to totally ignore me doesn't sit well with me.
    The actual performance I absolutely love. And I'm not absolutely positive this is all related to the ECU, but that seems the most likely cause. I just haven't been able to drive enough to fully test
  24. Aug 20, 2024 at 12:06 PM
    #234
    BluegrapeVr6
    J
    Sounds great! Sorry to hear about lack of communication.
  25. Aug 20, 2024 at 2:57 PM
    #235
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah @Weagle did you ever hear back?
  26. Aug 20, 2024 at 6:07 PM
    #236
    Weagle
    Prattville, AL
    no, but I've been down due to a few problems changing my timing belt so I haven't tried to contact him again
  27. Aug 20, 2024 at 8:45 PM
    #237
    whodatschrome
    lots of dents
    If it makes you feel any better, it took me a couple YEARS of trying to make first contact to a guy in Slovenia who can delete the immobizer from a KTM 990’s ECU. Once he finally replied to my email, i just made sure to stay 100% on top of communicating with him…and it was still hit and miss if or when he would reply. In a hail mary pass i shipped two KTM ECUs to him…not knowing for sure if i would ever seem them again. He says he has a one day turn around time, but it took him closer to a couple months. Many other ktm owners have used the guy before (including one of my friends), and were very pleased with his work, so i knew he was legit. Long story short i got both my ECUs back and they perform exactly how they should, but i don’t want to go through the process with that guy again. He’s a stand up honest guy, but for some reason he was reeeeealy slow with my ECUs. You would think that if he’s making close to $400 USD for each immobilizer removal (and i sent him two of them), it would be great incentive to do the hour of two worth of labor to put all that $$$ in your pocket!
  28. Aug 21, 2024 at 10:02 AM
    #238
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Dang that thing sounds deep @Weagle very nice man
  29. Sep 6, 2024 at 9:03 PM
    #239
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    @Weagle you ever get your timing belt done and hear back from Brandon?
    How's the truck running now?
    I'm still waiting on him to make an ECU for me. As of this Saturday September 7, it's been 2 months since purchase date.
    He's had a lot of excuses...
  30. Sep 7, 2024 at 7:44 AM
    #240
    BluegrapeVr6
    J
    Did you pay by CC?
