Wheel spacers
Discussion in '1st Gen Tundras (2000-2006)' started by Jeproksky, Jul 9, 2024.
  1. Jul 9, 2024 at 3:41 PM
    Jeproksky
    Jeproksky [OP] New Member
    2001 tundra SR5 V6
    To install a 2023 rims in my truck . I need a spacers pls help
    Hello there
  2. Jul 9, 2024 at 3:42 PM
    Jeproksky
    2001 tundra SR5 V6
    Im a new member
  3. Jul 9, 2024 at 3:44 PM
    Welcome!
  4. Jul 9, 2024 at 3:44 PM
    Aboard!
  5. Jul 9, 2024 at 3:48 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What's your question
  6. Jul 9, 2024 at 3:48 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    About wheel spacers?
  7. Jul 9, 2024 at 3:48 PM
    Jeproksky
    2001 tundra SR5 V6
    What kind of spacers i can get for my 106mm to 95mm wheel bore size?
  8. Jul 9, 2024 at 3:52 PM
    Jeproksky
    2001 tundra SR5 V6
    Yes pls
  9. Jul 9, 2024 at 3:53 PM
    Jeproksky
    2001 tundra SR5 V6
    I have 2001 tundra sr5 v6
  10. Jul 9, 2024 at 3:53 PM
    1.25" wheel spacers / adapters should work. Bora and Spidertrax make them. won't be able to use hubcentric ones though.
  11. Jul 9, 2024 at 3:53 PM
    Jeproksky
    2001 tundra SR5 V6
    And i just purchased a 2023 wheels and tires
  12. Jul 9, 2024 at 3:54 PM
    2023 Tundra wheels?
  13. Jul 9, 2024 at 3:54 PM
    Jeproksky
    2001 tundra SR5 V6
    The one i have have a 106mm
  14. Jul 9, 2024 at 3:55 PM
    Jeproksky
    2001 tundra SR5 V6
    The one i bought have 95mm
  15. Jul 9, 2024 at 3:55 PM
    What has the 95mm?
  16. Jul 9, 2024 at 3:57 PM
    Jeproksky
    2001 tundra SR5 V6
    The one i bought
  17. Jul 9, 2024 at 3:57 PM
    Jeproksky
    2001 tundra SR5 V6
    2023 tundra 18 inch rims
  18. Jul 9, 2024 at 4:01 PM
    Good luck with this. The threads are also different between a 2023 and an FGT. Another member here paid $5-600 for a set.
  19. Jul 9, 2024 at 4:01 PM
    Jeproksky
    2001 tundra SR5 V6
    Where can i get the spacers?
  20. Jul 9, 2024 at 4:02 PM
    Jeproksky
    2001 tundra SR5 V6
    It has 6x139.7 bolt patern
  21. Jul 9, 2024 at 4:04 PM
  22. Jul 9, 2024 at 4:17 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    455h0le_dachshund and JasonC. like this.
  23. Jul 9, 2024 at 4:56 PM
    From THIS THREAD, the last bullet here applies to you:
    • Wheel fitment (backspacing/offset info) ... backspacing/offset plays an important role in whether or not you're gonna rub when choosing larger-than-OEM tires. If you need help with understanding what ballpark you should be aiming in, this is a good thread to read. Gist: The best put year near the fender edge w/o rub on 8½" wide wheel is ~4¾" backspace, at 9" wide ~4.5" backspace. Popular OEM 7½" wide wheels had 5" backspace. You can run oversize 275/70r17 tires on 17x8.5" wheels @ 0 offset (i.e. 4.75" backspace) leveling up front w/minor rub.
    • Wheel fitment (caliper rub): If your truck has larger 13WL calipers, beware of caliper rub! 13WL is std on 2003+
    • Wheel fitment (from other Tundras): 2007-2022 Tundras use 5-lug wheels. In 2023, Tundras started using 6-lug axles again, but the hub bore is smaller (95mm on 3rd gen vs. 106mm on 1st gen), so they technically won't work unless you spend a couple hundo on custom-made spacers.
    But hey, if you're cool with spending a couple hundred bucks to make this work, go to town.
  24. Jul 9, 2024 at 5:30 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    FishNinja likes this.
  25. Jul 9, 2024 at 5:30 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  26. Jul 10, 2024 at 11:48 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
  27. Jul 10, 2024 at 2:14 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
  28. Jul 10, 2024 at 2:56 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Damn, I'm late to the party on this one. Someone is working hard to get to 50. Why is it always the weird ones whose name starts with J. Like Jim, Jimmy, Jerry, Jeramiah....
    shifty` likes this.
